Author Topic: Siglent SDG6000X series 200-500 MHz AWG's  (Read 196497 times)
Online tautechTopic starter
« on: August 01, 2017, 04:54:02 am »
Models of 200, 350 and 500 MHz, 2 channels and 2.4GSa / s sampling rate with 16 bit vertical resolution.
Sine wave amplitude:
20 Vpp ? 40 MHz, high impedance load
10 Vpp 40 MHz to 120 MHz (inclusive), high impedance load
5 Vpp 120 MHz ~ 160 MHz (included), high impedance load
3 Vpp 160 MHz to 350 MHz (inclusive), high impedance load
1.28 Vpp above 350MHz
Square wave to 120 MHz, risetime 2.4 ns max.
196 built-in arbitrary waveforms.
Arbitrary memory depth 2-20 Mpts
Webpage
https://int.siglent.com/products-overview/sdg6000x/
https://siglentna.com/waveform-generators/sdg6000x-series-pulsearbitrary-waveform-generator/
Datasheet:
http://www.siglentamerica.com/USA_website_2014/Documents/DataSheet/SDG6000X_datasheet.pdf
Review from Shahriar:
https://youtu.be/_2LcpH_JxYM
« Last Edit: July 31, 2026, 10:42:20 am by tautech »
Avid Rabid Hobbyist
The following users thanked this post: nikitasius
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: Siglent SDG6000 series 200-500 MHz AWG's
« Reply #1 on: August 01, 2017, 09:22:16 am »
Nice! The specs look pretty good, and it can do PRBS patterns and I/Q modulation as well.
Any ideas when these devices will be available outside China? And what the targeted RRP is for the various versions?
If they get the price right then I'd consider the 500Mhz variant. Hell, I'd even be willing to play beta tester for this thing if that means I could get one at reasonable conditions  ;)
Offline simone.pignatti
« Reply #2 on: August 01, 2017, 09:36:19 am »
Siglent will take 4 to 6 months before shipping out of the domestic market. Or at least this is what they use to do.
Technical Support
« Reply #3 on: August 01, 2017, 09:46:49 am »
It seems there will be a SDG6000X-E version too starting at 160MHz
http://www.siglent.com/function-arb-generator/SDG6000X-E
Only for domestic market, will not be available out of China
« Last Edit: August 01, 2017, 12:03:50 pm by simone.pignatti »
Technical Support
Offline Tsippaduida
« Reply #4 on: August 26, 2017, 12:05:23 pm »
This series actually interests me, no need to buy a Windows-machine (or license) to get wide range of functions out of this. Currently I have no need for fancy AVG, but you never know.
Offline MrW0lf
  • Country: ee
    • lab!fyi
Re: Siglent SDG6000X series 200-500 MHz AWG's
« Reply #5 on: November 03, 2017, 03:59:49 pm »
Offline Plasmateur
« Reply #6 on: November 04, 2017, 11:44:50 pm »
Released in the Chinese marketplace but as yet no western market release date or pricing.
Datasheet: (Chinese)
http://www.siglent.com/Chinese_website2014/Datasheet/SDG6000X_DataSheet_DS0206E-C01A.pdf
Very interested in one of these for my lab at work, as the SDG2042X has been pretty good to me except for that one thing they couldn't fix.
« Reply #7 on: November 05, 2017, 12:47:38 am »
I'd like to say that I can tell you more about the SDG6000X series but I passed on beta testing one as I wanted to focus on the 4 ch X-E that was offered at the same time too.  :scared:
Last I heard Wuerstchenhund might be getting one to beta test but Dave has unfortunately banned him from the forum so we've not likely to get much unless he PM's one of us. Last I looked at his profile he was keeping an eye on us all. He gave Siglent a good bit of stick over the years so I hope he makes some contribution to their products.
WRT 2042X, I'll have some more in a week or two and I'll reinvestigate the thing you wanted fixed/changed/added.
Avid Rabid Hobbyist
The following users thanked this post: Plasmateur
« Reply #8 on: November 05, 2017, 03:10:34 pm »
Last Friday I went trough the specs of the Chinese PDF, it seems the 500MHz will be kind of unique product. It is not easy to create the best test set-up, for sure high frequency calibrate coaxial cables and at least a 1GHz bandwidth oscilloscope with high sampling rate and accurate vertical resolution. I'm not sure I'll be ready to test it before Xmas even if I will get then unit as soon as it will be available in EU.  :(
However I'm available for specific tests, if you are interested just drop me a line with your test requirement.
