Folks!
I've got SW version 2.39 the other week from qihe, now the upway camera can't position the IC any more. It moves the component visually to the center, spinns it into the correct position, even if I misplace rotation on the component tray, it rotates it to correct position. Then the head moves out of the center in down direction on the screen. It continues to do so until it reaches the physical sensor switch and fires an error window. I`m not usinmg the camera for ICs frequently so I have`n recogniced it before. Any idea what I can do? I checked the various screen shots here in the forum and in the documentation to figure out what I`m doing wrong. I`m sure it is a config problem - so who has a hint for me?
Thanks
-AH-
