Author Topic: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project  (Read 96292 times)
Offline DavinD
Re: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project
« Reply #175 on: September 19, 2017, 05:02:34 am »
Question for you, Did you have to do anything special to get your IDE-CF adapter to power from the bus?  I can get the lights to come on, but it always hangs when the bios says Booting C.  It works fine when I connect the power cable.  I tried all combination of the 3 jumpers.  Not a huge deal as I just used a splitter, but it would be nice to have one less cable in there.
Also, if someone comes across one of the Tandy monitor stands that holds the monitor over the top of the PC, let me know.  I'm looking for one.
Offline djosTopic starter
« Reply #176 on: September 19, 2017, 06:23:25 am »
You need to supply 5v to Pin 20 (aka the "Key Pin") and the both your IDE cable (if using one) and adapter need to support power via pin 20. UDMA IDE cables dont have the Pin 20 connected (the ones with a blue IDE connector).
Some of the adapters out there are just crap and dont properly implement IDE - see the post below for pics of the ones that dont work and the ones that do:
https://www.eevblog.com/forum/vintage-computing/tandy-1000-exhx-plus-expansion-to-8-bit-isa-riser-card-project/msg1233022/#msg1233022
and here is a link to eBay for the working CF adapters which also support 5v on pin 20:
http://www.ebay.com.au/itm/Compact-Flash-CF-To-3-5-40Pin-IDE-Bootable-Drive-Adapters-Converter-Card-/182734576729?epid=2208588899&hash=item2a8bd45c59:g:UaMAAOSw~iRZodiz
Btw, some flash cards are a bit hit and miss too - I actually use a Seagate ST1 4GB CF Microdrive which has perfect compatibility due to being a real hard drive in miniature form. In terms of Flash cards, I found the most compatible are the Transcend "Industrial" CF cards.
« Reply #177 on: September 19, 2017, 06:31:13 am »
I was really lucky, I found one on eBay and it cost me almost as much as my EX did (Shipping from the USA was the killer).
« Reply #178 on: October 14, 2017, 06:54:13 am »
So I finally got some time to myself if the Workshop and built one of my SmartWatch+ boards up.
Report:
Physical Fit = Perfect!
Tandy BIOS still works = YES!
SmartWatch chip sets the time = FAIL! Utility Crashes the machine. (utility works ok with OEM SmartWatch)
I need to spend some time with my DMM and the schematic to see if I've fk'd up something - although it could be a dud Dallas DS1216 too. I'll remove the current one and put a socket in for testing.
« Reply #179 on: October 21, 2017, 08:09:18 am »
So I found an error in my clock boards power setup - it supports 2 batteries and I wired them up wrong and as a result I think I blew all my Dallas DS1216's up before I twigged to my error. So I've ordered some more and I'll see what happens then.   :palm:
In the mean time, some OLED's screens arrived and my Gotek HxC got a very nice little upgrade today!  :-+
Before:
Testing:
After:
Offline bitseeker
« Reply #180 on: October 21, 2017, 07:15:48 pm »
That's a snazzy upgrade. Now, all it needs is a mode with large track number display — for when you get older. ;D
« Reply #181 on: October 21, 2017, 08:34:36 pm »
Yeah I can crank up the display settings, just haven't worked out how yet. The firmware sports a bunch of different resolutions and you can configure the number if display lines too.
Offline bitseeker
« Reply #182 on: October 21, 2017, 09:17:11 pm »
Neat!
« Reply #183 on: October 28, 2017, 10:14:20 pm »
I thought I'd try an experiment using my Tandy 1000 EX, with one of my Edge-to-DB25 Printer adapters, to see if it worked with a Covox Speech Thing clone! :D
https://youtu.be/Q0OfISezrsU
« Reply #184 on: November 03, 2017, 07:06:01 am »
Tandy 1000 EX SmartWatch+ Project Update:
So after quite a bit of trouble shooting, I realised I had made several fundamental mistakes.
1/ the DS1216 needs to intercept the data lines etc from the BIOS ROM, not just need to be connected to them.  :palm:
2/ My dyslexia had kicked in and I'd confused some of the pins due to my upside-down design and a couple of traces where simply connected up wrong.  |O
anywhoo, I've ordered some V1.0 editions from elecrow to test.  :-DMM
Offline bitseeker
« Reply #185 on: November 03, 2017, 09:07:59 pm »
Nah, I think that's just the southern hemisphere abnormality effect. :-DD
(You know I had to ;D)
« Reply #186 on: November 03, 2017, 09:51:18 pm »
 :-DD yep, happens all the time, I'm just lucky my pet kangaroo wasn't around during the design phase or I'd prolly have a broken MacBook too.  :palm:
 :-DD
Offline bitseeker
« Reply #187 on: November 03, 2017, 11:03:21 pm »
Yeah, for sure.
