Not in Oz, it wasn't, both "B+boost" in tube designs & overwinds on solid state EHT trans were more common than any other way of doing things.
I should have been more specific. I was referring to vintage vacuum tube designs. Yes, some did have an extra B+ Boosted supply originating from the flyback. If I recall that became somewhat necessary when TV's started going cheap by employing series string and elimination of the power transformer.
Now when TV's started going solid state all bets were off. All sorts of creative designs were employed.
North American and 220/240V countries differed greatly in their approch to valve / tube TV design. In NA they typically had a mains trandformer supplying different voltages. In the UK at least thwy were transformerless designs with a "hot" chassis connected to mains, Filaments in trings with dropper resistors in series and multiple voltages generated from the flyback transformer. They were a significant hazrd to work on
Most of the few US TVs I ran across were transformerless, but the overwhelming majority of Australian ones used power transformers,
and B+boost supplies.
There were a number of reasons for transformer type supplies.
(1) Transformers were already made in large numbers for radios & other equipment.
(2) Valves (tubes) were most commonly made in this country with 6 v or 12 v heaters, the additional cost of producing wholly new types locally for "series string" heater supplies was not justified, & imported ones were expensive.
(3) Series string heaters are not as simple for 240v supplies as they are for 120 v---UK sets had various resistive methods of dropping voltages to use a reasonable number of heater voltage types.
(4)TV was introduced later than other countries, so, initially, most of the sets were used in major cities which already used 240/250v ac Mains supply.
As TV services were rolled out, communities using DC supplies were often also in the throes of conversion to ac Mains, so there was only a small requirement for AC/DC TV sets.
DC to AC converters were available, which were electromechanical devices using a very large 50 Hz "vibrator" (in effect, a larger version of the power supplies used in car radios).
These allowed the use of a standard ac TV on DC Mains.
Some were made for 240v/240v use, but most were either for 110v/240, or, in very large numbers, for use with 32v DC farm lighting plants.
