Author Topic: Siglent SDM3065X Issues? RMA Time?  (Read 19828 times)
Offline Rhine_LabsTopic starter
  • Rhine_Labs
    • My Personal Blog
Re: Siglent SDM3065X Issues? RMA Time?
« Reply #25 on: August 03, 2021, 05:09:30 am »
I e-mailed Siglent the questions about the accuracy verification report and if the 3065X and The HP3458A agreed if hooked in parallel over the weekend have not received a response.
I have some photos of the 3065X hooked in parallel with my fluke. (I Did not take many but enough for my documentation)
Cold and off For 1 Hour or So Right After Firmware Update. The fluke and SDM3065X Almost Agree.
After an Hour or So. (The Error Kept Drifting Up on the Siglent) even with a shutdown and restart after an hour the error would be small but increase over time.
30V I know the Polarity on the silent is reversed but did the same the other way around.
10V
60V
« Last Edit: August 03, 2021, 05:38:01 am by KG7AMV »
Online bdunham7
« Reply #26 on: August 03, 2021, 05:34:45 am »
So you're saying the error increases with power on time even after the meter is power cycled warm?  And even a short power cycle will reset or greatly reduce the error?  If the Siglent tech wasn't aware of this, perhaps the meter could pass a performance check cold?  The first photo shows no error, and the second, assuming the PSU drifted down and the Fluke 187 is more or less correct, an error of 500ppm, which is only possible if at least one of the meters is out of spec.  However, unless you subject the Fluke 187 to a similar hours-long test with a presumed good meter, I'm not sure how you can convince anyone that the Siglent is the one that is faulty.
  • Rhine_Labs
    • My Personal Blog
« Reply #27 on: August 03, 2021, 05:41:41 am »
Short power cycle had no change.
Yes, i told siglent this went back 1 firmware revision the error was less. That is how I discovered that when you upgrade the firmware it agrees with the PSU Output and the Fluke.
Even if you shut the meters off for an hour and turned turned them back on the error would be present only time they would agree would be upon a firmware update and just for a few min.
Both meters were on and off the same amount of time.
The output displayed on the PSU agrees with the Fluke when psu is on for 30 or so min will read flat 10.000 on the fluke.
Generic
I am sure if I had the Siglent in parallel it would have read 10.053 or higher.
« Last Edit: August 03, 2021, 06:21:49 am by KG7AMV »
Online bdunham7
« Reply #28 on: August 03, 2021, 05:50:18 am »
The output displayed on the PSU agreed with the Fluke.
So if I was trying to look at the temperature coefficient and power-on stabilization time for a meter, I'd connect two meters and a PSU in parallel, like you have.  Then I'd leave the PSU and the known-good meter on overnight to let them completely stabilize, then turn on the test meter in the morning to see how it behaves.  If you turn them all on at the same time, its hard to know which one is doing what.  Your 187 and PSU are probably right, but that is a hard case to make when both of them are so much less precise (on paper) than the 6.5 digit DMM.  Hopefully Siglent can respond in a way that is convincing one way or another.
 :o
« Last Edit: August 03, 2021, 05:52:23 am by bdunham7 »
  • Rhine_Labs
    • My Personal Blog
« Reply #29 on: August 03, 2021, 07:01:16 am »
We shall wait and see!
Online Kleinstein
« Reply #30 on: August 03, 2021, 08:52:02 am »
If the reading changes with a FW update, this could mean there could be a change in the cal constants, like an additional constant used of possibly a different use of some data. This may effect some units more than others. So there could be FW bug to cause a changed reading that is not obvious on all units. Worst case a change in FW would need a new calibration, but this is usually something they would avoid, if possible at all.
Maybe they try to copy some feature of the KS34470 drift after ACAL.  :-DD
The Fluke meter and the supply are not really good to give a definitive answer. The Sigilent service should however be able to check this rather fast, with a suitable grade meter. The error looks so large, if should even show up comparing to a 2nd 3065 meter that is allready proper warmed up.
Which FW versions were used (before / after) ?
  • Rhine_Labs
    • My Personal Blog
« Reply #31 on: August 03, 2021, 10:45:39 am »
Kleinstein,
Current 3.01.01.08R1 Large Error.
