Author Topic: Spectrum Analyzer - Rigol DSA815  (Read 882556 times)
Offline hpux735
Re: Spectrum Analyzer - Rigol DSA815
« Reply #250 on: January 09, 2014, 03:22:03 pm »
I've attached the new firmware 00.01.08 (full name 00.01.08.00.03) dated 2013-12-02
Since this forum limits single file size to 1MB I had to split it using 7zip and change file extension. Remove .zip from file name - it should be DSA800(DSP)update_00.01.08.00.03 zip.001 and DSA800(DSP)update_00.01.08.00.03 zip.002
I've successfully upgraded my DSA using Storage->{select "Mobile disk"}->{select file DSA800_UpdateFile.sys}->Sys Update.
All licenses stayed intact (including those added using keygen) and are functioning correctly. The biggest change is additional languages added.
Thanks for the heads-up!  Is there any reference to release notes anywhere?  Or do we just get to guess which bugs are fixed?
Offline Sparky
« Reply #251 on: January 09, 2014, 03:43:16 pm »
The download posted by Vtech includes a "Version Notes" document with details.
Offline Vtech
« Reply #252 on: January 09, 2014, 03:51:11 pm »
"Version Notes" document inside the zip is a bit Chinese (a lot actually) but the change list is the same as Pinkus posted earlier:
Version?00.01.08.00.03   Date?2013-12-02
1.      Solve the problem some spelling mistakes
2.      Temporary solution to the problem LXI communication is unstable.
3.      Increased multi-language support, including Portuguese,German,Polish,Korean and Japanese.
4.      Solve the problem marker table and PF don’t display correctly.
Offline Lunasix
« Reply #253 on: January 09, 2014, 04:00:03 pm »
Hello,
when I try to extract files with 7zip, I've got an error. I've made same treatment with other files without any error, I think there is an error in file 2 uploaded.
Offline Vtech
« Reply #254 on: January 09, 2014, 04:10:39 pm »
Have you changed the file extension? You have to remove the last .zip and leave only .zip.001 and .zip.002. I had to add it because of file type limitations on this forum. Other guys seems to have no problem extracting files.
I've added Rigol update instruction (again, because of the size limitation I had to convert it to b&w)
Offline Rory
« Reply #255 on: January 09, 2014, 04:11:14 pm »
Anybody with the option hack try this yet?
Offline Vtech
« Reply #256 on: January 09, 2014, 04:12:56 pm »
As I said earlier I've installed it over hacked DS815 and all hacked keys still work fine.
Offline Sparky
« Reply #257 on: January 09, 2014, 04:19:08 pm »
The problem is the file names are actually different (other than the simple 001 and 002), so the files cannot join successfully.
DSA800(DSP)update_00.01.08.00.03 zip.001.zip  << notice a missing '.' before the first 'zip'
DSA800(DSP)update_00.01.08.00.03.zip.002.zip
Make sure the filenames are identical other than the 001 and 002 on the end (remove the last .zip). I joined the files with HJsplit, and then unzip with WinZip works fine.
Offline Rory
« Reply #258 on: January 09, 2014, 04:19:48 pm »
Sorry, I came in on this from a link in a different thread and didn't see your earlier post. Thanks for repeating yourself for my benefit, I appreciate it.
Offline Lunasix
« Reply #259 on: January 09, 2014, 04:21:44 pm »
To Vtech : yes. As I didn't know it was possible to split a zip file, I made the test on another file (zip split and then unzip) to understand how to do. On my file, it works fine. I also tried to reload files from here, alwas with same result.
Offline Vtech
« Reply #260 on: January 09, 2014, 04:25:01 pm »
Damm... Sparky is rigth - "." was missing from the file name. Don't  know how it happened  :-// but I've fixed it.
Offline Lunasix
« Reply #261 on: January 09, 2014, 04:26:28 pm »
I've just seen the last Sparky's response, and obvious when we have seen it : the point on the name !!! :) It works fine now.
