Finally got my Advantest R6144 DC volt/current generator running after literally
years on the shelf...
I had to replace a bunch of missing parts removed by the previous owners repair attempts but it never worked right. So it sat on the shelf with the occasional half-hearted poke every year or so.
A poke here, a bodge wire there, etc etc and now it's alive!
BUT, it seems like I'm having an issue when generating less than about 1.6V though... As part of the repair process, I've checked
ALL the TTL chips, the range relays, vregs, transistors, etc etc (It was in a pretty sorry state when I got it...) but I am unable to properly test the opamps etc.
I replaced some of them 'just in case' as they were cheap to source locally, and I know the voltage reference is working too as it is rock solid when outputting higher voltages.
The only chip I am suspect of, the only chip I haven't replaced and can't actually test is an OP77GP opamp.
So, anyone got an OP77GP they don't need?
Seems the usual suppliers don't have them in DIP8 packages and I'm not keen on risking a blacktopped part from China.
Unfortunately it seems I haven't salvaged one of these yet so I'm coming up dry.
[EDIT] So it seems the OP177 is a higher spec part and I can get it off the shelf in Akihabara. Monday shipping is scheduled!
