These are V2.39 Update log.
If you want to know more,you can connect this e-mail:[email protected]1、Modify the BUG that the data “Angle” which is in the list “Sub Pcb Reference Point Pos” didn’t have any effect;
2、Add one new algorithm for the recognition function of mark point :“Image Template”.And optimize the interface.
(1)、The “Size” in the “TemplateParam” corresponds to the size of the Red Box in the Down Vision.And select the appropriate image as the template by adjusting the red box size.
(2)、Click the button “Get” to get the image template of Mark.
(3)、Click the button “Test”。The Bule Box is the image which matches the image template. Below the vision screen,“OffsetX” and“OffsetY”reflect the offset of the matched template.
(4)、The data of “ImageMark” are saved to the CSV file.
3、Optimize the interface:
(1)Move the interface of “Run”“Manual”“Auto”;
(2)Add a quick menu of “PcbArray”;
(3) Add the button which could switch the Vision;
(4) Modify the method of change the speed,now use the button to add and subtract the speed.
4、Optimize the function of “PcbArray”, and the components in the list of each board are independent and can be changed manually.
About V3.10
1、Modify the BUG about “Aimed With Camera”;
2、Add the function that the Z Axis could return to the origin home,and check all the time if the Z Axis is at the origin home.