Previous 3.01.01.07 About 1/2 the error of firmware above.
Siglent told me a Firmware update should not change calibration.
  • Rhine_Labs
    • My Personal Blog
« Reply #32 on: August 03, 2021, 10:59:19 am »
They should be testing this on a DC calibrator not a power supply, they are completely different beasts and have very different stability expectations, a calibrator will be much lower noise and have much higher stability, a power supply could drift constantly or contain high frequency noise which may or may not get filtered/captured by the meter being tested...
It sounds to me like they don't have the right gear there to do the testing... personally I have a few DC calibrators and I am just a nerd that fixes stuff, so I don't think they have an excuse for not having the right equipment to do the job.
TheDefpom, I think I have seen you on youtube.
When I spoke with Scott @ Siglent 2 days after DMM landed on their dock about 2 weeks ago he said they just got some new equipment but did not elaborate.
So far all the other Siglent stuff I purchased recently is preforming as it should rather impressed better then expectations. I am very happy with the Function Generator and Scope the DC Load I still has to prove itself but so far acceptable.
Online mawyatt
« Reply #33 on: August 03, 2021, 01:33:50 pm »
Been following this thread as we're considering a SDM3065X as a replacement for an aging HP34401A which needs new display and haven't the time to fix this now (in the middle of a complex project that needs this level of DMM performance).
I can vouch for the SPD3303X-E, we've been using one of these (have 3) for a variable reference. Did some simple tests using a KS34465A, and the SPD3303 (all 3) were very stable with little low frequency cyclic or random noise. An LM399 or LTZ1000, no, but pretty good PS IMO (sans issue with my improper calibration causing CC offset...another story, hopefully with a good ending).
If the OP SPD3303X-E is as stable and low noise as our 3, then using it as a short term reference for comparing the questionable SDM3065X against a known good DMM seems acceptable.
Good luck and hopefully Siglent will get back to you soon with an acceptable solution.
Best,
~Wyatt Labs by Mike~
The following users thanked this post: Rhine_Labs
  • Rhine_Labs
    • My Personal Blog
« Reply #34 on: August 03, 2021, 02:15:39 pm »
mawyatt, I got my PSU used and agree it is very stable. I will be adding a 5A SPD1305X next prime/holiday sale.
SDG2042X is awesome the frequency counter on it has come in very handy recently.
  • Rhine_Labs
    • My Personal Blog
« Reply #35 on: August 03, 2021, 07:15:26 pm »
Got a Siglent Reply..
As I mentioned in the first email I put your SDM3065X on the Fluke 5522A Mulit Purpose Calibrator and tested it and it passed all of the DC voltage performance verification. This alone is enough for us to verify your SDM3065X is within specification.
Then knowing you performed your tests without a Fluke 5522A I used our calibrated equipment to run the tests again using the accuracy specs for instrument in the test. All the equipment used here for testing has been calibrated within the last year. Here is my process of testing.
First I calculated the B2901A Accuracy from data sheet (% reading + offset) ±200 V range - ±(0.015 + 50 mV). Then I set the B2901A at 30 V and based on the setpoint accuracy the true ouput range will be between 30.0545 and 29.9455.
Here is my math.
30  * .00015 = .0045; .0045 + 50 mV = 54.5 mV; 30 + .0545 = 30.0545; 30 - .0545 = 29.9455; range is between 30.0545 and 29.9455
Then I took the SDM3065X data sheet on 200 V range specification which reads DC Voltage Accuracy±(% of Reading + % of Range) 0.0050 + 0.0005.
Here is my math.
Example measurement was 30 V on 200 V range – taking my B2901A source accuracy range which is between 30.0545 and 29.9455 I added and minused to get the measurement range.
30.0545 * .00005 = .00150272; 30.0545 * .000005 = .00015027; 30.0545 + .00150272 + .00015027 = 30.056153
29.945 * .00005 = .00149725; 29.945 * .000005 = .00014972; 29.945 - .00149725 - .00014972 = 29.943353
The measurement range is between 30.056153 and 29.943353.