Thanks to all ! I try the upgrade.
« Last Edit: January 09, 2014, 04:28:41 pm by Lunasix »
Offline Vtech
« Reply #262 on: January 09, 2014, 04:34:04 pm »
Ok. Rapidshare should solve the problem:
http://rapidshare.com/share/5123813300A5B6F4E69F3035E5149BC5
Offline Lunasix
« Reply #263 on: January 09, 2014, 04:52:38 pm »
Split file is a good solution, and stays on the same server.
Upgrade is ok, no problem with options.
I had 04 version, made a request for 07, have rapidly a response from Rigol that my actual version was the latest (mistake request/actual) !
I made 2 other requests after this mistake, but no response !
EEV better than Rigol !!!
Thanks
« Last Edit: January 09, 2014, 04:57:32 pm by Lunasix »
Offline Lunasix
« Reply #264 on: January 09, 2014, 05:02:28 pm »
Apparently, the software found here RigolBildschirmkopieLAN seems to not work anymore after update. DSA change state to remote, but nothing happen.
« Last Edit: January 09, 2014, 05:04:11 pm by Lunasix »
Offline hammy
« Reply #265 on: January 09, 2014, 07:59:00 pm »
I had made the update from v1.07 to v1.08 without problems. The license keys stay valid.  :-+
Offline jstarr
« Reply #266 on: January 11, 2014, 06:07:33 am »
When generating keys with the 1.03c keygen do I use the "official" or timed first letter (of the 4 letter) option?
tia
john
Offline hammy
« Reply #267 on: January 11, 2014, 02:22:13 pm »
If you want keys for a limited time period you can use S = trial.
If the keys should be valid forever you can use A = official.
You can also use this website http://riglol.3owl.com
Offline EMC
« Reply #268 on: January 15, 2014, 05:59:25 am »
Would you mind providing comment on any improvements.   Any noticable change in the functions mentioned in the above change list?  Is communications in particular stable & reliable? Thanks.
Offline stormbr
  • Country: br
« Reply #269 on: January 18, 2014, 07:26:22 pm »
How to do for generate a signal of 200mhz in output of dsa815tg ?
I wanna test my oscilloscope (ds2072-hw2.0@300mhz).
Thanks
« Last Edit: January 18, 2014, 07:28:27 pm by stormbr »
Offline Rory
« Reply #270 on: January 18, 2014, 07:50:08 pm »
Zero span.
Offline stormbr
  • Country: br
« Reply #271 on: January 18, 2014, 07:58:47 pm »
Sorry, i'm a newbie with spectrum analyser, but can you explain detailed this for me ?
I'm use a adapter type n to bnc connected over "gen output" of dsa815tg and with ch1 of ds2072.
I press the button: span and option, span zero, digit the frequency with 200mhz, but nothing happens.
 :palm:
Offline Rory
« Reply #272 on: January 18, 2014, 08:05:53 pm »
Enable the tracking generator.  TG button lit, menu selection TG ON.
Offline stormbr
  • Country: br
« Reply #273 on: January 18, 2014, 08:21:00 pm »
Right now, the oscilloscope measured a signal/noise with 250mhz.
But i can't change the frequency to 50 mhz, for example.
Thanks a lot.
Edit:
Not have problem to change the frequency using the "freq" button and your menu.
The oscilloscope show me a perfect senoidal wave with 200mhz and 1.5ns of rise time.
« Last Edit: January 18, 2014, 08:43:53 pm by stormbr »
Offline fqahmad66
« Reply #274 on: April 02, 2014, 11:43:01 am »
I read it in mikrocontroller.net. when pressed in order..
TRACE> TG> MARKER FCTN> MEAS SETUP> SYSTEM> PRINT SETUP> STORAGE
a hidden item 'ph noise opt' is unabled in system menu. Somebody played with it?
Regards
F
