Author Topic: FLIR E4 Wifi Resolution and Menu Hack Thread  (Read 443381 times)
Online Psi
Re: FLIR E4 Wifi Resolution and Menu Hack Thread
« Reply #975 on: April 23, 2020, 07:09:05 am »
I'm thinking of getting a Flir E4 with the goal to update it for full resolution.
No idea what version i would receive and if that will be possible.
My question is, is it possible to unsolder/dump out the flash contents so i have a known working state a could fall back on if i brick it?
Or is there some hardware features that makes that impossible.
« Last Edit: April 23, 2020, 07:11:14 am by Psi »
Offline KONNEX
« Reply #976 on: April 24, 2020, 05:40:05 pm »
2 questions:
1) How to enter the credit screen that bud implemented?
2) Using Iron or Rainbow with temp range.. and looking at objects like a house with the sky in the background (-40°) - how do I compensate the scale?
I just ask again ;)
Online Bud
« Reply #977 on: April 24, 2020, 06:22:03 pm »
I just ask again ;)
2) not sure if this is what you mean, you can switch temperature scale to Manual and play with adjustment of low and high  limit separately or together.
Offline Kkonline
  • Country: sg
« Reply #978 on: April 27, 2020, 04:01:02 pm »
Hi everyone,
Thanks for this forum post once again. I have one newbie question here to ask any pro here.
1. When the surrounding temperature was 31c-32c, the e4 is showing object around 36.1.c.
2. But when it reaches noon time, the surrounding temperature got hotter (38c), the target temperature became higher (abnormal) at around 39c to 40c. Can anyone kind enough to explain the fluctuations in temperature?
3. The unit is being used outdoor. Noon time temp can reach 38c. Morning time is abour 31c-32c.
Thank you very much!
Online Bud
« Reply #979 on: April 27, 2020, 04:39:44 pm »
You need to adjust Emissivity, Ambient temperature and Reflected temperature settings.
Offline Kkonline
  • Country: sg
« Reply #980 on: April 27, 2020, 04:43:41 pm »
Hi bud,
Do you mean when it reaches noon time, the ambient temperature needs to be adjusted accordingly? And to adjust it back during the morning?
Sincerely,
Online Bud
« Reply #981 on: April 27, 2020, 10:28:38 pm »
You should always match ambient and reflected temperature in Settings if you want better accuracy. These parameters represent vvariables into the object temperature  calculation formula.
Offline Kkonline
  • Country: sg
« Reply #982 on: April 28, 2020, 12:30:09 am »
I got it. Thank you so much bud. I learnt something new
 again today.
Offline KONNEX
« Reply #983 on: April 29, 2020, 04:09:21 pm »
I just ask again ;)
In some kind of configuration I got a (cyan) limiter for the lower temperature (by accident) with iron, rainbow and other pallets which might be nice. But I'm not sure how I got it. The other Question is more a general question how to really messure object with the sky in the background? Just ignore it and post-process in flir tools? the sky is more or less always below 0. Or do I just have to adjust ambient temperatur and so on and my issue is gone?
Currently I have a much bigger problem. I overtightened the fixed Focus lense and scratched a ring (from the metal case/frame) in it.. this might wouldn't be much of a problem but now the Image of the sensor and camera do not match as the lense is shifted. Does anyone know how to fix that or get a replacement of the screwed in lense? |O
Edit: If I change "rset image.fusion.ypanvol"  to like 40 it's close..  but not "perfect" from other angels. - I will post pictures tomorrow
Edit2: Hm.. I'm pretty sure I somewhat broke the lense in some way (throug the pressure? - is it possible?) from the distance everything seems fine but in close ups the pictures are way off, like 2-3cm :/ - // Would it be enough to replace the lens and does someone know where to get it?
Edit3: Now I'm not so sure if anything is broken or it's just the distance which causes the shifting. - here some pictures:
- close shots (shifted)
- the scratched lense
- rainbow palet with a minimal range option?! - not sure how this happend but is somewhat nice.
« Last Edit: May 04, 2020, 08:21:59 am by KONNEX »
Offline intef
« Reply #984 on: April 30, 2020, 07:12:00 am »
Success, E4 2.0L, non wifi, 3.12.0, fresh from RS components. Looks like a good specimen.
.calib.nrdp.ds250C_we_ap_fi_le.measureInfo.temporalMk double 11.611229
Already did some mods to qml's  :-+
Offline mmame
« Reply #985 on: May 11, 2020, 06:54:14 am »
Sorry to ask a maybe already answered question, so...
Is there any worth to update the firmware from 3.9.0 to 3.16.0?
Online Bud
« Reply #986 on: May 12, 2020, 02:54:00 am »
Perhaps you tried just too close ? The stock E4 I believe minimal distance is 0.6m that it can correct for the parallax. Check the "Alignment distance" setting in Settings menu. The liberated E4 can go closer than 0.6m so make sure you set that parameter properly depending on the distance to the object you are trying top measure. The E4 does not have auto-alignment, it is up to the user.
