A couple of days ago, out of curiosity, and feeling somewhat adventurous after imbibing copious amounts of amber liquid seeing in the New Year (yeah-yeah... I know - alcohol and test equipment don't mix), I decided to try and update (or more correctly, downgrade) my machine back to firmware v1.09 from v1.12. Firmware v1.09 was the firmware I was having trouble updating to from v1.08, months ago. There was no way back then that I could get v1.09 to run, I tried everything; multiple USB sticks of various sizes formatted with FAT, FAT32, many, many times - the machine just refused to boot after updating; it would hang with the TG and Auto buttons illluminated, but would not go any further. My unit has bootloader v1.02.
I initially considered sending my analyzer back for a warranty repair thinking there may have been a problem with it, but then decided against that and chose to stick with firmware version v1.08 until a newer firmware became available, which is the current v1.12.
Surprisingly, downgrading from v1.12, I was able to install v1.09 via the operating system of the analyzer (the Rigol update procedure) and it booted up without any problem at all; there was no hangup at boot with the TG and Auto buttons being illuminated, like there was when I was updating from v1.08 to v1.09, or updating to v1.09 from any one of the earlier firmware revisions I have (v1.06, v1.07, and v1.08). Whatever was preventing v1.09 from being installed properly was cleared after updating to v1.12.
The tracking generator only goes down to -20dbm on my unit with FW v1.09, (as it always had with all the previous versions of firmware including the original v1.05) unlike the -30dbm some others on the forum can have with v1.09. I suspect there's an anomaly or bug in the v1.09 firmware that affects certain hardware combinations allowing dropping of the TG output level to -30dbm on some machines, which is probably why Rigol addressed that in firmware v1.12. Anyway, I have again updated to the latest FW 1.12 without any problem. The "Version of Digital Board FPGA" was updated to 00.05 with firmware v1.12, whereas it became 00.04 when I downgraded to FW v1.09.
Tom
Just to add, the TG default power level on the unit in question is -20dBm, I have to wind it down to -30dBm.
So Howard, do you think it might be related to the key used when hacking the SA? The DSA 832 and DSA 875 allow the value to go down to
-30 and -40 dBm
respectively, so it is likely available to the DSA 815 if we just knew how to hack it.
Len
EDIT: Both the 832 and 875 go down to -40dBm
So Howard, do you think it might be related to the key used when hacking the SA? The DSA 832 and DSA 875 allow the value to go down to -30 and -40 dBm respectively, so it is likely available to the DSA 815 if we just knew how to hack it.
Len
The unit I'm familiar with is recent, and was shipped with a bootloader and firmware which doesn't work with the keys currently generated by Riglol etc.
Hi all, this is my first post on the forum, recently i bought the DSA815 TG and it was installed with the Firmware 00.01.09 and this evening i have successful updated the latest firmware 00.01.12
Does anyone happen to update to this version and do you know what was added or fixed please.
Thanks
tom d
what boot-loader version does your machine have ?
tom d
Mine is an earlier machine with v1.02.
If you go back a page, Pinkus has listed the features/fixes in Reply #398.
Tom
Hi Tom D, many thanks for your prompt reply and also your help regarding the early post by pinkus which i missed as i said i am a newbie.
Looks like they made some good changes, i have bought the dsa815 just 10 days ago so i am still learning.
Here please find attached two pics of the shipped version and now with the latest firmware and you can notice what was changed.
Kind Regards
Ray
Hello, Ray, welcome to the EEVblog forum. I see that your "Version of Main Board" is 00.08, which makes me wonder if the hardware in these newer DSA 815 units is shared with the DSA 832.
Tom
Hello Tom D, well i dont know if this could be possible, although it always could be with some sort of software related ....
I am waiting to receive also the VB1020 VSWR kit which i ordered 2 days ago. It should be a great add on for my shack workshop.
