Author Topic: Siglent SDS800X HD 12 bit DSO's  (Read 1212773 times)
0 Members and 64 Guests are viewing this topic.
Offline Furna
  • I still don't know
Re: Siglent SDS800X HD 12 bit DSO's
« Reply #1625 on: July 28, 2024, 04:37:34 pm »
Oops -- why is your UBoot at 3.8.12 rather than 2.8.12? What exact scope model do you have? (I assume the anti-aliased font is just due to switching to large font size?)
SDS824X HD bougth form Welectron  beginning of June 2024  ... I really have no idea what was the version before I updated the software
Yes the anti-aliased font is just the result of switching to large font size ... now you all know that I am an old guy  :)
I know for previous scopes they had a separate update for the OS (UBoot).
UBoot is not an OS ... it is a bootloader that in turn loads the OS
https://en.wikipedia.org/wiki/Das_U-Boot
Doesn't the UBoot version coincide with the OS version on the Siglent scope? I could be wrong, I was assuming. 🤷
While looking again at the image I realized that Siglent does not distinguish between the bootloader and the "OS" ... so sorry KungFuJosh.
« Last Edit: July 28, 2024, 04:45:42 pm by Furna »
The sky above the port was the color of television, tuned to a dead channel.
Offline Furna
« Reply #1626 on: July 31, 2024, 03:48:52 pm »
AFAIK, Sigrok is not really actively developed and I don't think there is support for 2000X+ or any of the 12 bit scopes that support 16bit data format (v4).
If I'm wrong I would like to be corrected...
https://www.eevblog.com/forum/testgear/new-sigrokpulseview-hardware-support-(siglent-sds-hd-rigol-dho800-)/
Looks like someone is doing something  ;)
Let's see what can be achieved.
Currently I am able to perform a basic acquisition ... need to setup some multi channel acquisition and get used to the scope as well; with limited time available.
« Last Edit: July 31, 2024, 03:51:29 pm by Furna »
Offline Furna
« Reply #1627 on: August 02, 2024, 09:38:46 pm »
At the end of April in EEVblog 1612, Dave teared down the SDS1000X HD; during that video we learnrd he also received an SDS824X HD.
Does anyone know if a tear down/review of the SDS824X HD is on schedule?
Thank you.
Offline tautechTopic starter
« Reply #1628 on: August 02, 2024, 09:44:29 pm »
Already done by Defpom:
Avid Rabid Hobbyist
Offline TomKatt
  • Electro-BOOMER
« Reply #1629 on: August 02, 2024, 10:14:59 pm »
Not quite the same…. He seemed a bit nervous to dive deep…
I was half curious if the SDS800X shared the SDS1000X HD platform…. Same processor?  Front end?
I’m surprised Dave hasn’t done a SDS800X HD / DHO800 comparison.
« Last Edit: August 02, 2024, 10:16:58 pm by TomKatt »
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
« Reply #1630 on: August 02, 2024, 10:31:50 pm »
And thankfully so when it's my unit !  :P
No 50 Ohm inputs in SDS800X HD.
Avid Rabid Hobbyist
Offline nanopico
« Reply #1631 on: August 04, 2024, 06:53:38 pm »
Defpom's review is very useful, he convinced me to buy - maybe Siglent (via @tautech) will send him a small gift.
On the other hand, every review made by Dave has a special charm. I've also been waiting for a while.
If his SDS800X wasn't lost or stolen :) , I'm still waiting to see a presentation.
The next milestone after the successful SDS1000X-E series, for all the ones on a budget who are serious about electronics T&M.
Performa01 made a thorough professional analysis of the operation of the SDS800X HD oscilloscope.
https://www.eevblog.com/forum/testgear/sds800x-hd-review-demonstration-thread/msg5293741/#msg5293741
The following users thanked this post: CastleCustodain
Online tszaboo
« Reply #1632 on: August 09, 2024, 04:15:45 pm »
So I have a question. I'm trying to do a noise measurement, determine the RMS noise of something, I do not with to AC couple. I enable measurement and add RMS, that's going to say that my RMS is 3.3V, and doesn't tell me the noise. Cycle RMS neither because my noise isn't periodic. So what's the measurement that I should use?
Online ebastler
« Reply #1633 on: August 09, 2024, 05:36:54 pm »
Siglent uses the mathematical term, StdDev, if I recall correctly. RMS, as you have observed, includes the DC component.
The following users thanked this post: Performa01, tszaboo, 2N3055
Online tszaboo
« Reply #1634 on: August 09, 2024, 06:10:08 pm »
Thanks, that does the trick.
Offline Unity
« Reply #1635 on: August 21, 2024, 12:23:26 am »
I've decided to solve the tempered glass screen protector question once and for all. I did some research which 7" tablets have similar screen size and came up with the list:
- Amazon Fire 7 (ruled out because of the camera cut out)
- Nintendo Switch OLED 7", 2021
- SteamDeck 7", 2021/22 & OLED 2023
- Asus ROG Ally 7", 2023
Ordered all on Amazon, they were cheap, like 10 bucks for a 3 pack. Here's the results (sorry for dark photos):
Nintendo Switch: Can be aligned to have same margins around the visible screen (LCD).
Steam Deck: Leaves 2 bands on the top and bottom. It is spot on on the sides, completely covers on the left & right.
Asus ROG Ally: Can be aligned to have same margins to the edge of the screen border.
Which one do you prefer?