The following users thanked this post: KONNEX
Offline Weston
« Reply #987 on: June 11, 2020, 05:10:36 am »
My flir E4 wifi arrived today and I the liberation procedure went smoothly! Thank you Bud for all the work do for the community on this!
For those looking on where to order the camera from, I ordered my flir E4 wifi from TEquipment a few months ago and it was backordered so it only recently shipped. The camera is hardware version 2.0L and software 3.16.0. The calibration card has a date of April 28, 2020, which is recent, so I would assume that there is no newer software than 3.16.0. I have not tried the advanced package yet.
For those not wanting to dig through endless pages of the thread:
I used the 3.12.0  files from here: https://www.eevblog.com/forum/thermal-imaging/flir-e4-wifi-resolution-and-menu-hack-thread/msg1397359/#msg1397359
and the new 3.16.0 dll from here: https://www.eevblog.com/forum/thermal-imaging/flir-e4-wifi-resolution-and-menu-hack-thread/msg2252082/#msg2252082
and instructions on how to put the camera in RNDIS mode from here (I had problems with the website so I had to access it through web archive) https://web.archive.org/web/20190409142550/https://fubar.gr/hacking-the-flir-e4/
This was done on a windows 10 desktop.
The following users thanked this post: Bud, iainwhite, andre2142, d2, 556
Offline Summer
  • Country: tw
« Reply #988 on: June 16, 2020, 01:16:54 am »
Here is a version of the Basic Package for E4 WiFi 2.0L, fw v3.12.0
I do not have a 3.12.0 device, so this version has not been tested.
YOU TRY AT YOUR OWN RISK.
Update: Basic Package v3.12.0 is confirmed working.
Update: Advanced Package v3.12.0 is confirmed working.
Update August 2018: New camera version v3.13.0 confirmed working with this v3.12.0 Basic Package. See post here:
https://www.eevblog.com/forum/thermal-imaging/flir-e4-wifi-resolution-and-menu-hack-thread/msg1733972/#msg1733972
my flir e4 HW 2.0L SW 3.9.0(hack) non wifi
can I use
Basic_3.12.0.zip
common_dll_3.12.0.zip
in flir e4 2.0L non wifi ?
thank you
« Last Edit: June 16, 2020, 08:04:04 am by Summer »
Online Bud
« Reply #989 on: June 16, 2020, 03:05:36 pm »
I do not know.
The following users thanked this post: Summer
Offline d2
« Reply #990 on: June 20, 2020, 08:19:52 pm »
Just to confirm:
Westons summary works fine on E4 2.0L with 3.16.0 without WIFI.
Camera odered from RS components two days ago.
Thanks Bud for the great work! Thanks Weston for the summary!
Bye,
Daniel.
Offline ignat750
  • Country: ua
« Reply #991 on: June 24, 2020, 07:16:12 pm »
Help, I want to buy flir e4, but I don’t know if anyone can flash it in flir e8? Or can only old versions of flir e4 be changed in e8?
Offline DaveWBTopic starter
« Reply #992 on: June 24, 2020, 07:21:09 pm »
They all can be upgraded.
Offline ignat750
  • Country: ua
« Reply #993 on: June 25, 2020, 03:52:43 am »
Many thanks.
Offline ignat750
  • Country: ua
« Reply #994 on: June 25, 2020, 08:07:07 am »
flir e4 wifi p/n: 63906-0604
change in e8+ ? And will it work well?
Offline abgx1
  • Country: sk
« Reply #995 on: June 29, 2020, 09:12:40 am »
it should be OK, but I am gonna ask to be sure:
can I upgrade flir E5(2.0L with 3.16.0) with wifi to E8 with same process as E4(via watsons summary)?
« Last Edit: June 29, 2020, 09:15:55 am by abgx1 »
Offline Aaronm
« Reply #996 on: August 08, 2020, 06:14:14 pm »
Do you have the instructions step by step?
Offline lazarusr
« Reply #997 on: August 15, 2020, 05:42:50 pm »
Another very satisfied customer. Thanks Bud for all your work on this.  :-+ :clap:
(E4 2.0L with 3.16.0 without WIFI)
Offline Sakalas26
  • Country: lt
« Reply #998 on: August 20, 2020, 04:20:26 pm »
Dear colleagues, i encountered this problem when i try to enter "stopapp" in the "Putty" telnet program window. Maybe someone was facing this problem?
Thanks.
Online Bud
« Reply #999 on: August 20, 2020, 05:58:26 pm »
If you connect through USB you need to start from getting the camera generate the proper IP address (192.168.0.2 i believe). The IP address you connected to may not have the needed service. You may not be able to advance until you set the camera's network interface correctly.
