Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36309444 times)
factory, Vince and 1896 Guests are viewing this topic.
« Reply #82425 on: February 13, 2021, 05:06:30 pm »
Printers, grrr bloody laser printer printed out 6 pages perfectly, had a paper jam, now printing thick black horizontal lines 10mm thick every 30 mm down the page so an A4 sheet gets 8 of these bloody lines per sheet. Give me an ink jet every time  |O
What's the page count on it? Sounds like the drum is fucked.
« Reply #82426 on: February 13, 2021, 05:09:29 pm »
Nope, it's a new one
« Reply #82427 on: February 13, 2021, 05:11:42 pm »
Was it Tesco paper? That stuff'd fuck your mother if you put it near her.
I use the xerox 80gsm stuff off amazon
Offline Kosmic
« Reply #82428 on: February 13, 2021, 05:12:05 pm »
Got a new toy for the stack of soldering equipment: It's the cheapest of the whole stack, anyway a few tests showed it does the job. As it's rather seldom used, I'm happy with it for now.
I've one of those too, labelled ZD-915. Been using it for years without a problem. Just be careful to make sure the nozzle is solder-free before it cools down and clean the glass chamber regularly.
McBryce.
Little trick for those desoldering iron. My cheap S-993A had developed a problem where it was getting clogged all the time. So I tried using Mig nozzle gel inside the tube of the desoldering iron. Ideally you want the gel inside the tube and not at the tip. Never had any problem after that. The gel work at hight temperature and prevent solder to stick to metal.
« Last Edit: February 13, 2021, 05:17:36 pm by Kosmic »
The following users thanked this post: BU508A, Specmaster, Mortymore
Offline Saskia
« Reply #82429 on: February 13, 2021, 05:35:52 pm »
Lubrication is everything  :-DD
The following users thanked this post: Specmaster, Kosmic
« Reply #82430 on: February 13, 2021, 05:46:44 pm »
Good tip. It seems a bit expensive to buy a big tin though. A bit of safety data sheet research shows composition to be 990-100% Petrolatum AKA Vaseline.
I'll try that first
Edit: This SDS https://cdn3.evostore.io/documents/fusion_us/fus_us_o_368_df731_16.pdf
Has a first aid measure for skin contact - Apply an emollient  :-DD :-DD :-DD
(Petrolatum is an emollient!)
« Last Edit: February 13, 2021, 05:51:04 pm by Robert763 »
Offline drussell
  • Hardcore Geek
« Reply #82431 on: February 13, 2021, 05:49:06 pm »
Well, obviously those of us with welders already have some around, but it's only like $5 for one of those 16 oz tubs.
« Reply #82432 on: February 13, 2021, 05:55:57 pm »
ON THE BENCH TONIGHT: 5Kg Boneless Pork Roast
Smeared in (I Can't Believe It's Not) butter & pan-seared & on a bed of carrots to get it in the roaster by noon. The usual seasoning rubs. I expect this to take 6-8 hours, so rest of veggies (aside from onions on top) will go in aboot the 3 hour mark so they don't just turn into a slurry.
Now to chop up some veggies; this will actually happen on the bench as our kitchen is so small there isn't room to lay them all out. Plus I can sit, which I need a break off my feet anyways.
 :-/O
The following users thanked this post: Specmaster, bd139, syau
« Reply #82433 on: February 13, 2021, 06:14:07 pm »
I’ve just eaten and I’m hungry again now  :-DD
« Reply #82434 on: February 13, 2021, 06:57:51 pm »
I made entrecôte slices, pepper sauce and the world's best potatoes. And as we sat down to eat my file server in colo decided to call it a day. Sometimes, having another machine around, with the IPMI commands to get a serial console documented, is a saturday night saver of considerable importance.
root@sada:~ # uptime
 7:52PM  up 16 mins, 1 user, load averages: 0.06, 0.14, 0.15
root@sada:~ #
It hands out iSCSI storage to the compute node nearby, so am currently restarting processes on the compute node to get them over the fact that their storage was ripped from under their feet.
Offline Ero-Shan
« Reply #82435 on: February 13, 2021, 06:59:18 pm »
Since they seem to be be highly regarded by some, here's another one. With a defective fan. Prime candidate for the fanless modification.
https://www.ebay.de/itm/HP-3456a-Digital-Multimeter/265045615362
No affiliations with the seller.
