Author Topic: Infiray C210 Thermal Camera review  (Read 46718 times)
Offline keenox
Re: Infiray C210 Thermal Camera review
« Reply #100 on: September 02, 2022, 03:59:55 pm »
I put it on the SD and copied it from terminal to /root. Did not go the upgrade path because I wanted to be as safe as possible and not lose access to the USB terminal in case something happens.
My guess is also that it is hardcoded into the executable, but I did not find any differences yet in the code where the menus are created and switched, but I did not have the time to properly analyze the executable. Maybe I will this weekend.
Offline keenox
« Reply #101 on: September 02, 2022, 08:23:37 pm »
I managed to find the differences between 1.1.10 and 1.1.18. It is indeed hardcoded, the Qt signals for showing the menu are not connected. I managed to patch the binary to show the USB mode menu instead of device information, but upon switch it crashes. Needs some more work.
Offline littlebootTopic starter
« Reply #102 on: November 03, 2022, 12:52:00 pm »
Hi, It has been a while since I started this topic.
Very nice that people have found a way to extract the firmware.  :-+
I have the C210 model, the device information page lists the following:
Model: C series
Version: V1.1.10
My camera does support the "USB camera" option.
If my understanding is correct after reading the comments, There is currently not a way to extract the firmware from this camera without opening it up.
For me there is no real need to take the device apart, it is working and I have all the features I need, but if someone needs it let me know.
I assume my camera is IMX6 based, not sure though ("C200 based on HiSi3516 platform, different for the C200/C210 from early batches which are IMX6 based")
Maybe it is possible to just load my C210 firmware on the C200 model to make UVC work?
Offline bebopdk
« Reply #103 on: November 04, 2022, 09:10:00 am »
Could be interesting to see the C210 fw and find out if it could be modified for the C200,
I ended up with a C200 even though I ordered a C210, but returning it would be a nightmare due to the non refundable VAT and taxes I paid for it |O, so I am kind of stuck with it, but having the webcam working would make me feel a bit less disappointed :-+
« Last Edit: November 04, 2022, 09:12:24 am by bebopdk »
Offline Ozzi
« Reply #104 on: January 21, 2023, 11:43:24 am »
Hi All,
I've ordered a c200 as well, but before it arrives i have been analyzing the 2 pictures (the IRG files) that were posted in this thread.
I noticed that the JPG data in these files are only 192x256 as well. Do you know if there is an option to get the full resolution in the irg-files?
Its kind of a waste letting all those extra pixels go to waste ;)
Offline Ozzi
« Reply #105 on: January 22, 2023, 01:48:45 pm »
For now I am able to generate the following image from the IRG-data:
Offline joe-c
    • Joe-c.de
« Reply #106 on: January 22, 2023, 04:47:22 pm »
I have no InfiRay_C210, but i got 2 Frames to look at.
it have 192x256 as 2 byte per pixel.
I also have a "Vevor SC240" here, it stores *.irg files too and the format looks similar.
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
Offline Ozzi
« Reply #107 on: January 25, 2023, 02:07:21 pm »
Yesterday I received my c200, it seems that I have software version 1.3.8
The data in the irg-files seem to be a bit different as well. I am also not able to open them with the IRAY software on windows.
Offline litchiate
  • Country: cn
« Reply #108 on: February 23, 2023, 06:38:27 am »
thanks, I should put stl file instead of sldprt file. ::)
Offline RAPER
« Reply #109 on: March 11, 2023, 03:56:05 pm »
Hey, is there any progress with the software update in c200/
A-BF RX-680 ??? can you unlock uvc?
Offline rebotea
  • Country: pt
« Reply #110 on: March 14, 2023, 08:20:57 pm »
Hi any code to read thermal image?
Offline duzycinek
« Reply #111 on: March 16, 2023, 03:40:00 pm »
Hello, anyone have maybe firmware for C210? Sadly I got 1.1.6 :(
Offline Honusnap
« Reply #112 on: April 15, 2023, 09:57:20 am »
I received a C200 Pro and it's all in chinese, and no option in the menu to change to english ...
Is there something special to do to get it in english ?
I got firmware 1.3.8
Thanks
Offline Honusnap
« Reply #113 on: April 18, 2023, 03:26:09 pm »
Hello,
Are you able to chose english langage for this device ? I got the same firmware and C200 Pro, it's only in Chinese .. !
Offline sab
« Reply #114 on: May 02, 2023, 06:16:49 pm »
Has anyone had luck changing the date and time on the C210? Every time I change it, it defaults to 0101/1970 when I restart the device. I have firmware version v1.3.1(111).'
Perhaps there is some secret key or a long press that is required to save the date/time after I change it? I've tried but haven't had any luck.
BTW,  I did email support@infiray.com for new firmware and was told to to go to orders@infiray.com. No response from them though. And, the link previously posted on this thread is dead.
Thanks,
Sanjay
Offline Honusnap
« Reply #115 on: July 10, 2023, 09:49:48 am »
Hello All,
Still pinging here, do someone got a firmware for a C200 pro (or maybe not pro) Thankkkss
Offline painkiller
« Reply #116 on: July 23, 2023, 01:51:21 am »
I just got a C200 pro. When I try to bring up the hiden menu to have a look, instead I think I brought up the calibration menu instead....I immediately press the back button to exit. but it seems something has changed. the temperature measuremnt and image is now off....I am cursing myself at moment.....
Is it possibe to restore a backup copy of the calibration from another C200 unit to the camera if someone have it?  I know it won't be perfect for my unit. But at least is should be close? Thanks a lot.
BTW, is that update_dat in the advance manu for restore the calibration?
« Last Edit: July 23, 2023, 01:53:18 am by painkiller »
Offline bebopdk
« Reply #117 on: August 01, 2023, 09:27:52 am »
The calibration is stored in a file named CalTempConfig.ini, it is unique to each camera, but the attached one is from a C200 V.1.1.10.
Offline Honusnap
« Reply #118 on: October 26, 2023, 03:48:57 pm »
Hello,
Do you know a way to dump the C200 firmware ? Or maybe you already got a firmware update for a C200 ?
Thanks
Offline bebopdk
« Reply #119 on: October 27, 2023, 08:16:35 am »
It is mentioned earlier in this thread, you will need to connect via the internal serial port:
https://www.eevblog.com/forum/thermal-imaging/infiray-c210-thermal-camera-review/msg4368193/#msg4368193
Offline Honusnap
« Reply #120 on: November 27, 2023, 04:07:34 pm »
Hello,
This method do not seeems to work with recent C200 (i got a 1.3.8 firmwawre - C200 Pro)
