Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 35988034 times)
0 Members and 6030 Guests are viewing this topic.
Offline factory
« Reply #137850 on: July 06, 2025, 07:56:13 pm »
And look at all those lovely SK* sockets just waiting to be jiggled and deoxidised :)
Yes as it failed when shipped, hopefully it's just a bad connection.
And be careful if probing the display ICs, shorting the HT rail to the low voltage parts will probably not end well, which reminds me of that Philips counter I ruined with a probe slip....  :-BROKE
            ....it's still here waiting for me to have another go at fixing it.
« Last Edit: July 10, 2025, 04:56:50 pm by factory »
Offline PascalNE
    • Personal Website
« Reply #137851 on: July 06, 2025, 08:02:51 pm »
Thanks everyone for all your advice. Only annoyed Im away till Tuesday and can’t try things sooner!
Move slow and break things
Offline factory
« Reply #137852 on: July 06, 2025, 08:39:07 pm »
The non-working 70755 GPIB option, could the ribbon connectors be at fault? There are three inside the 7075 and a bunch more inside the module itself, repair info & diagrams are in the 7075 technical manual.
Might be worth collecting the contents of the six PROMs somewhere too.
Offline tggzzz
« Reply #137853 on: July 06, 2025, 09:01:12 pm »
Take the 70755 off, and it will probably be possible to find useful information on the 50 way D connector. There's no microprocessor, so the interface will be pretty simple conceptually.
That might make it possible to indicate the problem is in the display section, or digital section, or elsewhere.
« Reply #137854 on: July 07, 2025, 05:27:26 am »
Selling working instruments in bits is what 'MJ' does, try not to copy them, it pisses me off no end, knowing they parted out some rare TE and stuff where I was the second highest bidder.
It would bother me slightly less it they didn't take the piss with the asking prices on parts, often one part is more the what it sold for complete & working.
Yep, scumbags like mjlorton are why we have a members only buy-sell-wanted section in The Other Place
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #137855 on: July 07, 2025, 05:31:24 am »
What, that youtube guy is stripping working gear to sell for parts???
« Reply #137856 on: July 07, 2025, 06:59:52 am »
A package arrived from Digikey yesterday. A pack of EE2-4.5TNU relays (Dual coil latching in SMD package) and a long fine cranked tip for the Metcal.
Time to replace the relays on the Advantest / ADCMT 7461A DMM.
First issue is the correct relay is EE2-4.5TNUN. This is a "reduced footprint" version. Basically the dit of the leg in contact with the PCB is shorter. Thery re not a stock item but the EE2-4.5TNU is. Easily sorted out with a small pair of flush cutters. IT does show how tight the mounting of these relays is.
Removal of old relays was by cutting the legs with my smallest pair of lindstrom side cutters. Cleaned up the pads and soldered on the new relays.
And it works.  :-DMM
However this thng is a pig to work on. The plastic parts have become brittle (date codes in IC's indicate it is no more than 20 years old) and break at the slightest touch and there is no technical information available.
I won't be buying another one.
NUN seems to be an option from NEC, seems Kemet/Yageo no longer produce it and they have elimated any reference to it the current datasheet.
There were other brands making these telecom type relays, just can't remember them at the moment.
Did you take any pictures when you had the DMM open for repairs?
Yes I did  :D
You can see it is mostly standard parts other than a couple of resistor networks. No high precsion components. They must be relying on stability and stored calibration offsets.
Robert.
The following users thanked this post: factory, PascalNE
Offline wkb
  • PA1WBU
« Reply #137857 on: July 07, 2025, 07:52:13 am »
I suppose you want him excommunicated?
Offline factory
« Reply #137858 on: July 07, 2025, 09:13:06 am »
No it not him.
It's a UK dealer that buys TE and advertises the parts on feeBay in the UK.
That would make no difference, the UK dealer is searching feeBay & probably other places, the same as we do.
Example below of rare working TE that was bought on feeBay (at approx £100 from scottrade) and parted out & bits advertised at crazy prices.
The Fluke 8375 I asked about on here was another rare TE, it wasn’t functional & I didn't know if it was complete at the time, but would now, since the manual is on archive org.
« Last Edit: July 07, 2025, 09:54:16 am by factory »
Offline wkb
  • PA1WBU
« Reply #137859 on: July 07, 2025, 09:15:21 am »
No it not him.
Terra was refering to mjlorton on YouTube. But regardless: lets excommunicate brainless TE breakers  >:D
Offline factory
« Reply #137860 on: July 07, 2025, 09:40:16 am »
I'd not actually heard of mjlorton before, can't imagine they would be buying much from here anyway. Yes I excommunicate known TE breaking dealers & even one TE breaker on this forum.
Yes I did  :D
Robert.
Guessing the ref is the LT1027, next to some of those custom resistor networks.
And I see what you mean by the short leads on the NEC relays, not sure why they used those, given there is space around them.
« Last Edit: July 07, 2025, 09:46:15 am by factory »
Offline madao
« Reply #137861 on: July 07, 2025, 12:08:59 pm »
TE Breaker, you can added Max Koschuh to "TE Breaker" bzw  Röhrengeier (german tube vulture, raped HP/Tek for audiofool-tube )
« Reply #137862 on: July 07, 2025, 12:40:04 pm »
mjtronix, not mjlorton, apologies 😓
  • Country: jp
« Reply #137863 on: July 07, 2025, 12:46:03 pm »
Ah, crisis averted!