The picture I have included shows your SDM3065X measuring the B2901A @ 30 V. It measured 30.0085. Which if you see the measurement range is between 30.056153 and 29.943353 so your SDM3065X is well within specification.
« Last Edit: August 03, 2021, 08:32:00 pm by KG7AMV »
Online bdunham7
« Reply #36 on: August 03, 2021, 07:38:56 pm »
Yikes!  I think someone is lacking a fundamental understanding of how this all works, which is what I was afraid of.  Perhaps the best way to approach this is to reiterate that the meter is accurate at first, but after a warmup it starts to drift higher.  The calibrator should catch the error in that case,  but if they don't want to tie up their calibrator for hours, they can just connect their Keysight SMU, your meter and the HP3458A all in parallel and observe them for an hour or three.
The best part is that the Keysight SMU is probably dead accurate and they are actually sending you a photo that demonstrates the error, but instead of just measuring with the HP3458A, they are usign a calculated uncertainty and concluding that it is OK.  Perhaps they are conflating a Planck/Schrodinger type of uncertainty with the sort of uncertainty that can be eliminated by accurate measurement.   |O
Online Kleinstein
« Reply #37 on: August 03, 2021, 08:07:14 pm »
What I found he 1 year specs for the SDM3065 in the 200 V range are 50 ppm of the value + 5 ppm of the range ( = +-1 mV).
For 30 V input in the 200 V range this would be +-2.5 mV maximum error.
In the 200 V range the B2901 is a good supply, but to no surprise the specs (150 ppm+50 mV) are not good enough to test a 6 digt meter.
With 30 V this are 50 mV + 4.5 mV uncertainty, though the typical error is usually much smaller (e.g. 3 times for a well maintained instrument).
So the test with the supply does not tell that the meter is in spec, it only can not prove the meter is far out. The 8.5 mV are even not yet in the range to call it suspicious from this test.
It would need at least a second better meter.
The Fluke 187 should have specs of 300 ppm+3 mV (50 V range) and thus +- (9+3) mV. So it is slightly tighter specs for 30 V, but still not good enough to really call it out. The observed drift still makes the sigilent meter slightly suspicious, though the specs usually only apply after plenty of warm up. For an bench meter there usually are no specs for use after 1 minute warmup. For a Handheld this may be useful.
Some meters include corrections to improve the performance in the warmup period - this may change with FW version and maybe it got worse in this case.
However the part on the test with a 3458 still makes it a bit odd - so they may have done this test quite wrong in some way. Even than the stabilty of the B2901 should be consideratbly better than the accuracy specs.
The automated performance test may not include a point near 30 V - though it ideally should.
Offline rf-loop
« Reply #38 on: August 04, 2021, 06:07:43 am »
Afaik this is from Siglent:
"As I mentioned in the first email I put your SDM3065X on the Fluke 5522A Multi Purpose Calibrator and tested it and it passed all of the DC voltage performance verification. This alone is enough for us to verify your SDM3065X is within specification."
This is main thing. All other measurements and calculus they are more like entertainment stories.
Also there is important things on specifications.
SDM3065X Specifications are for 90-minute warm-up and 100NPLC integration time!
Also whole test setup need be fully reached thermal equilibrium including contact interfaces where the material changes at the joint, including coatings. (thermal emf, example one worst case is copper-copper oxide joint... 1mV/celsius. In normal serious cal I have used pure copper wires without any plating and just before tight contact all the oxide layer removed mechanically, but with 6.5digit meter it is not so critical specially when can wait enough for thermal equilibrium between all joints)
They have checked  it using Fluke 5522A, if I understod right, and if with it this SDM3065X meet its specs it is well enough said.
Fluke calibrator specs. All other things are then nonsense and mainly entertainment.
https://download.flukecal.com/pub/literature/3931295f-en-5522A-ext-specs-w.pdf
Measuring SDM3065X accuracy using some old fluke 187 and comparable instruments is more like joke if use this for claim nearly ten times more accurate instrument with fresh cal is out of specs. Or with some friend old Keysight 5.5digit unknown DMM.
First there need need use very stable low noise cal grade ref source... you do not have it at all here but just used normal PSU.
When there is fluctuation and noise different meters may handle it bit different.
