Oh, a Tek 577 curve tracer ! Didn't remember you had that one !
There is a reason for not remembering the 577, I didn't have enough time for a post when I picked it up 3 weeks ago, along with the other TE and smaller items & parts, took me about 2 days to go though everything making notes of what was in the boxes and checking for things that might have leaktubes inside, only casualty of those was a Megger BM8, with mil grade leakage.
-group-therapy-thread/?action=dlattach;attach=2904616)
Hmmm.... top right corner of the second pic, the side of two similar looking boat anchors stacked on top of each other, I think I recognize those !!
Well done for spotting those two 416B ratio meters, the tape recorder I stole an eye tube from (for one of the HP meters) is in the store too. Underneath those two boat anchors is the £10 606B, these are all now completely inaccessible, they need to be in the opposite corner with the boat anchor counter (pun not intended).
My helper decided not to stack some of the TE, instead it was left face up, can't complain too much given the amount we moved.
Oh, and a Tek TDS 300/400 scope in the van, I am surprised that you fell for such modern stuff ! Not your kind
No that's right... you do have some modern scopes.... your Yokogawa springs to mind now I think of it...
-group-therapy-thread/?action=dlattach;attach=2904620)
Your right not really my sort of thing, but it came with the job lot, it's a TDS 420A, it's supposed to be working, probably has RIFA/Schaffner madness smoke waiting to be released, I've read about surface mount cap-iss-itors too, the rear cover is bit broken.
My Yokogawa scope has been out recently, the HP DSO hasn't been used for a long time (has annoying fault) and a more recent Tek TDS 2014 has proved very unreliable.
Also have a badly behaved Hameg, focus problem has been sorted (drifted film resistors), but it seems to have more problems.
-group-therapy-thread/?action=dlattach;attach=2904624)
So I worked on the BWD powerscope instead, it was described as "doesn't power up", well it didn't the first time I operated the power switch, but did the second time (must have dirty switch) it worked for about 30 seconds before the trace & LEDs started flickering, the trace then became a dot. Opening I got the burnt resistor smell, due to a tant bead, I found the tant, changed the 100 ohm resistor and checked some other capacitors, some were testing low in value, I've started recapping the PSU, which is now waiting for me to order more capacitors from Mouser.
-group-therapy-thread/?action=dlattach;attach=2904628)
The picture also shows a HP DSA, the fuse holder, handle & feet are missing and the HPIB connector is broken, not looked inside yet.
Now you need half a dozen heavy duty shelves to make all these instruments easy to access... but beefy shelves cost a mega fortune, at least here they do
Only hope would be to search for used ones locally.
I've only got one decent shelving unit, the ex-work one which I suspect originally came from RS, it was in the motor alternator control unit test pen for years, before that got EOL'd.
The blue shelves are very thin, I can't believe they haven't collapsed yet, there are two Ikea bookcases that I got just before the 2024 health malfunction, they are still waiting to be assembled and filled with manuals.
