Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 37099972 times)
dxl and 5268 Guests are viewing this topic.
« Reply #74025 on: November 03, 2020, 06:38:32 pm »
Nice job on that by the way. And at least it’ll keep you warm this winter  :-DD
« Reply #74026 on: November 03, 2020, 06:42:38 pm »
   So, Mr incredible... How long before this little hollow-state world needs saving again...?  :-DD
 >:D
You talking to me?  :-// :-//
Yes... maybe this will clarify. ;)
 :clap:
Well, we shall see. It's on the torture rack for many hours of burn-in. And it has already demonstrated some reliability after the HV fix and has over 8 hours on it. But this little guy does run HOT.  :o So once the fan base is restored it will go up on it.
Good plan.  :-+
Keep the faith, buddy. ;)
« Reply #74027 on: November 03, 2020, 06:42:40 pm »
Thanks.  :-+
Yea, between this little guy and the Type 535A I'll never be chilly.  :-DD
Offline tautech
« Reply #74028 on: November 03, 2020, 07:01:02 pm »
Thanks.  :-+
Triple nickel coming anytime soon Med ?
Avid Rabid Hobbyist
« Reply #74029 on: November 03, 2020, 07:07:15 pm »
Thanks.  :-+
That would be the ultimate boat anchor and heater, wouldn't it?  :-DD
As much as I'd love to own a Type 555 and fuss over it I got no room unless I move.  :scared:
« Reply #74030 on: November 03, 2020, 07:08:27 pm »
Dunno if med could afford the 'lectric bill with all 3 of them...
tzzt.
« Reply #74031 on: November 03, 2020, 07:09:26 pm »
I’d be more worried about his outlets catching fire  :-DD
BTW Good luck to our American friends over the next 24 hours. We’re all in the shit with you here  :-DD
Offline tautech
« Reply #74032 on: November 03, 2020, 07:11:11 pm »
Thanks.  :-+
Still, that would be the crowning glory right ?
If anyone should have one I can think of no other more deserving that would properly restore it.
You would find room for it.
Avid Rabid Hobbyist
« Reply #74033 on: November 03, 2020, 07:17:36 pm »
Maybe I'll buy a big bag of cheap AD811s from China; maybe I'll look for a cheaper and/or more durable alternative part.  :-//
You know perfectly well that if you do that, you'll receive a big bag of reject LM741s marked as AD811s, or worse...
You mean like these...?  :-DD
https://www.ebay.com/itm/1-pieces-AD811AN-High-Performance-Video-Op-Amp-AD811-/120762845943
Heh. Imagine that.
« Last Edit: November 03, 2020, 07:21:59 pm by mnementh »
« Reply #74034 on: November 03, 2020, 07:18:08 pm »
Yes, with all the power hungry boat anchors here I have to be aware and careful and practice good power management because bench 1 and 2 are all on the same 15 amp circuit.   :o
« Reply #74035 on: November 03, 2020, 07:18:53 pm »
Heh. Imagine that.
[/quote]
Oh those look dodgy as hell. Just the different images and labelling between photos says it all.
Edit: yeah I know the quoting is fucked on this post. I don’t care any more  :-DD
« Reply #74036 on: November 03, 2020, 07:23:45 pm »
Well duck you too... I was busy fixing it, ya big spooty-head!  :-DD
 :popcorn:
« Last Edit: November 03, 2020, 07:26:46 pm by mnementh »
Offline Saskia
« Reply #74037 on: November 03, 2020, 07:29:49 pm »
finally done something productive today.
- revived a C246 workstation board (Fujitsu enhanced temperature range blablabla ...), it's passing self test now with 32GB mem, a 9400F, NVME SSD and a GTX1660 (only card I had floating around which I could power with a reasonable power supply.
Turned out that the Quadro that was originally in there had a nasty short.
- revived my mini itx enhanced temperature range industrial board which I had cannibalized to revive the C246 board ...
Both are working now.
The following users thanked this post: Zucca, bd139
« Reply #74038 on: November 03, 2020, 07:34:07 pm »
Heh. Imagine that.