For claim SDM3065X is out of specs you need even some ground under legs... other ways it is waste of time.
Even if you connect many DMM parallel and wait until all are stable and in thermal equilibrium so that also environment temp is enough stable...  even then if do not have cal grade voltage reference it is like an entertaining hobby for spending free time. (because diffeerent meters handle DC fluctuation and noise differently - comparing nearly like apples and shoes or least oranges)
I do not understand at all why Siglent NA did this playing with this B2901A and some calculus just for generate just extra mess more  than give answers specially (perhaps they was trying to do teaching but imho is better to leave for teachers).
If they have just Fluke 5522A and HP3458A and these together tell it is OK then it IS ok if these tools have valid certified cal (it was told they was in cert cal.) and measurements done as need do.
« Last Edit: August 04, 2021, 06:11:07 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
The following users thanked this post: egonotto, Bad_Driver
Online bdunham7
« Reply #39 on: August 04, 2021, 02:46:07 pm »
With respect for the expertise you have brought us in other areas, you are making some errors of thinking here.
Your basic premise is that you need calibration-grade sources to determine that at meter is out of spec.  This is false.  You need calibration grade sources to properly calibrate the meter, and possibly to verify that it is in spec.  If your Siglent DMM is reading 2X actual values, I can demonstrate that with a Simpson 260 or a Harbor Freight freebie.  In this case, the customer complaint is that it starts out reading correctly and then drifts high.  It may be the case that the calibration procedure may not catch this because we don't know the cause of the drift nor the exact conditions under which it will occur.  It may be, for example, that it only happens when you take a continuous reading of a stable value for an hour straight, in which case the presumably automated calibration procedure won't catch the error, but any idiot with a stable PSU and a decent DMM--not necessarily one rated as well as the DUT--would catch the error the OP complains of.
The issue of the low-noise 'cal-grade' source is a bit trickier.  Calibrators are not necessarily very low noise, in some cases a PSU or SMU might actually be better than a given calibrator.  While it is true that a significant amount of noise might affect the actual calibration process, we don't buy expensive meters just to measure 'low-noise sources' and batteries.  Any reasonable DMM needs a fair amount of normal mode rejection (the 100NPLC is there for that exact reason) and the difference in effect of PSU noise on various multimeters will be fairly low, most certainly much lower than the error reported by the OP.  This is especially true of an SMU like the Keysight model used here.
Attitudes like this are why we have return policies and customer protection laws.  I do not know whether the OPs meter is defective or if he has made some usage error that just hasn't come to light yet.  However, Siglent has not addressed his actual stated issue (at least as stated to us after some clarification) and unfortunately, the 'playing' you referred to reveals at least a communication error and at most a gross misunderstanding of the fundamentals of uncertainty.  The correct way to handle this would be to simply take the OP's meter, the Keysight SMU and the HP 3458A, connect them all in parallel, set the SMU to 30.0000 volts and go to lunch for an hour.  If both the HP3458 and OP's meter agree to within the specs of the SDM3065X (the SMU specs are completely irrelevant) then the complaint has not been verified.  If they differ by more than allowed in the SDM3065X specs, the meter is broken.  Not out of cal, broken.  Now if you insist on using 'cal-grade' sources, you could simply substitute the 5522A calibrator and set it manually to 30 volts and then go to lunch with that running--the HP3458A would be optional.
Offline 2N3055
  • Country: hr
« Reply #40 on: August 04, 2021, 05:14:09 pm »
That would be true for a CALIBRATED Simpson260 or a Harbor Freight freebie. And then it would be only possible to do so if error was larger than what the guardbands are for Simpson.
Answer from Siglent is correct but not written in language easily understandable for those that are not clear on all the concepts.
Let's break it down:
1. Factory specification for meter is after 90 minutes of warmup (1 hour 30 minutes). Anything before that is IRRELEVANT to specification verification. By the way, that is somewhat similar for all long scale meters. I believe someone mentioned than new Keithely meters are bit faster in warmup, less than 45 min to good accuracy. My old Yokogawa takes 2-3 hours to settle (no forced heating), Rigol DM3068 60-90 minutes, depending on temp in a lab.