Technical Support
« Reply #9 on: November 06, 2017, 08:45:51 am »
The European public launch for the SDG6000X is scheduled for November the 16th
It seems it will carry a surprise surprise for all of us ... the frequency maybe hackable as it is for the SDG2000X  :-+
Can't wait  :popcorn:
Technical Support
Online gby
« Reply #10 on: November 11, 2017, 03:23:01 pm »
Go an email Nov 10 from Circuit Specialists in the US showing  these generators up for order.
SDG6022X 200MHz $1,499 (back order ships 11/29/17)
SDG6032X 350Mhz  $3,339 (ships in 1-2 business days)
SDG6052X 500Mhz $5,299 (ships in 1-2 business days)
A fair bit pricier than the SDG2000x series but if you need the higher frequencies still probably a reasonable value.
Offline alreadystarted
« Reply #11 on: November 13, 2017, 08:26:23 pm »
I see this page on the English language site mentions a SDG6000X-E series.  But there's no listed devices from that series.  That's pretty interesting.  Anyone have more info on that?  Possibly from Chinese market?
The only details are just a note on rise times:
The rise/fall times of the SDG6000X can be set to as low as 1 ns (SDG6000X-E series as low as 2 ns), comparable to much higher – priced units.
http://www.siglent.com/ENs/qyxwxx.aspx?id=2217&sid=25
« Reply #12 on: November 13, 2017, 09:25:26 pm »
SDG6000X-E only for domestic market
EU launch was planned for the 16th not sure why is already online.
For this reason on our website we have activated the 3 models and the IQ option too so you can check European pricing.
All models available.
Technical Support
Offline bson
« Reply #13 on: November 14, 2017, 12:09:23 am »
Offline Qw3rtzuiop
« Reply #14 on: November 15, 2017, 01:32:27 pm »
Which scope is used in that video? Afaik there is no siglent scope with that high bandwidth. There is just a branding Siglent powered by LeCroy. Can we also expect a high bandwidth scope from siglent?
« Reply #15 on: November 15, 2017, 01:53:48 pm »
SDS3000 or LeCroy WaveSurfer 3000 (same unit)
Technical Support
Offline bson
« Reply #16 on: November 16, 2017, 07:10:02 am »
It's not a WaveSurfer 3000 - it lacks the ProBus probe connectors and seems to have only basic BNC inputs.  Otherwise looks very similar, though white instead of black.  Interesting that the Siglent scope runs LeCroy firmware.
« Reply #17 on: November 16, 2017, 07:30:17 am »
I just checked again and I confirm is the SDS3000 (white version of the WaveSurfer 3000)
If you jump to 1’34” you can see the logic pod on the right.
Technical Support
Offline rf-loop
« Reply #18 on: November 16, 2017, 08:38:43 am »
It looks like  "alternative truth" aka "trumth" is so popular that it has to penetrate everywhere. Or how this must think?
Checking the facts.
TeledyneLecroy WaveSurfer 3000  is manufactured by Siglent and  is same as Siglent SDS3000.
Yes labels are different and outer case plastic color is different.
No ProBus in Siglent?  Where from this information come?
Look this image. Only BNC's ?
EV of course. Cars with smoke exhaust pipes - go to museum.
« Reply #19 on: November 16, 2017, 08:42:45 am »
Maybe next year.
Avid Rabid Hobbyist
« Reply #20 on: November 16, 2017, 08:54:11 am »
Checking the facts.
The probus in next to each BNC. Siglent and LeCroy are exactly the same.
Technical Support
Offline rf-loop
« Reply #21 on: November 16, 2017, 10:23:58 am »
Checking the facts.
I know this of course.
But @bson  "know" the "alternative truth".
Offline JPortici
« Reply #22 on: November 16, 2017, 10:50:42 am »
Maybe next year.
hopefully with more horsepower and capacitive touch instead of that crappy resistive one.. it's been a real pain to use that lecroy
« Reply #23 on: November 17, 2017, 09:12:31 am »
Maybe next year.
I didn't try the touch screen when I was at the Siglent factory 3 years back, only the physical controls, however I don't hear of negative comments of the SDG2000X AWG touch screen so one would imagine any touch interface for a new high BW Siglent DSO will follow the experience gained with the popular SDG2000X series.
https://www.eevblog.com/forum/testgear/siglent's-new-products-sds3000-series-oscilloscopes/msg558936/#msg558936
Avid Rabid Hobbyist
Offline JPortici
« Reply #24 on: November 17, 2017, 11:32:15 am »
well, screen is about twice as big..
in the lecroy we demoed the touchscreen was so bad that you had to press too hard to use it and when you didn't move your finger the cursor would move frenetically. with a stylus, not so bad but at that point i'd rather use a mouse thank you very much :(