« Reply #82436 on: February 13, 2021, 07:05:03 pm »
As long as it's not a substitute for skill in proper preparation. ;)
The following users thanked this post: mnementh, Neomys Sapiens
« Reply #82437 on: February 13, 2021, 07:21:48 pm »
Well it is in the drum area, along with the drum there is a charge roller of 37.7 mm circumference, which must be the culprit as that is the spacing of the black lines and nothing else is that size. So thats the good news, the bad news is that they don't want anyone touching as there is no strip down information on the imaging unit, everything else on the dam printer has detailed exploded views and part numbers for everything  :palm: |O
« Reply #82438 on: February 13, 2021, 07:25:24 pm »
"Möglicherweise kein Versand nach Schweden"  :-[
« Reply #82439 on: February 13, 2021, 07:28:19 pm »
Can you run blank sheets through it until it stops? Crap solution but  :-//
« Reply #82440 on: February 13, 2021, 07:46:46 pm »
Nope, I have been printing a test page and those bloody lines are always there, I blame C for this, I think he started a thread about ink jets and then this happened. :-DD
« Reply #82441 on: February 13, 2021, 07:50:21 pm »
You'll just have to read between the lines.  :P :P :-DD
The following users thanked this post: Brumby, Specmaster, Neomys Sapiens, nixiefreqq, AVGresponding
Offline Zucca
  • EE meid in Itali
« Reply #82442 on: February 13, 2021, 07:59:50 pm »
No problem to reship it to you.
« Reply #82443 on: February 13, 2021, 08:00:43 pm »
..., I blame C for this, I think he started a thread about ink jets and then this happened. :-DD
[Fx] Shhhhnick!
« Reply #82444 on: February 13, 2021, 08:02:04 pm »
Good start to the day. My battery charger just blew up  >:(
Can anyone recommend something that will charge 12x AA NiMh cells independently?  Edit: might actually just charge them off a power supply at C/10  :-//
I've been using the 10-slot predecessor to this one from Tenergy for ~15 years:  https://www.amazon.ca/dp/B00ZYTX93M/
Similar ones all claiming independent channel charging:
https://www.amazon.ca/Battery-Charger-Display-Batteries-Individually/dp/B07NQ4V38T/
https://www.amazon.ca/EBL-Individual-Battery-Rechargeable-Batteries/dp/B01LVZY6TJ/
https://www.amazon.ca/EBL-Upgraded-Battery-Charger-Screen/dp/B08KXR6NJZ/
*juicy*
Offline Zucca
  • EE meid in Itali
« Reply #82445 on: February 13, 2021, 08:03:07 pm »
SOT23-5 with mark on top UK48.
Can't figure out what it is....
« Reply #82446 on: February 13, 2021, 08:08:17 pm »
Hey, I'm on Discord for a change and no one else is?  :wtf: :wtf: :wtf: :wtf:
Online PA0PBZ
« Reply #82447 on: February 13, 2021, 08:09:32 pm »
Give us some context, I don't think UK48 is a valid topmark
The following users thanked this post: vk6zgo
« Reply #82448 on: February 13, 2021, 08:11:51 pm »
I see the problem now. The shit is fucked.
« Reply #82449 on: February 13, 2021, 08:12:15 pm »
one of these is on the way to my fortress of solitude , but stuck at the big sorting center in harrisburg.
anyone have experience with them?
https://www.ebay.com/itm/HP363-RF-Power-Meter-50-to-0dBm-1M-10GHz-Attenuation-Value-for-Radio-Instrument/373290120533?hash=item56e9d33555:g:68UAAOSwPJRfkXo4
Oh lordy... just what I need. Another $50 power meter that needs one or two $80 attenuators to work in my application.
Bastard.  :-DD
*finger hovering over the BIN button anyways*
you are welcome.  (but i do prefer to be called "bastard freq" thank you) already had the attenuators for protecting a couple of spectrum analyzers.
Thank you, bastard-freqq.  :-DD
But I was able to resist; I realized that my existing RC-oriented RF meter is more than adequate, and task-specialized. I also have a number of appropriate 0-6GHz and 0-18 GHz SMA attens from Micro-Circiuts and INMET purchased for my previous RC-oriented RF meter in the trailer in BuffaloNY; I just can't make myself duplicate that largish expenditure at this point. :-\
*toddles off to do V-day card & flower shopping*
