Author Topic: software for HP-33120A generator ?  (Read 4807 times)
Offline peterpTopic starter
« on: May 23, 2019, 05:58:57 pm »
Hi all,
I've checked that the HP34811A BenchLink Arb software for this generator is no longer available. Are there newer
versions of HP (or other) software that can be used with the 33120A ?
Offline chronos42
Re: software for HP-33120A generator ?
« Reply #1 on: May 23, 2019, 06:26:32 pm »
Do you mean 34811a or 33120a?
And for which operation system?
For windows I use this softwarebundle with my hp 33120a:
A software, called: "FuncGen_25Aug_a.exe". This is the main install software package.
You also need the agilent/keysight IOLibSuite with an Agilent USB-GPIB Converter or a NI card with the NI driver. (I am not sure what is necessary for communicatian via serial link)
Further there is a plugin for pulses, "WFE_PulseAddin and a pattern editor called PatternEditorInstall_4.0msi".
This sofware is rather old, but is still working, even with the latest Windows 10 64bit version.
« Reply #2 on: May 23, 2019, 07:23:04 pm »
Thanks for the info.
I think the 34811a refers to the software that is no longer available.
I googled "FuncGen_25Aug_a.exe" ... is it part of the IntuiLink Waveform Editor ?
Offline chronos42
« Reply #3 on: May 23, 2019, 07:50:39 pm »
I am not 100% sure but I think it was indeed part of  IntuiLink Waveform Editor.
Offline james_s
« Reply #4 on: January 31, 2020, 03:49:54 am »
I realize this thread is quite old but does anybody have this software posted somewhere? I found one place that claims to have it but they require a credit card number, which is something I refuse to give any company I'm not buying something from.
Online jhenderson0107
    • Elk Engineering
The following users thanked this post: volvo_nut_v70, james_s
Offline icezebra
« Reply #6 on: January 05, 2022, 03:02:33 am »
Indeed.  Thank-you Jim
