Author Topic: Flir E40 Upgrade & Configuration  (Read 264173 times)
0 Members and 26 Guests are viewing this topic.
Offline matthieu.e
Re: Flir E40 Upgrade & Configuration
« Reply #475 on: September 29, 2025, 04:04:07 pm »
Hi Fraser,
Thank you ! So I can’t update the number in the conf file and I need to modify the EEPROM directly on the circuit ?
Online Fraser
« Reply #476 on: September 29, 2025, 04:18:53 pm »
Correct
The eeprom contents are editable in the cameras service menu after entering the required password.
Offline matthieu.e
« Reply #477 on: September 29, 2025, 04:43:27 pm »
I have a E40 mk2 can explain you me how to access to the service menu and share the password ?
Is the service menu the same as the one we have to go to change the usb mode ? Or is it only for accessible on the mk1 version ?
« Last Edit: September 29, 2025, 06:59:36 pm by matthieu.e »
Online Fraser
« Reply #478 on: September 29, 2025, 07:59:30 pm »
EEPROM access password: 1235
The rest is detailed in posts on this forum. Use search for Ex, E4 and E40 to find out about eeprom access.
Offline matthieu.e
« Reply #479 on: October 02, 2025, 12:44:49 pm »
Thank you, I will do the research.
Offline matthieu.e
« Reply #480 on: October 02, 2025, 01:03:40 pm »
Hi Fraser,
Do you refer to this menu to update the camera number ?(attached picture, not my camera).
If yes I think it is only editable on the mk1 version. My E40 mk2 do not have this menu. Or perhaps I need to downgrade the firmware ?
Online Fraser
« Reply #481 on: October 02, 2025, 04:46:55 pm »
Yes that is the correct menu and it is present on my E40 Mk1.
Some Mk2 owners have reported that they have the Service Menu in their camera. It would appear that some do and some do not  :-// I do not know whether a firmware downgrade would provide the service menu for your camera.
Fraser
« Last Edit: October 02, 2025, 04:49:07 pm by Fraser »
Offline RRtheone
« Reply #482 on: October 08, 2025, 07:41:40 am »
Hi Fraser,
You need 3.18 firmware (can be found in this forum). I have a E40 mk2 and get this menu after downgrading.
Offline dogmanner98
  • Country: kr
« Reply #483 on: February 27, 2026, 12:21:17 am »
Can I get the 2.23.14 firmware?
All the links don't work.
