Author Topic: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project  (Read 96322 times)
Offline djosTopic starter
Re: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project
« Reply #150 on: August 24, 2017, 08:57:18 pm »
But with a bus expander, that could be remedied. You want to back up your floppy collection, right? ;D
 :-DD
Offline bitseeker
« Reply #151 on: August 25, 2017, 06:17:55 am »
Yeah, to think my entire collection of hundreds of 5.25" floppies would barely put a dent in a freebie thumb drive these days. I wonder how much longer those disks will maintain a readable signal.
« Reply #152 on: August 25, 2017, 06:49:15 am »
I've got close to 10 GB of c64 disk images! Considering they are 170 kb each....  :-DD
The old discs last surprisingly well if they've been stored in a reasonable location.
Offline bitseeker
« Reply #153 on: August 25, 2017, 10:44:48 pm »
It's been a few years since I fired up my old Atari 8-bit machines, but some of those floppies are from the late 80's and still worked fine. Good longevity, indeed.
« Reply #154 on: August 25, 2017, 11:32:03 pm »
Good stuff, just make sure you clean the drive heads with IPA frequently as the discs can get gunk building up on them.
« Reply #155 on: August 25, 2017, 11:33:47 pm »
It's been a busy week building parts - I've build and sent the following orders for EEVB Forum members:
DavinD ISA/r Adapter x1
EMan - ISA /r adaptors x2
plus I've shipped at least 9 adapters and all 4 of the spare Floppy adapters I built to members of the VCF forum.   8)
Offline bitseeker
« Reply #156 on: August 26, 2017, 12:39:03 am »
Very cool. So, what's next?
« Reply #157 on: August 26, 2017, 01:37:24 am »
I'm still designing a clock board for the EX and trying to work out how to make a riser board with ram and maybe DMA on it. I haven't had much time to work on either as I've been busy building the PLUS-ISA/R boards.
Offline bitseeker
« Reply #158 on: August 26, 2017, 03:05:46 am »
No worries, was just curious.
« Reply #159 on: August 26, 2017, 03:56:15 am »
Curiosity is always welcome.  :-+
The clock board is done electronically but I'm still sorting the physical properties out.
« Reply #160 on: September 09, 2017, 03:58:46 am »
Well I'm a happy bunny, got PCB v2 of the Printer Adapter yesterday and now that I have the wiring around the right way (not mirrored) it actually works!  :-+
https://youtu.be/rYrEzZlc1iI
Tandy 1000 Printer Port Adapter
Is $21 USD + $5 USD shipping (inc paypal fees)
AFAIK, these are not compatible with the original 1000, A, and HD models.
Offline bitseeker
« Reply #161 on: September 09, 2017, 07:50:01 pm »
Very cool! Congrats! :-+
« Reply #162 on: September 09, 2017, 09:38:59 pm »
Thanks mate.
I did a quick video tour of my Tandy, hopefully it's not too painful to watch.
https://youtu.be/St8Nx7iHA2o
Offline bitseeker
« Reply #163 on: September 09, 2017, 11:04:31 pm »
Thanks for the tour. The video sync relative to the screen was pretty good. The video looked fine considering you were holding a phone. The only problem was the audio level dropped significantly after the bit where you showed the printer port and floppy adapters.
Now, I want to go play all the Space Quest games. It's been many years.
« Reply #164 on: September 09, 2017, 11:13:12 pm »
No worries.
Bugger I thought I'd audio level'd the entire video, I must have only done bits.  :palm:
next time I'll use my Camera on a tri-pod, that should be much easier.
The Space Quest series is just brilliant, I never get sick of it.  :-+
Offline bitseeker
« Reply #165 on: September 10, 2017, 05:25:13 am »
My brother and I lost many hours of sleep thanks to SQ. Good times.
« Reply #166 on: September 10, 2017, 05:45:26 am »
Lol same here, my sister and I put many many hours into all the sierra quest games.  ;D
« Reply #167 on: September 10, 2017, 09:53:42 pm »
Just updated the video, hopefully the low sound issue is better now.
Offline bitseeker
« Reply #168 on: September 10, 2017, 10:24:44 pm »
Yes, audio is much better now.  :-+
« Reply #169 on: September 10, 2017, 11:06:49 pm »
Awesome, I've never used iMovie before so didn't realise the audio adjust isn't global, it's per segment which does make sense.
Offline DavinD
« Reply #170 on: September 14, 2017, 10:12:16 pm »
Love the video.  Got my boards a couple of days ago and they work great!  I do hope you get the clock chip going at some point.  My favorite game on the Tandy was Starflight.  Spent many hours on that one.
The following users thanked this post: djos
« Reply #171 on: September 14, 2017, 10:22:05 pm »
Fantastic!
The PCB's have shipped and I have all the parts for the smart watch design so we'll find out if my first active PCB works soon enough. :)
« Reply #172 on: September 14, 2017, 10:40:54 pm »
I got a Gotek Drive yesterday and promptly flashed it with the HxC Firmware after soldering on the required header pins. I'm planning to replace the segment display with a mini OLED display - for now tho it fits great into my empty Tandy external drive shell. That said I do need to replace the the Floppy power lead on the PCB with a longer one.
Offline DavinD
« Reply #173 on: September 14, 2017, 10:46:49 pm »
I ended up ruining 2 of the Gotek drives trying to solder and flash myself.  I think my iron is just old and dirty (or I just suck at soldering).  :)
So, off to ebay I went to buy one already flashed.  lol
I installed mine in place of the internal floppy.
I have a second 1000ex that I'm leaving bone stock.
« Reply #174 on: September 14, 2017, 10:52:26 pm »
Lol, I just hold the pins in place with Kapton tape while soldering and that makes it easy. I've got a hobbiest grade station which is actually pretty darn good considering how affordable it was ($250 AUD including desoldering station).
Because the Tandy can switch Floppy boot drives so easily I'm not going to bother replacing the internal drive, I did consider a 3.5" transplant tho.