I want to thank all contributors to this great informative forum, as i am finding a lot of useful information.
please could anybody post a download-link for the new firmware?
thanks Karsten
This is the latest Firmware upgrade ( Firmware 00.01.12) for the 815 tg, however i am no responsible for any damage cause with this upgrade for your unit.
I am saying this cause not all 815's board versions might take this update.
This update firmware was sent to me by Regol for my latest version of 815.
My main board version is 00.08
Hope this helps
https://www.dropbox.com/s/t5wprax8wmyuyr3/DSA815(DSP)update_00.01.12.00.02.zip?dl=0
Hi Ray
thanks very much. I will give it a try.
My Boardversion is 00.04 with SN is DSA8A1616..... which tell that it is build in 16.th week of 2014!
There is a remarkable jump to 00.08 in the last past month of 2014.
Karsten
Welcome Karsten, i hope it will work well, please keep us posted
Good that I can move backwards and forwards between 1.09 and 1.12 if necessary.
The re-writing of the FRAM time parameter appears to still work under 1.12, but I don't know about the other option of simply enabling the WP pin. ( https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg572507/#msg572507 )
As expected the TG minimum is -20dBm under 1.12, but if I regress back to 1.09 I can still choose -30dBm on the example hardware I have here.
It would be interesting to compare the two load images to figure out which memory location controls the TG level. Then it could be re-written with the old value (and would then probably need a checksum re-calc...). This might even be a way to hack it to -40dBm like the 832 and 875 units. It would be really cool to get it to be a DSA 832! I wonder if it is the same board and components...
Ray, for information
update 1.12 with your downloadlink is working well. Altough there seems to be a significant change in the mainboards between rev 00.04 to 00.07 and the newest 00.08:
my noisefloor (full span, conds same as posted from Howardlong) is only by -50 dB !!!
Are there any other guys with a new DSA815 (board rev. 07 or 08) who can tell us the same low noise level?
Karsten
Karsten, i am glad you succeeded and its working well....
Karsten
I have recently bought a DSA815-TG, main board is v00.07, on FW 1.09 the TG will go down to -30dB, the noise floor looks pretty good too.
Hi Gents, this evening i just received the VB1020 kit and the full software key.
I will post some updates later how i find it to work
Just updated the licence key .....
My DSA815-TG came with 1.09 and the 1.04 bootloader. The tracking generator will go down to -30dBm, and my noise floor looks just like Howardlong's.
I'm interested to hear about the VB1020. It has been sitting in my cart at tequipment, but I can't bring myself to pull the trigger when the price is so steep and I could probably just buy the minicircuits directional coupler + short the WP pin on the FRAM to keep the demo options.
I've been really happy with my minicircuits directional coupler. Just saying.
also, the math for swr and return loss is trivial.
I made one of the VK3DIP return loss bridges, he has several variations that go up to around 3 GHz. The cost is peanuts. Mine is good to 1 GHz and usable to 1.5, I used type 43 binocular cores and RG110 coax. The cores were £2 for 5... I certainly wouldn't shell out for the Rigol RLB kit.
Solder
Would you mind posting some inks to where you purchased the parts? I mainly am concerned with the housing and the beads /cores
Thanks in advance
I've been really happy with my minicircuits directional coupler. Just saying. also, the math for swr and return loss is trivial.
I too have been very happy with the Minicircuits ZFDC-20-5+. I've also become accustomed to working with Return Loss in preference to VSWR and not using the VSWR menu at all.
The article mine is based on is:
http://www.yagicad.com/Projects/ARRLB.htmThe housing is a Hammond diecast box type 1590A, external size 93mm long by 39mm wide, 31mm high (inc lid). They are listed by several sellers on eBay.
The binocular cores are Amidon type BN43-202, for better UHF performance BN61-202 could be used. My interest is mainly HF, for which the 43 type is ideal.
The '43 cores are listed on eBay, both types are available from the G QRP Club (members only).
