Author Topic: VOLTCRAFT DOV series  (Read 19892 times)
Aldo22, lcp, Olex, PhilRépartout and 12 Guests are viewing this topic.
Online 2N3055
  • Country: hr
Re: VOLTCRAFT DOV series
« Reply #250 on: June 09, 2026, 01:13:18 pm »
What is actual purchase price of the scope ( 2 and 4 channel) with VAT at this time?
Dr. Richard W. Hamming
Online Aldo22Topic starter
« Reply #251 on: June 09, 2026, 01:39:27 pm »
It seems hopeless to me.
The signal looks fine, so I'm wondering if this could be a firmware bug.
Very strange.
Don't give up.... ;)
Please try the following:
1. Press the Default button and confirm
2. Then set the channel where the square wave is input back on (turn the other channels off)
3. Set the time base to 500 ns
4. Turn on FFT, leave it as is.
5. Now press “Autoset” in the FFT menu
What does it look like then?
If I follow your instructions (almost) to the letter, this is what it looks like (10MHz square):
The following users thanked this post: egonotto, Martin72
Online Martin72
« Reply #252 on: June 09, 2026, 01:49:29 pm »
Here's what it looks like on my scope:
1) After restoring factory defaults, set to usable values.
2) FFT enabled, with no changes made to it#
3) “Autoset” pressed in the FFT menu.
It would be good if others could confirm or refute this.
@2N3055: No matter how much, it's too much. ;)
The following users thanked this post: egonotto, 2N3055, Aldo22
« Reply #253 on: June 09, 2026, 02:26:25 pm »
OK, thanks.
But what else could it be besides a firmware difference?
The 10 MHz signal looks fine, so what else could be going wrong?
Online 2N3055
  • Country: hr
« Reply #254 on: June 09, 2026, 02:31:27 pm »
OK, thanks.
Try different frequency... 11Mhz for instance... Or try setting FG until scope shows exactly 10MHz..
The following users thanked this post: Martin72, Aldo22
« Reply #255 on: June 09, 2026, 02:32:34 pm »
2Ch: 149.- at Conrad Germany
4Ch: 199.- at Conrad Germany
and far too much in other countries.
« Reply #256 on: June 09, 2026, 02:46:47 pm »
Thanks, but how does that help me?
-> Screenshot at 11 MHz
The funny thing is that it actually works a little bit; it just looks completely different from Martin's.
I probably would have just accepted it if I hadn’t seen Martin’s screenshots.
It’s also particularly strange that the signals are always at -90dB (see Y cursor).
What does that tell me?
Offline KungFuJosh
  • TEAS is real.
« Reply #257 on: June 09, 2026, 02:48:31 pm »
What sig gen are you using, and what output level?
What sig gen and output level is @Martin72 using?
Best Continuity Tester Ever
« Reply #258 on: June 09, 2026, 02:58:48 pm »
I've tried a few different ones.
This image here is from the NanoVNA with the MS5351. About 350 mVpp.
« Last Edit: June 09, 2026, 03:00:26 pm by Aldo22 »
Offline atrophicinterludes
« Reply #259 on: June 09, 2026, 03:16:51 pm »
If you buy from Voelkner (part of Conrad) and use a coupon, the total prices including VAT and shipping currently come to €128.55 and €173.55 for the 2-channel and 4-channel variants, respectively.
I believe you also get a 2-year warranty extension if you subscribe to their newsletter.
Online Martin72
« Reply #260 on: June 09, 2026, 03:22:15 pm »
I first fed in the signal from the Bodnar pulser, which can also be seen in the FFT; the last examples were taken with an SDG6000X.
(+14 dBm, 50 Ω)
As for the firmware, as I mentioned, I took my first FFT images with my first Voltcraft unit, without updating the firmware
Offline KungFuJosh
  • TEAS is real.
« Reply #261 on: June 09, 2026, 03:32:49 pm »
So what's the put your signal at? @Martin72's signal was at +14dBm. My guess is that you'd have to adjust the sensitivity of the FFT if the scope can handle that, or try a higher signal level.
ETA: Are you using 50Ω termination?
« Last Edit: June 09, 2026, 03:37:23 pm by KungFuJosh »
Online Martin72
« Reply #262 on: June 09, 2026, 03:56:12 pm »
We can do it another way, Aldo.
