Tek 2465 PSU RECAP & REPAIROK last evening I pulled the PSU and took it apart, and took note of all the caps in there. Will sit down and order all that sometime today.
Then I looked at the fan motor control board, which is part of the PSU, to try to diagnose it.
Well the good news is that the fan control is on a little individual board, that's soldered directly at the but of the motor.
you just have to removed a 3 pin cable that attached to it to power it with 15V, and that's it. The motor/board can be removed in an eye blink.
-group-therapy-thread/?action=dlattach;attach=1844149;image)
So that's fantastic, that means I can actually power the fan stuff alone on the bench, don't need the PSU never mind putting it back into the scope.
So that will male troubleshooting orders of magnitude easier/faster... so here is the result :
Initial problem was that the fan would not spin.
Well now that the fan is removed and the motor is 100% unloaded... I can see it does rotate at power up, but very, very slowly. So far so good, after all it's temperature controlled.
Problem is that it draws only 40mA or something... again no problem you say, current and torque will increase as necessary when a load is present ?
Well, no. I can stop the shaft/motor with my fingers effortlessly. This motor will not develop any torque whatsoever, and will not draw and more current than the 40mA it does when unloaded.
OK so I tried to speed it up. I shorted the thermistor in order to simulate a high scope temperature. It worked. Motor now spins much faster. However it still draws pretty much the same current, and again if I try to load it with my fingers, it fails to draw more current, and fails to develop more torque. It just slows down and stops eventually, with only moderate finger pressure.
OK, so you say the electronics on the board fail to provide enough current, right ? No.
I buzzed all the components on that board, all good. Except for resistor R1691 at the bottom of the schematic. It's supposed to be 15R but registers only 10.4R.
-group-therapy-thread/?action=dlattach;attach=1844155;image)
However I don't think it's a problem... it's not a precision resistor used for current sense/feedback. To me it looks like it's just there to limit the short-circuit current (when the motor starts initially) to something safe. In this case 15Voltsd supply, 15R... that's 1A grand maximum. Which is also the current rating of the transistor array that that drives the windings, so that adds up.
So with a 10R resistor that means the max current is more... but who case, since the freaking motor won't draw more than 50mA no matter what...
ISTR replacing the quad transistors with individual transistors mounted on a standard IC header. I don't see why they need to be thermally coupled.
Since this transistor array is prone to failure it seems, and since I got some strange in-circuit readings, I removed it and replaced it with discrete transistors.
2N2222A. current rating is only 800mA not 1A, but since the motor only draws 50mA... I though it would be at least good enough to see if it made any difference, and help me further the diagnosis.
-group-therapy-thread/?action=dlattach;attach=1844143;image)
Well, doing this... it made absolutely zero difference what-so-ever. It's no better or worse.
So as far as the components surrounding the motor, I don't see anything wrong.
Only the motor itself is left. Manual says it's got hall effect sensors in it, which are in the feeback loop to control the amount of current that the windings get.
So maybe they are tired and/or : I ntice a lot of RADIAL play in the motor shaft.. axial play is normal to a degree, but lots of radial play hmmm... not good me thinks. It maybe causes the hall effect sensors to misbehave. The gaps are not as tight and consistent as they should.
Well that's were I am at right now, not looking good !
I don't know if one can find a cheap replacement motor (preferably with the control board still attached to it...).
If not, maybe it's possible to retro-fit a "normal" fan, like I noticed, later 2465 scopes were fitted with.
Requires some investigations....
Anyway, I am well pissed, because without a working fan to keep the hybrids cool, I just can't take the risk of using this scope any longer !
So for now I will order the caps and recap the PSU, which is the biggest/most painful job that this scope needs, and when that's out of the way I can investigate what can be done to fix the fan situation...
