What are you hiding in those HP cases?
And I bought another HP 3400A fairly recently too, it's slightly more unusual from the outside, with the front output option and a 50 ohm decibel scale, from a message on the groups.io HPAK group I've been told it was probably an option H02-3400A made for the military, the option label is long gone, as was the original chopper board & panel meter.
A note for Dazz & others with these, the older ones use Ge transistors for the power supply & pass transistors, sometimes with previous repairs they get changed to Si parts without the full modifications, this causes incorrect supply voltages.