What sources do you have available? I'll try to replicate them in terms of waveform, level, and frequency.
To be able to compare anything, the conditions have to be reasonably similar.
The following users thanked this post: Performa01, egonotto, KungFuJosh, Aldo22
« Reply #263 on: June 09, 2026, 04:20:45 pm »
I really appreciate your help, but I'm becoming more and more convinced that there's something wrong with my device or the firmware version.  :-//
Anyway, here's my suggestion:
12.50 MHz at 4 Vpp with coax and a 50-ohm load = approx. 2 Vpp.
OK? 6.25 MHz would work as well.
« Last Edit: June 09, 2026, 04:26:59 pm by Aldo22 »
Online Martin72
« Reply #264 on: June 09, 2026, 04:26:17 pm »
OK, got it... ;)
The following users thanked this post: egonotto, Aldo22
« Reply #265 on: June 09, 2026, 04:29:40 pm »
OK, got it... ;)
Different rise-time!  :-DD
And now?
Online 2N3055
  • Country: hr
« Reply #266 on: June 09, 2026, 04:32:55 pm »
As long as input is not overdriven (as it is not) level should not change shape of "skirts" on bins..
It is either different window or some RBW setting or something is wrong.
This is exactly where Rigol had (and still to some extent still has) a problem with FFT implementation...
So devices are software incomplete, OEM does not support it directly, there are numerous problems, including signal integrity problems...
Voltcraft supports it to some extent, but good luck fixing FW problems via intermediary.....
If this was simple scope that has only basic functions (very basic math for instance) but has simple stuff working right, for 150-180 € it would be cheap alternative to Fnrisi...
But it is not working right. In some aspects even Fnrisi works better, it seems....
As for normal price they are asking usually, you would have to be mental to buy it... This special price is only for Germany and some other special destinations. Conrad lists it for more than 400€+VAT...
More expensive than DHO800 and same as SDS800xHD.....
Online 2N3055
  • Country: hr
« Reply #267 on: June 09, 2026, 04:34:28 pm »
OK, got it... ;)
And now?
Different rise time will change amplitude of higher harmonics. It has no influence to the shape of bins on lower frequencies itself.
Online Martin72
« Reply #268 on: June 09, 2026, 04:37:11 pm »
And now?
Switch on FFT, press Autoset.
After that, I played around with the span a bit and, of course, adjusted the time base.
But first, I used Autoset, and then it should have turned out like in my picture.
« Reply #269 on: June 09, 2026, 04:43:35 pm »
I can see something with these settings below.
Also strange: when you select “Mode Average,” the Vpp is halved in the automatic measurements.
« Last Edit: June 09, 2026, 04:45:56 pm by Aldo22 »
Online Martin72
« Reply #270 on: June 09, 2026, 04:43:42 pm »
@2N3055:
The scope would be OK at the listed price RIGHT NOW if the 200 mV glitch were fixed.
Otherwise, it’s way too expensive and not worth recommending, because at the original price it’s too close to a DH800—and that’s significantly better.
It might be worth the price if the software were halfway up to par, but it isn’t.
It’s partially buggy and far too lacking in features.
Plus, the support is absolutely terrible.
No, €200–250 would be OK, but definitely not anything above that, because no improvements in terms of OS/UI are to be expected.
Online Martin72
« Reply #271 on: June 09, 2026, 04:46:06 pm »
With these settings, I can see something:
Same window (Hanning)?
« Reply #272 on: June 09, 2026, 04:52:37 pm »
No, Hamming. With Hanning, the dB levels drop even lower, so I can't see much anymore.
Online Martin72
« Reply #273 on: June 09, 2026, 05:14:50 pm »
I'm a kid at heart...
https://www.youtube.com/shorts/x6YUCSFR0DU
Then something is definitely wrong.
« Last Edit: June 09, 2026, 05:18:17 pm by Martin72 »
« Reply #274 on: June 09, 2026, 05:30:56 pm »
By the way, you can also create an MP4 directly in the scope.
Swipe down from the top of the screen, then tap the hard-to-see camera icon and confirm to start
I think so too.
The question is simply whether it's a hardware issue or a firmware issue.
« Last Edit: June 09, 2026, 05:34:29 pm by Aldo22 »
