Author Topic: Siglent SDG6000X series 200-500 MHz AWG's  (Read 155093 times)
Offline alex_0331
  • Country: cn
Re: Siglent SDG6000X series 200-500 MHz AWG's
« Reply #600 on: December 18, 2025, 04:28:15 pm »
Yes, cause I've done it.
The following users thanked this post: GerardF
Online KungFuJosh
  • TEAS is real.
« Reply #601 on: December 18, 2025, 06:57:44 pm »
Best Continuity Tester Ever
Offline GerardF
« Reply #602 on: December 19, 2025, 02:21:06 pm »
Just picked up my system. SW version 6.01.01.38R3.
It looks like I was able to activate the IQ function entering the code the script generated via the screen.
I do not see the counter anymore when choosing IQ waveform, so I assume it worked.
Next the freq option, but I guess that can only be done via the network interface.
Happy with it, as I use the system for hobby and would like to learn but not build commercial systems.
Would also be happy with the system without it but very nice to play with it.
« Last Edit: December 19, 2025, 02:30:16 pm by GerardF »
Offline mawyatt
« Reply #603 on: December 19, 2025, 02:45:13 pm »
The SDG6000X is a good AWG that covers a nice frequency range up to 500MHz!! You can use a cheap Disciplined GPS OCXO like the BH3SAP (be sure and check for the mis-wire and make the mods for best results) if you want extreme frequency accuracy.
https://www.eevblog.com/forum/testgear/10mhz-gpsdo-by-bh3sap/msg6034083/#msg6034083
Best
~Wyatt Labs by Mike~
Offline GerardF
« Reply #604 on: December 20, 2025, 10:41:46 am »
Thanks, a good idea to look into that.
These seem a bit tricky to get. Would this be a good alternative option to use ?
From the Dutch guy who also did the TinySA analyzers. I met him at a recent Ham radio show where he showed it.
https://www.tinydevices.org/wiki/pmwiki.php?n=TinyGTC.GPSDO
Offline GerardF
« Reply #605 on: December 20, 2025, 01:57:47 pm »
Made a telnet connection to the unit, notice that the code I get with MCBD? Command is different that the Bandwith codes that were generated by the script.
Is that correct ?
What happens if I enter a wrong code ?
Offline Martin72
« Reply #606 on: December 20, 2025, 03:00:14 pm »
It will explode.. ;)
No, nothing should happen, wrong code will be ignored.
Reading out the key for the actual bandwidth serves as a check.
If you have “fed” the key generator correctly, this code should also appear under the bandwidth keys.
Then you know that the generated key for the 500M is correct.
Offline GerardF
« Reply #607 on: December 20, 2025, 03:25:52 pm »
Thanks, that is what I thought.
Strange. It was the code from the same run of the script that I used to activate the IQ option.
Offline GerardF
« Reply #608 on: December 24, 2025, 11:21:37 am »
Although the code showed by MCBD? Was different for 200 MHz than what the script shows, I entered the 500M code anyway.
Happy to share it still worked :-)
