-group-therapy-thread/?action=dlattach;attach=1758440;image)
This is the biggest piece that I brought back from my big TE hakl a few months back.
This DOES qualify as a boat anchor.... it's huge, it's cubical, and it's freaking heavy.
I am big guy and am very much used to my 30kg old Tek scopes... and this TE is significantly large and heavier than my Teks...
It's so big and heavy that at first I refused to take with me... but then when I had a closer look at it, I saw how cool it looked, oozes build quality inside out, show room condition inside, excellent nick outside, and a general purpose enough and with decent specs, that I could potentially use it.
So I didn't have the heart to leave it there, know the guy would scrap it soon.
It's still too big and heavy for me to contemplate using it.... but it's still nice enough that I am not in a hurry to get rid of it. I will take a few months to try to find it a good loving home.
In the mean time I am very excited and curious to see if I can get some life out of it, and see if I can get it working !
Would also help selling it as well...
So what is it then ?
It's a Ferisol P201A pulse generator. So it's French stuff, and was owned by the French army according to the plaque riveted to its side.
-group-therapy-thread/?action=dlattach;attach=1758464;image)
I can't find a service manual for this thing... if you do please share.
From the front panel, we can at least see the features and basic specs of the thing.
- Pulse width adjustable down to 50ns.
- Trigger : external, manual or via a built-in oscillator adjustable up to 100kHz
- Output : 50 or 300 ohms, positive or negative pulses.
- Amplitude : the attenuator goes from 0 to -59dB
ConstructionLike all decent boat anchors, it's got loads of tubes, cool dials and big knobs...
-group-therapy-thread/?action=dlattach;attach=1758536;image)
Nice mechanical construction of the attenuator. The knob is two-part : the black part makes a window slide up and down the dial, to select the coarse rang : 0-9db, 10-19db, 20-29dB etc, up to 50-59dB. Then if you turn the red knob, it makes the drum of the dial rotate which lets you fine tune the attenuation in 1dB steps.
-group-therapy-thread/?action=dlattach;attach=1758470;image)
Each knob rotates a camshaft via a bike chain. the camshafts have 4 cams and the lobes actuate 4 switches in a binary pattern. The switches of course take the relevant resistors in and out of action.
-group-therapy-thread/?action=dlattach;attach=1758548;image)
Other than this attenuator, there are 3 more dials on the front panel, which are quite nice : they have an anti-parallax system. I tried to show it in this picture, not easy.
You have a very thin fixed needle / marker... that's doubled : there are two needles, a millimeter or two apart. So you line them up tio make sure you are reading perpendicular to the dial.
Attention to detail.
-group-therapy-thread/?action=dlattach;attach=1758482;image)
At the back there is a convenient mains voltage selecting switch, hidden behind a small door easily popped, secured by two quarter turn screws. So first thing I did was set it to 240V....
-group-therapy-thread/?action=dlattach;attach=1758458;image)
The instrument comes apart dead easily : put it face down, resting on the two beefy bar handles, which conveniently protect all the knobs... then at the back there are 4 giant thumb screws.. remove them, the cabinet just lifts up in seconds, and you are in !
Electrical testingSince the instrument passed the visual inspection with flying colours, like new, no damaged or missing parts, all knobs that rotates freely and feel smooth...
I could switch to the next phase : checked fuse : good.
Grab DMM, test the power socket : primary of the transformer is neither open-circuit nor shorted : reads 3 to 5 ohms which makes sens for a transformer that... gigantic.
open-circuit between ground and neutral/live pins. Checked visually : can't see any Y caps anyway. So I am safe here (unlike the Metrix RF gen that tried to kill me with leaking Y caps and is not even earthed...).
Spotted to big can caps. They were neither shorted nor open-circuit, read a few megs, so looking good. Measured at 200+ µF and.. they are marked 200µF so.. I am happy.
So with these basics checks done, I was OK powering it up... through my dim bulb tester. It's got a small 77W halogen bulb so of course I knew it would light up solid which it did, but the point was not to get the TE functionnal/working, but just to trickle a few mA at a low voltage, to wake the TE up slowly, let the caps get out of hibernation slowly... and limit the magnitude of massive component failures, should any happen.
-group-therapy-thread/?action=dlattach;attach=1758560;image)
I measured the AC voltage at the power pins.. got about 25V.
then measured across the two can caps I had just tester : got 30Vdc with negligible ripple, so was happy.
I watched the voltage, noticed it would climb, slowly but steadily, mV by mV.... I monitored it for 10 to 15 minutes. Eventually it capped at 40 Volts or so, at which point the massive beefy chunky scary cooling fan.... came to life Yes, it started turning... barely crawling but still, there was life in this TE.
I left it warming up for another 30 minutes or so, voltage is stable, no explosions or smoke.... so me thinks the caps are good enough, and now it's only the bulb tester that's keeping it from coming to life. So I feel confident enough that I will now take the risk of powering the thing directly from mains, no dim bulb tester anymore.... will that prove to be a mistake ? Will it come to life or explode or smoke ?
You shall have the result in a coming post... for now I only wanted to introduce this TE, wet your appetite, and use the time it took me to write this down, to give the TE some more warming up time.
Oh forgot, I spotted a convenient test port in the PSU section. A connector that brings you all the power rails, clearly labeled, easy to reach, with convenient 4mm jack connectors to plug your DMM. All ports read dead zero. Of course.
-group-therapy-thread/?action=dlattach;attach=1758554;image)
OK so let's upload some pics then try to power this thing up and report... I am so excited !!!