2. They tested meter with Fluke calibrator and factory calibration fixture and it was verified in spec. That alone does mean it is passing verification.
3. Then they went to try and demonstrate how people can get confused by using equipment that is not good enough to test accuracy. OP tested with bench PSU, and 20+years old Fluke 187 that was never calibrated and a noname cheapo multimeter.  Why would you proclaim brand new 6.5 digit meter is wrong when tested against 20 year old handheld instrument of inferior specification, whose temperature coefficient in 1°C  contributes more than TWICE complete accuracy specification the instrument ??
Let me repeat: 1°C of temperature difference for Fluke contributes to error TWICE as much as full specified error for that range. 1°C of difference and your error in that range is not anymore 0.03% but a full 0.08%.. Few more degrees and all bets are off..
So they went and tried to demonstrate how you CANNOT do that with inferior instruments, but that got misunderstood. They didn't try to demonstrate how you can do performance verification with B2901A, but opposite, how you cannot do that, even with such an expensive SMU, because even THAT is inferior to what is needed to verify 6.5 digit meter.. He was probably confused how OP doesn't understand those basic facts.
All this is just a demonstration what kind of bias exists out there. These people are not amateurs. They know their stuff.
So let's do some math for worst case scenarios..
Quick calc for Fluke  187 (providing it is FULL in spec):
At calibrated temperature                        What can it really be:
      Accuracy                          Measured                      Min              Max                P-P error
      0,0300%    +   0,003   .   30,04100E+0   .   30,02899E+0   30,05301E+0   24,02460E-3
      0,0300%    +   0,003   .   10,01700E+0   .   10,01099E+0   10,02301E+0   12,01020E-3
      0,0300%    +   0,003   .   59,99000E+0   .   59,96900E+0   60,01100E+0   41,99400E-3
At 1°C+calibrated temperature
      0,0800%    +   0,003   .   30,04100E+0   .   30,01397E+0   30,06803E+0   54,06560E-3
      0,0800%    +   0,003   .   10,01700E+0   .   10,00599E+0   10,02801E+0   22,02720E-3
      0,0800%    +   0,003   .   59,99000E+0   .   59,93901E+0   60,04099E+0   101,98400E-3
So WITHOUT even adding SDM3065X specification, what is shown is included in error specification of THE Fluke 187. And by that I mean that nothing is wrong with it, it just how accurate(inaccurate) it is. Which, by the way, is excellent for 60000 count handheld instrument that old.
So OP's findings are just fine. But conclusions were wrong.  Errors made:
1. 90 minutes to warm up.
2. Not calculating what specifications really mean
3. Cognitive bias that 20 years old inferior specification Fluke must be "more right" that Siglent's modern, new 6.5 digit meter...
4. Not being suspicious and going back to it, until all the math is right.
Those are all human failings. Nothing unusual to make mistakes. But they have to be opportunities for learning. And if we put in effort, it can be opportunity for all of us to learn new things.. It makes us better..
Dr. Richard W. Hamming
The following users thanked this post: Bad_Driver
Online bdunham7
« Reply #41 on: August 04, 2021, 05:57:02 pm »
No, no, no and no.  You, Siglent and rfloop are completely missing the point and all of this talk about calibration is just irrelevant.
The facts as stated by the OP, if all correct, seem to indicate the possibility that the meter is BROKEN.  Not 'out of cal', BROKEN.
If I have a BROKEN meter that reads a 9 volt battery as 18.0678 volts and I confirm that my many-decades old Simpson reads that same battery as 9-ish volts, I have demonstrated that the meter is BROKEN.  Of course there is always some possibility of a mistake on my part or some freakish mishap, but those aren't calibration issues per se.  In this case, the error is not 2X, but still much larger than the specs of the meter.  Whether it is large enough to be definitively affirmed by the instruments the OP had at hand may be an issue, but that is easily resolved by simply using better instruments.
The fact that the meter has 6.5 digits and some spec or another does not prevent you from concluding that it is wrong using a lesser-spec known good meter.  What you are willing to accept as 'known good' is debatable, but it has nothing whatsoever to do with the relative precision of the devices.  The only other issue is by how much the suspect meter is wrong.
