As long as input is not overdriven (as it is not) level should not change shape of "skirts" on bins..
It is either different window or some RBW setting or something is wrong.
This is exactly where Rigol had (and still to some extent still has) a problem with FFT implementation...
So devices are software incomplete, OEM does not support it directly, there are numerous problems, including signal integrity problems...
Voltcraft supports it to some extent, but good luck fixing FW problems via intermediary.....
If this was simple scope that has only basic functions (very basic math for instance) but has simple stuff working right, for 150-180 € it would be cheap alternative to Fnrisi...
But it is not working right. In some aspects even Fnrisi works better, it seems....
As for normal price they are asking usually, you would have to be mental to buy it... This special price is only for Germany and some other special destinations. Conrad lists it for more than 400€+VAT...
More expensive than DHO800 and same as SDS800xHD.....
