Hello,
Four weeks ago, Paul posted on youtube two videos on the topic of understanding and decoding ARINC 429. Thank you very much for that.
Unfortunately, used aeronautical devices with ARINC 429, such as altimeters, are still very expensive. Too expensive to just try out the decoder in the MXO. But there is an Arduino sketch on Github that generates an ARIC 429 signal. It's not very stable, but I've managed to get a few error-free transmissions from time to time.
For anyone who wants to try it out, I have attached an Arb file for the MXO function generator. It contains 5 words, but is not symmetrical ±5V or ±10 V, as would be correct according to ARINC 429, but only positive.
However, it still works with the correct settings: Gen1 output 3Vpp, 0V offset, Protocol settings, Polarity A Leg, Bit rate mode High, Min Gap Time standard 4 bit, Upper Threshold 2.5V, Lower Threshold 0.5V.
Another suggestion for the MXO roadmap: for the polarity settings, include not only A Leg and B Leg but also A-B.
Images 2 and 3 were created with the ARINC 429 signal from Gen 1.
Best Regards,
Bernd