Offline Hydron
« Reply #137864 on: July 07, 2025, 01:12:52 pm »
Yeah and mjtronix has little to no docs/specs on most of the components, so they're worth far less after being stripped from an unnamed instrument than they would be if you at least knew where they came from. Wouldn't be so bad if he just attacked old military gear that isn't really amenable to use outside that environment, but all manner of good usable/fixable TE is also ruined by that damn butcher.
« Last Edit: July 07, 2025, 01:16:17 pm by Hydron »
« Reply #137865 on: July 07, 2025, 06:58:03 pm »
I've stopped looking at his listings. It's not good for my blood pressure.
Robert.
Offline wkb
  • PA1WBU
« Reply #137866 on: July 07, 2025, 09:06:11 pm »
Offline EggertEnjoyer123
« Reply #137867 on: July 08, 2025, 04:00:53 am »
I got a Telequipment CT71 curve tracer for a low price from the ewaste.
Has anyone 3D printed a replacement knob for these? I'd prefer if I didn't have to draw it up in CAD. Also I'm missing the box so I'm probably going to have to 3D print a replacement for that too.
Edit: https://www.printables.com/model/113790-telequipment-ct71-curve-tracer-knob/remixes
Offline tautech
« Reply #137868 on: July 08, 2025, 04:34:41 am »
Being a '71 vintage or later, more Tek than Telequipment so Tek knobs will very likely fit.
https://w140.com/tekwiki/wiki/Telequipment_CT71
Avid Rabid Hobbyist
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #137869 on: July 08, 2025, 04:37:38 pm »
HP 8156A (optical attenuator) presents with a "FAIL0040" error. Opened her up, vaguely hoping it would be the CMOS battery or something.
Seems the previous owner also opened her up. And didn't put the hood back on. And pulled so hard on the PCB that it cracked. And lost the hood  |O Even if I could figure it out and repair, I probably still can't sell it. I'm guessing that optical mirror being contaminated with dust is not a good thing.
You can't win them all I suppose but at least I had a learning experience. Optical is black voodoo to me, but seeing this makes a lot of sense. The input passes a lightguide to line it up. There's a rotating mirror placed under an angle so it reflects back to the output. I'm guessing that the mirror has a gradient or something so rotating it changes the attenuation.
« Last Edit: July 08, 2025, 04:41:52 pm by Ice-Tea »
Offline m k
« Reply #137870 on: July 09, 2025, 02:39:11 pm »
Can you test it?
Light is a nasty bugger to deal with.
Acoustic beam shaper was one solution.
Latest laser I've had to fiddle was Linotronic 500, pretty fresh, eh.
(it's a film printer and time was this millennia)
Since the light likes to "fold" it's route must be kept materially homogeneous.
Air is just fine for straight stuff, but deflection is different.
That old Lino has five beam deflection points, if memory serves.
Including one rotating hexagon and one curved convergence mirror.
(and a mechanical attenuation wheel with dimming glasses)
To keep things in order all of them are deflecting from the surface.
On the other hand it's light, nothing more.
For film printer it means that no darkness and the film is gray.
Unfortunately placed dust particle and a dot is nowhere or somewhere else.
(don't sneeze when cleaning is almost done)
So clean the glass like you'd clean your eye, no scratches, no harmful chemicals and no leftovers.
Repair the PCB, add a new cover and sell it for secondary projects.
Offline Shimonu
« Reply #137871 on: July 09, 2025, 04:56:21 pm »
I got a couple of faulty frequency counter yesterday. A Philips PM 6669 and an HP 5315A.
My suspicion is that the seller of the HP didn't quite know how to use a frequency counter as they said it wouldn't show anything when connecting a signal on the input. My guess is they didn't adjust the sensitivity because it worked fine when I got it and haven't had that kind of problem. On the other hand it was behaving strangely and would seemingly enter the display check for no reason. That just turned out to be some dirty switches and after cleaning it seems to work great!
The Philips had a strange problem, it has the battery option and it wouldn't show any count if the plug was connected together with the battery but it worked fine on each power source separately. It turned out to be a broken output pin on a 7905 which I've resoldered temporarily.
Today I've also got a DMMCheckPlus, lovely little thing. Pretty handy for checking all the functions of repaired multimeters or even an LCR meter.
Yeah, I'm starting to like this hobby. :-+
The following users thanked this post: Vince, ch_scr, TERRA Operative
Offline wkb
  • PA1WBU
« Reply #137872 on: July 09, 2025, 05:34:04 pm »
Now this followed me home, so I have an infinite IQ rabbit hole to explore   :-//
A day on which you did not learn something is a day not lived...
Offline Ice-Tea
« Reply #137873 on: July 09, 2025, 05:41:38 pm »
Can you test it?
Maybe, not sure...
Doesn't solve the Fail. In addition: not worth my time. There's no way I could sell it full price (at least not while staying honnest) and at anything less than full price it rapidly descends in 'not economic to repair' territory. Probably will keep it around for parts (the display and the PSU are shared with other devices I think). Or, if someone is willing to fork over the price of a display, it's theirs ;-)
EDIT: Another class of instruments I have little experience with. R&S ESCS30. So many questions, so much to learn!
« Last Edit: July 09, 2025, 06:16:20 pm by Ice-Tea »
Offline Ice-Tea
« Reply #137874 on: July 11, 2025, 09:18:50 am »
WHAT IS THIS ALL DOING HERE???  >:( >:( >:(