« Reply #188 on: December 14, 2017, 10:32:28 am »
Hi all, I promised the community that once I'd made the 50 (yep 50!) Tandy 1000 EX / HX PLUS-ISA/R v1.1 adapters I needed to use up the parts I had to bulk buy, (to keep costs down), I'd release the Gerber files with no strings attached.
So here they are ... I'm making no demands on how you use them, they are now 100% Public Domain.
https://www.dropbox.com/s/3mu8zdts7im36rc/Tandy%201000%20ISA-PLUS%3AR%20v1.1.zip?dl=0
« Reply #189 on: January 14, 2018, 12:48:55 am »
I've made another video showing a the new OPL2LPT Parallel port Adlib Card and a Covox Speech thing clone working on my 1000 EX, I hope you enjoy it.
https://youtu.be/jVgY7fRG0Vs
Offline bitseeker
« Reply #190 on: January 14, 2018, 05:53:42 am »
Yeah, the OPL2 has a lot more punch than the Tandy sound, but what the soundtrack is really missing for the Tandy is a percussion track.
Is the OPL2LPT that you assembled the same kit that the 8-bit Guy reviewed?
« Reply #191 on: January 14, 2018, 06:20:58 am »
Quite true mate, although the OPL2 has the advantage of being at least a few years newer than the Ti chip used by Tandy and the PCjr.
It's the very same kit, I ordered mine from Europe tho as I didn't realise 8 bit guy was selling them until later.
Offline DavinD
« Reply #192 on: January 25, 2018, 05:50:04 pm »
Any update on the smart watch board?  My plus adapter is still working great.
Also, here's one for you guys.  I'm looking to do a pretty crazy project with a 1000HX.  I'd like to get an adapter to use the internal keyboard hooked to a motherboard with a PS/2 port.  I'm pretty sure the protocols are different, so some kind of micro controller would be involved.
« Reply #193 on: January 25, 2018, 09:37:29 pm »
I've been busy with other projects but I'm going to redesign it it. I wss trying to take shortcuts and design it in the PCB designer and as a result I keep making silly mistakes. I'm gong to take the time to design the schematic properly first.
Nice, that should be an interesting project.
Offline james_s
« Reply #194 on: January 25, 2018, 09:59:12 pm »
Lol, yeah clone 386 boards are hardly collectable.  ;D
You might be surprised. I would expect to get at least $50 for one of those boards, how often do you see them for sale? Most of them got thrown out, the few that remain tend to command higher prices once you find someone who needs them.
I remember when people were buying complete Apple II's for a few bucks each at thrift stores to harvest parts. Now a working one fetches a couple hundred bucks.
« Reply #195 on: January 26, 2018, 12:11:35 am »
Good point, I never did harvest it for parts so i might see if I can repair the damage and get it going.
Offline DavinD
« Reply #196 on: January 28, 2018, 07:15:46 am »
Turns out the keyboard itself in the 1000HX I'm using for this new project doesn't have a controller built in.  Looks like pressing a key simply completes a circuit between two pins on the ribbon cables.  I should be able to do something with an arduino to make it work.  Anyone know what kind of connectors are on the motherboard for the ribbon cables?  I'd like to find some online, but I have no idea what they're called.  As a last resort I guess I can un-solder them from the MB.
« Reply #197 on: February 28, 2018, 07:48:58 am »
I did some looking about and it's in the "IDC" Class apparently - couldnt find much more than that.
Btw, I sent of my latest PCB design for manufacturing, it's an external Drive adapter for the EX / HX machines and re-uses the cable & 1 edge connector adapter I made to replace missing floppy drive cables. The main point of it is to allow folks to hook up a Gotek Virtual Floppy drive for those without an external Tandy drive chassis. It will work with real floppy drives too, as long as they support being configured as DS1 (most PC drives are fixed to DS0 and cant be changed).
« Reply #198 on: March 02, 2018, 12:43:18 am »
Due to continuing demand and the time consuming nature of building the PLUS-ISA/R adapters, I got my PCB maker to build 50 Adapters for me, it bumped the price up a bit but saves be a HUGE amount of time!
Anyhoo, they arrived yesterday!  :D
If anyone would like 1 or 2 (most folk buy 2, 1 for each Ram expansion socket), please PM me your order with email address and I'll send you an itemised PayPal invoice, they are $19 USD each + $5 USD for shipping.
For those who would prefer to buy the Adapters via eBay - here's the link (it's in Australian $ but converted = ~$23.34 USD + $7.75 USD shipping):
http://r.ebay.com/HG9Gcu
Offline bitseeker
« Reply #199 on: March 02, 2018, 01:00:42 am »
Congrats on your volume getting to the point where you want/need to have them assembled. Neat.