It is possible for an instrument to go through calibration, pass its performance verification and still not meet its specifications.  I've seen it happen.  I'm not concluding anything about this situation yet, but IMO a proper analysis starts with determining whether or not the customers observation is true or not, not calibration.  Calibrating a broken meter solves nothing, doing a calibration check on a broken meter proves nothing.
That's the procedure for calibration or the achievement of maximum accuracy.  If the SDM3065X normally has errors this large for more than a few seconds after power-up, then it is unlike any other 6.5-digit DMM I have seen.  In any case, the OP reported just the opposite--the meter seems accurate at power-on and then drifts away.  A lot.
 :scared: Where do you get this?  The 187 DC specs are valid from 18C to 28C with no temperature correction.
The SMU with the 3458A are plenty to confirm or refute the OP's complaint.  To repeat, I'm not making any conclusion as to the OP's complaint.  Siglent had the tools at hand to make a pretty clear determination one way or the other, but they didn't do it.  They're stated reasoning, if I read it correctly, is that you can't use a precision DMM to accurately measure the output of an SMU/PSU because of the 'uncertainty' in the SMU/PSU.  That is nonsensical.  Many will try to reinterpret what was said into something that makes sense, but reread exactly what he said, including the ending "Which if you see the measurement range is between 30.056153 and 29.943353 so your SDM3065X is well within specification."
« Last Edit: August 04, 2021, 07:46:05 pm by bdunham7 »
Offline wraper
  • Country: lv
« Reply #42 on: August 04, 2021, 06:18:07 pm »
Yep, I had a similar issue with a 2 weeks old Rigol DM3068 about 7 years ago. It had fluctuating readings on AC ranges which technically were barely within calibration spec. After meter was kicked back for 2 times with very long turnaround, with no repair and stupid arguments over email (even though Rigol person had seen fluctuating readings), I became tired with their BS. Took it apart and made that meter really no longer measured AC at all and got it swapped. Surprise, no more fluctuating readings.
  • Rhine_Labs
    • My Personal Blog
« Reply #43 on: August 04, 2021, 07:04:08 pm »
I just got off the phone with Dave the GM at Singlet I explained to him whats going on.
They will be sending me a new replacement.
The following users thanked this post: egonotto, 2N3055, mawyatt
Offline 2N3055
  • Country: hr
« Reply #44 on: August 04, 2021, 08:08:29 pm »
The SMU with the 3458A are plenty to confirm or refute the OP's complaint.  To repeat, I'm not making any conclusion as the OP's complaint.  Siglent had the tools at hand to make a pretty clear determination one way or the other, but they didn't do it.  They're stated reasoning, if I read it correctly, is that you can't use a precision DMM to accurately measure the output of an SMU/PSU because of the 'uncertainty' in the SMU/PSU.  That is nonsensical.  Many will try to reinterpret what was said into something that makes sense, but reread exactly what he said, including the ending "Which if you see the measurement range is between 30.056153 and 29.943353 so your SDM3065X is well within specification."
Broken meter was his claim based on fact that cold it agrees with 20 year old, never calibrated Fluke 187. That is no verification for all the reasons explained. As far as I know it could have been Fluke drifting..
You are correct about temperature coefficient, I did misread,  it is outside 18-28°C, unlike what I understood. I made a mistake there. Corrected calculations are:
         Accuracy   .          .   .   Measured   .          Min              Max             P-P error
      .   0,0300%    +   0,003   .   30,04100E+0   .   30,02899E+0   30,05301E+0   24,02460E-3
   .   .   0,0300%    +   0,003   .   10,01700E+0   .   10,01099E+0   10,02301E+0   12,01020E-3
   .   .   0,0300%    +   0,003   .   59,99000E+0   .   59,96900E+0   60,01100E+0   41,99400E-3
So my calculations for the tempco were very much off. I apologize for that.
But still, basic errors for F197 are in the order 12-44mV P-P for measured values. Providing it is perfect. Which there is no reason to believe it has to be.
They also said that SDM3065X and 3458A agreed between themselves while measuring B2901A. Rest is trying to explain how large errors can be if you only use B2901A as reference .. It is written a bit confused..