Yeah... like the crappy 64DPI laser-etching and double Pin1 indent wasn't a dead giveaway; they had to post an additional silk-screen printed "alt" part.  :palm:
punter.
Offline Saskia
« Reply #74039 on: November 03, 2020, 07:43:42 pm »
waiting for my MSO cable to arrive.
« Reply #74040 on: November 03, 2020, 08:12:15 pm »
am thinking a democratic republic is not worth the trouble.  a dictatorship would save me a lot of time standing in lines.
One of the things that changed immediately when Pinochet took over in Chile 1973, apart from people being disappeared, tortured and shot, was that the food stores overflowed -- apparently there had been some coördinated stock piling going on, to prove the point of dictatorship. The Allende era concept of "las colas", the queues, vanished overnight. Much rejoicing, if you weren't being suspended from your private parts while waiting to be shot.
However, as the initial surge of purchaseable goods faded, waiting together with other people for the chance to ask about a disappeared relative or to get the chance of buying something sort of resurfaced, but not in the unruly proletariat form of "las colas".
No, in a dictatorship queues are transformed into formation, "las filas".
Today, no Chilean resident uses "colas", the Newspeak "filas" has taken over completely.
So, I'm afraid that either way you're turning, your frozen butt points backwards. In line.
« Reply #74041 on: November 03, 2020, 08:23:17 pm »
Sondermüll - presumably leaning on the umlaut to give it that vomitory stress.
Most certainly just so.
« Reply #74042 on: November 03, 2020, 10:26:54 pm »
Compensation adjustments on the Type 310A. Set up with the Heath IG-4244 Scope Calibrator. The adjustments fell right into place quickly and with minimal interactions between ranges unlike some scopes where the adjustments are real fiddly. Sample result on screen. Nice square corner.
So......Sweep timing was dead nuts.
Trigger just needed a tweak.
Calibrator output dead nuts.
Vertical gain: This is where the pot twist monkey spend all his time. Now calibrated.
Compensation done. This project is now complete.
And just for fun. 1MHz square wave. For a scope with 4MHz bandwidth that is not too shabby.  :-+
I have a question:
How does the illumination of the grid work?
I looked for some kind of a light source but wasn't able to find one.
Thanks for an explanation.   :)
« Last Edit: November 03, 2020, 10:45:12 pm by BU508A »
« Reply #74043 on: November 03, 2020, 10:29:10 pm »
Think it’s on fire inside  :-DD
The following users thanked this post: BU508A, mnementh, Specmaster, shakalnokturn
« Reply #74044 on: November 03, 2020, 10:37:53 pm »
So let me get this straight... all y'alls think that all these posts talking aboot not talking aboot religion are somehow not in their own right also talking aboot religion...?  :o
Stop being so fucking logical Mr Spock.  :P :-DD
No pointy ears.
No fancy demonic looking eyebrows.
Naaa, mnem is far away from being a vulcanian.   ;D
« Reply #74045 on: November 03, 2020, 10:43:54 pm »
A hot scope for a hot boy smurf you mean?
 :-DD  :-DD  :-DD
« Reply #74046 on: November 03, 2020, 10:53:18 pm »
LMAO  :-DD :-DD :-DD
« Reply #74047 on: November 03, 2020, 11:12:52 pm »
« Last Edit: November 03, 2020, 11:16:55 pm by mnementh »
Offline VK5RC
« Reply #74048 on: November 03, 2020, 11:48:45 pm »
I was just thinking, more of this 5xx Tek burn ins and we will have no hope re global warming! (not really)
« Reply #74049 on: November 04, 2020, 12:04:42 am »
 :-DD  :-DD  :-DD
Well I see the comedians are at it again.  :P :D But in a way it IS on fire inside with all those vacuum tubes packed in like sardines in a can.  :o
But anyway....to answer the BURNING question concerning the screen illumination. All it is are two #47 lamps with a plastic grid over the front of the CRT with a bezel to hold it in place. Nothing fancy or unusual.
The following users thanked this post: BU508A, Specmaster, bd139, tonyalbus