I went with the "- SteamDeck 7", 2021/22 & OLED 2023" option and I'm happy. I also picked up a wireless mouse, thanks.
The following users thanked this post: EvgenyG
Offline Furna
« Reply #1636 on: August 30, 2024, 05:35:43 pm »
On a friday evening for an unknown reason, I decided to look at my power supply and his ripple/noise.
PSU: 15V 1.5A connected to 10Ω resistance LPR100 10RJ https://www.ohmite.com/assets/docs/LPR-01-33-002.pdf
Probe setup: Cal Test/ELDITEST GE2501 - fixed 1X 55MHz https://www.caltestelectronics.com/product/GE2501 https://as.caltestelectronics.com/public/attachments/GE_series_manual.pdf
2355933-0
PSU channel switched off
2355937-1
PSU channel switched on
2355941-2
Any idea how to reduce the noise? Am I doing something wrong? Will poor man differential probe help??
Online ebastler
« Reply #1637 on: August 30, 2024, 06:10:10 pm »
What are the long red and black probe leads for -- connecting the load resistor? Does it make a difference if you use a very short connection instead (or remove those leads if they are for some other purpose)?
Does it make a difference if you disconnect the whole adapter & probe arrangement from the power supply? (I.e. does the noise actually come from the power supply?)
The following users thanked this post: Furna
Offline Martin72
« Reply #1638 on: August 30, 2024, 06:26:15 pm »
I measure ripple with a capacitor directly at the BNC input of the scope and twisted wire to the power supply, its output.
If this is not available, you can try average, 16x for example.
The following users thanked this post: KungFuJosh, Furna
Offline Furna
« Reply #1639 on: August 30, 2024, 07:18:18 pm »
Correct, the red and black leads connect the resistor ...
Image with whole adapter disconnected (note the V/div change)
2355999-0
If I switch on the PWM led light on the desk
2356003-1
So the noise is coming from the environmet; I am aware the noise is not coming from the PSU.
I already tried to find the source of the noise without luck and cannot "investigate" further about the environment.
I can calculate the PSU noise/ripple using the cursors whit PSU channel on and off ...
The question is: are you aware of some settings or probing technique that can help here?
I already tried Trigger Noise Reject.
The goal? Have the scope calculate correctly Pk_Pk and RMS
Thank you
Offline KungFuJosh
  • TEAS is real.
« Reply #1640 on: August 30, 2024, 07:39:58 pm »
As Martin suggested, try Averaging.
Best Continuity Tester Ever
« Reply #1641 on: August 30, 2024, 07:55:11 pm »
This is your best screenshot of PSU noise plus environment noise.
Look past the blur and at the deeper trace color.
Just what the repetitive spikes are is another question.  :-//
I will say from experience, trying to measure ripple on a PSU rated at 300uV max ripple and noise is not a trivial task.  :scared:
However Siglent have a specialized power rail probe coming soon but unfortunately it will be beyond the budget of most except professional users.
Avid Rabid Hobbyist
Offline Furna
« Reply #1642 on: August 30, 2024, 08:28:39 pm »
Will start to think about that ... do you have a picture that you can share maybe?
Will do ...
You mean cursors like this?
2356009-0
Thank you all!!
Offline BillyO
« Reply #1643 on: August 30, 2024, 08:29:36 pm »
I have a magnifier lamp in my lab that creates noise like that. Just a really cruddy power supply in it.  If you have anything like LED lighting or things powered by SMPS wall warts, try shutting them off until the noise disappears.
« Last Edit: August 30, 2024, 08:38:22 pm by BillyO »
Bill
The following users thanked this post: tautech, Furna
Offline Furna
« Reply #1644 on: August 30, 2024, 08:37:16 pm »
I have a magnifier lamp in my lab that creates noisE like that. Just a really cruddy power supply in it.  If you have anything like LED lighting or thing powered by SMPS wall warts, try shutting them off until the noise disappears.
Tried already to switch off/ disconnect almost evrything in the room, including the PC.
I guess I have to live with that noise ...
Thank you for your suggestion anyway.
« Reply #1645 on: August 30, 2024, 08:42:50 pm »
I have a magnifier lamp in my lab that creates noisE like that. Just a really cruddy power supply in it.  If you have anything like LED lighting or thing powered by SMPS wall warts, try shutting them all off until the noise disappears.
FTFY  :P
Yup, this in spades.
I have 1 room in the house with 10 LED downlights and 10'/3m high ceilings where one must be very careful when attempting any sensitive scope measurements however I now know where those 10+kHz spikes come from whenever they rear their heads.  :horse:
Avid Rabid Hobbyist
« Reply #1646 on: August 30, 2024, 08:44:53 pm »
Yup, good work.  :-+
Avid Rabid Hobbyist
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #1647 on: August 30, 2024, 09:02:13 pm »
Prior to them becoming contraband in the United States, I hoarded several cases of incandescent bulbs for use in my lab / ham radio shack, precisely because of the absolutely awful RF noise created by many household LED bulbs.
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline KungFuJosh
  • TEAS is real.
« Reply #1648 on: August 30, 2024, 09:31:38 pm »
Doesn't have to be the same room. I've spent insane amounts of time searching for the causes of spikes or parasitics that turned out to be power supplies on the other side of my house.
The following users thanked this post: pdenisowski
Offline Martin72
« Reply #1649 on: August 30, 2024, 09:37:45 pm »
Have you tried my tip?