Anyways, I'm not saying meter was perfect. I cannot know that, short of testing it myself.
But whole thing went about kinda wrong way.
If I buy two meters: Keysight 34465 and SDM3065X, connected them in parallel, and they differ 20 mV while measuring 30V, which one do you send back ?
Even in that case proper answer is you verify both. You might say that Keysight might be less likely to be wrong (years of experience etc..) but that is wrong. If error between those two instruments is so large, there must have been some damage in transport or something like that. Those can happen to any vendor.
But if you take 60000 count meter that is very old and never calibrated, you can maybe start suspecting that your brand new SDM3065X is not doing well, but you cannot be sure which one is wrong.
Would you be so eager to say the same it if it was Uni-T 60000 count meter.. I personally have experience those are very accurate, albeit bad mechanical quality so they start falling apart after some time... But as long as they are new they are very accurate.
So yes, OP could have suspect something was not OK with his new SDM3065X, but I would try to compare it at least with another 5.5 digit meter (that one could have been good enough to verify such a large claimed error). Fluke 187 is only good enough to rise suspicion and prompt an additional action.
But good news is that OP will get a replacement one, just to make sure this is solved for him in satisfactory manner. That is all that matters. And that is, after all the effort, good support.
Online bdunham7
« Reply #45 on: August 04, 2021, 09:19:19 pm »
They also said that SDM3065X and 3458A agreed between themselves while measuring B2901A... It is written a bit confused..
I didn't actually read that, I think it is just what most people would assume happened because it makes the most sense.  It's what you or I would do.  What the tech appears to have done is noted that both the SDM3065X and the HP3058A separately met their respective combined uncertainties, a calculation that is obviously dominated by the SMU.  If he had simply connected them in parallel and sent a photo of them agreeing after an hour, I would be pretty convinced.
Of course the OP could have theoretically done more to verify the issue, but he did what he did with what he had at hand and didn't consult all of us ahead of time.  Once he identified an issue, he expected Siglent to investigate and take care of it, all perfectly reasonable.  As for what to do in your example, it just depends on what you have available.  Strange errors like this can actually be quite difficult to nail down.
FWIW, my experience with the Fluke 187/189 types is that there is an 80% or better chance of them being accurate to within an absolute 2 counts, 3 on a bad day, regardless of what the maximum uncertainties in the specs are.  That includes old and very beat ones--they're all old at this point.  They're much more likely to break than go out of cal.  A 20-count discrepancy would concern me, specs or no.  It's true that if the SDM3065X were on trial, that evidence alone would leave some reasonable doubt, but it would also not be something I would dismiss out-of-hand.
Well, lets see what the new one does...I hope the OP does the same routine and posts it either way.
Online mawyatt
« Reply #46 on: August 05, 2021, 12:25:10 am »
This indicates to me Siglent did the right thing for the customer, and what one would expect from them. Sure it took a little effort but in the end they supported the customer, so hats off to Dave and Siglent :-+
Been following this for awhile to see how things turned out. We need another quality DMM for our on-going project, one of the 2 HP34401As displays is fading and needs replacement (will try and replace the display when time permits). We were considering another KS34465A (we have one), but that is overkill for the need and over budget, so please tell Dave that his and Siglent's handing of this issue made the decision for us get the SDM3065X. Just ordered from Saelig in NY, the last one they had :phew:
Keep us up to date when the replacement arrives and how it behaves.
Best,
  • Rhine_Labs
    • My Personal Blog
« Reply #47 on: August 05, 2021, 12:38:23 am »
bdunham7,
I will for sure be doing the same checks with the new replacement when it arrives and will post results.
mawyatt,
Yea, Dave handled it well he said it would ship tomorrow 08/05 or the next day.
I just checked their site it is showing (1 week lead time) so I will just have to wait and see if thats the case.
  • Rhine_Labs
    • My Personal Blog
« Reply #48 on: August 06, 2021, 07:35:30 pm »
Got a package shipment notification from FedEx today.  :)
Online mawyatt
« Reply #49 on: August 06, 2021, 08:14:25 pm »
Good news :-+
Ours is due tomorrow :)
Best,
