Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 37001083 times)
djadeski and 1546 Guests are viewing this topic.
Offline tautech
« Reply #37750 on: August 30, 2019, 01:55:50 pm »
The only rusty equipment I've ever seen is Tek.  :P
Avid Rabid Hobbyist
« Reply #37751 on: August 30, 2019, 01:58:57 pm »
I bought a Mastech power supply from Rapid once and it was rusty when new  :palm:
Offline Mr. Scram
  • Display aficionado
« Reply #37752 on: August 30, 2019, 02:05:36 pm »
Doing your business blindfolded is quite a feat.
« Reply #37753 on: August 30, 2019, 02:10:16 pm »
Interesting video  :-DD
« Reply #37754 on: August 30, 2019, 02:25:59 pm »
The trousers! OMG, the trousers!
Offline Kosmic
« Reply #37755 on: August 30, 2019, 02:27:39 pm »
Wonder if she tested the cap before powering the device. ESR was probably really high.
Offline Mr. Scram
« Reply #37756 on: August 30, 2019, 02:30:40 pm »
I was wondering about that “without warning” too.
« Reply #37757 on: August 30, 2019, 02:36:33 pm »
There were definitely several warnings but they went unmeasured and unheeded.
« Reply #37758 on: August 30, 2019, 03:00:06 pm »
Now that was a dumbass move.  :palm: He's lucky. Was going to work on the 485 this morning but got a frantic phone call because someone's computer is all jammed up. Not the first time and I'm certain won't be the last. Through the wonders of Teamviewer I'm in the process of unfucking it. You'd be flabbergasted to know who this person is. More later.
In the meantime I did determine that the slope switch is hopelessly jammed. But won't you know it the 465B uses same value slope/level assembly. So I harvested one out of my 465B parts mule. And of course the shaft was slightly bent....they all get whacked....but I was able to straighten it out. Now I just have to wire it in and mount it, after I get done playing Mr. Computer Fix-it.  :-DD
« Reply #37759 on: August 30, 2019, 03:03:08 pm »
I haven't.  :-//
« Reply #37760 on: August 30, 2019, 03:15:53 pm »
Got cheaper - £5.60 in the end from Rapid inc delivery.
Are you sure it's correct? I'm asking because the eBay one has 6 pins and Rapid one is only 4 pins?
Sent from my POT-LX1 using Tapatalk
Offline BravoV
  • +++ ATH1
« Reply #37761 on: August 30, 2019, 03:16:44 pm »
I haven't.  :-//
Mine ... 2465B, though its fixed now with new nuts.
« Last Edit: August 30, 2019, 03:18:20 pm by BravoV »
« Reply #37762 on: August 30, 2019, 03:25:47 pm »
"Memo to self: do not become a voltnut."
I explicitly tried that technique, with insufficient success :(
In my case some functional 70yo saturated Weston Cells were the gateway to hell.
I know; I was quoting YOU. From that exact article. :-DD
I was wondering about that "without warning" too.
"I don't think so, Tim!"  :-DD
« Last Edit: August 30, 2019, 03:29:12 pm by mnementh »
« Reply #37763 on: August 30, 2019, 03:27:15 pm »
Haha, been there many years ago and that was on an old valve(TUBE) amplifier and that was a big old bastard.
« Reply #37764 on: August 30, 2019, 03:35:43 pm »
"More power!"
« Reply #37765 on: August 30, 2019, 03:38:38 pm »
"Waugh... Waugh... Waugh!!!"
"Arrrou...?"
« Reply #37766 on: August 30, 2019, 03:41:38 pm »
The following users thanked this post: med6753, mnementh, Black Phoenix
« Reply #37767 on: August 30, 2019, 03:45:46 pm »
In all honesty, pretty sure a quick check with with a DMM would've spotted that; I can about guarantee that cap had low DCR. 100% PEBWAC error.  ;)
 :popcorn:
« Reply #37768 on: August 30, 2019, 03:53:06 pm »
I THINK this is all of them in one long "Uurrrrk...!"
*cringe*
« Last Edit: August 30, 2019, 03:58:22 pm by mnementh »
« Reply #37769 on: August 30, 2019, 03:56:18 pm »
Yeah only the rear 4 are used in the scope. DPST is needed but the one in it is a DPDT with 2 pins not connected.
« Reply #37770 on: August 30, 2019, 03:59:48 pm »
Does it use the extra pins as anchor points for strength, or is the crossbar actually screwed to something?
 :bullshit:
« Reply #37771 on: August 30, 2019, 04:06:20 pm »
Bar is screwed down so I'm not too worried about losing the extra two pins.
Mount is as follows:
As you can see from the switch, the flange that holds the spring on has broken off and the latching pin has gone AWOL (probably what blew the scope up to start with!).
I'm not convinced HP's idea to screw a standoff onto the shaft was a great idea (the 18 inch long power switch screws into that)
« Reply #37772 on: August 30, 2019, 04:27:06 pm »
Some of those, the last loop of the compression spring itself retains the ratchet pawl, like on this one. I'm thinking the clip that retains the other end of the spring went south. Actually, are you sure that's original? Something about what I'm seeing there around that re-purposed standoff feels pretty ghetto-fab... like maybe a custom bit of plastic on the end of the pushrod wire went south, so somebody used that standoff as a substitute.   :-// I just can't see HP designing with that chunk of metal so close to live points on the PCB.
 :-BROKE
« Last Edit: August 30, 2019, 04:38:02 pm by mnementh »
« Reply #37773 on: August 30, 2019, 04:44:18 pm »
That was what it looked like before it broke.
It's definitely the original as there are no signs of flux around it. Also it's documented in the service manual that's how it's put together.
HP 3478A has the same switch but uses a plastic bar.
Offline Mr. Scram
« Reply #37774 on: August 30, 2019, 04:51:41 pm »
Farnell is being ridiculous. I’ve found a part in the right category and want to look at more so I click one level up in the “directory path”. Page not found. Another level up. Page not found. This is basic stuff Farnell.
