Author Topic: Pick and Place Machine TVM802A / TVM802B  (Read 477963 times)
Offline crunch_tone
Re: Pick and Place Machine TVM802A / TVM802B
« Reply #825 on: June 19, 2018, 12:24:10 pm »
After one year of using this machine, one of the pumps stopped working. Sticker on the pump tells me that it's Parker / Hargraves PN: D861 - 22 - 01. I tried to find it on the official web site using this PN, but nothing was matched with this request. Has anybody meet the same problem? Have you tried to find any replacements? Need to say, that I don't want to use external pump at this moment.
You can connect our aftersale to buy the pump.
E-mail:[email protected]
Thanks for your response. I've written to your e-mail just.
Offline qihe_kim
« Reply #826 on: June 20, 2018, 12:14:52 am »
You are welcome.My colleague has already replied to you.Hope your question will be solved.
Offline qihe_kim
« Reply #827 on: June 20, 2018, 12:55:11 am »
talk to qihe via skype, that's the fastest way to reach them
Any question about TVM802A/B can connect the aftersale.
Provide free technical support.
Skype ID:huang
E-maill:[email protected]
Offline Gary.M
« Reply #828 on: June 20, 2018, 09:09:42 am »
What is the TVM802D? What does the D model mean?
Offline qihe_kim
« Reply #829 on: June 21, 2018, 02:35:12 am »
The TVM802D is the same as the TVM802B.
Offline TJ232
  • www.esp8266-projects.org
    • ESP8266 Projects
« Reply #830 on: June 21, 2018, 04:01:13 am »
Great, but what's the difference between. If I want to buy one, why I should choose a B or a D.
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline Gary.M
« Reply #831 on: June 21, 2018, 04:25:04 am »
Why do you have two different names for the same machine?
Offline qihe_kim
« Reply #832 on: June 21, 2018, 05:11:49 am »
In the beginning,the software of TVM802B language is Chinese,and the software of TVM802D language is English.
Later, in order to unify the model, TVM802D was changed to TVM802B.So the model of machine is same.
Offline qihe_kim
« Reply #833 on: June 21, 2018, 05:30:40 am »
You can only buy the TVM802B now,because we unified the model.And the TVM802A/B had made a lot improvements and upgrades.Also now we have the new model TVM802AX/BX.You can learn about them through this link:https://www.alibaba.com/product-detail/New-style-automatic-led-assembly-pcb_60694587058.html?spm=a2700.7724838.2017115.1.8f3744a4UmFq1o&s=p
Offline Gary.M
« Reply #834 on: June 21, 2018, 06:18:40 am »
Ok, thank you for for your reply. The new models have built in computer, is that all?
Offline qihe_kim
« Reply #835 on: June 21, 2018, 06:24:24 am »
Yeah.
1.Built in computer.
2.High voltage drive.
Offline qihe_kim
« Reply #836 on: June 28, 2018, 07:20:16 am »
From research and development to the present, we are constantly improving the TVM802, including hardware and software modifications and upgrades.Our software version is from 1.XX to the current 3.XX, but if you are using 2.XX version software, you can upgrade to the latest 2.39 version, but can not use 3.XX.Because the hardware of 2.XX machine  is not the same as 3.XX.In the latest software, we have perfected some defects and added some features.If you want to get the latest software and know more,you can connect to our aftersale.The e-mail address :[email protected].
Also you can visit our website to know more about the latest machine:www.qhsmt.com
Offline qihe_kim
« Reply #837 on: June 28, 2018, 08:06:56 am »
These are V2.39 Update log.If you want to know more,you can connect this e-mail:[email protected]
1、Modify the BUG that the data “Angle” which is in the list “Sub Pcb Reference Point Pos” didn’t have any effect;
2、Add one new algorithm for the recognition function of mark point :“Image Template”.And optimize the interface.
 (1)、The “Size” in the “TemplateParam” corresponds to the size of the Red Box in the Down Vision.And select the appropriate image as the template by adjusting the red box size.
(2)、Click the button “Get” to get the image template of Mark.
(3)、Click the button “Test”。The Bule Box is the image which matches the image template. Below the vision screen,“OffsetX” and“OffsetY”reflect the offset of the matched template.
  (4)、The data of “ImageMark” are saved to the CSV file.
3、Optimize the interface:
 (1)Move the interface of “Run”“Manual”“Auto”;
(2)Add a quick menu of “PcbArray”;
 (3) Add the button which could switch the Vision;
 (4) Modify the method of change the speed,now use the button to add and subtract the speed.
 4、Optimize the function of “PcbArray”, and the components in the list of each board are independent and can be changed manually.
About V3.10
1、Modify the BUG about “Aimed With Camera”;
2、Add the function that the Z Axis could return to the origin home,and check all the time if the Z Axis is at the origin home.
Offline qihe_kim
« Reply #838 on: July 03, 2018, 01:21:20 am »
I am very honored to communicate everything about TVM802 with everyone here.This is a public platform that can ask questions and leave suggestions.At present, the hardware and software of TVM802 are continuously updated and upgraded, so as to better meet the needs of customers.Thank you very much for your valuable suggestions.
The following users thanked this post: crunch_tone
Offline ubbut
« Reply #839 on: July 09, 2018, 12:06:16 pm »
Hi
I am going to buy a TVM802B and I am now talking to someone from
https://www.zjyingxing.com/ on skype.
They are now asking for a deposit via paypal which I find a bit strange.
Is this legit? Anyone bought it there?
Thanks a lot!
Offline qihe_kim
« Reply #840 on: July 10, 2018, 04:56:01 am »
Hi
Thanks a lot!
Hi,yingxing is one of our agents.You can buy the machine from them,and the machie is produced by our company.We will also provide follow-up services.
Offline ubbut
« Reply #841 on: July 10, 2018, 09:13:10 am »
Thank you for the confirmation, looking forward to work with the machine
Offline ubbut
« Reply #842 on: July 20, 2018, 09:30:45 am »
I am having a couple of issues setting up my TVM802B. It is a newer model with firmware 3.09.
- When turning it on there is a very loud hum, even when the safety switch is in stop mode. It's not the pump I think, because I can turn that on and off in the software. Is this normal? Sounds like transformer hum. This is on 220V.
- USB recognized one camera as STK1160. There are no further cameras unlike stated in the user manual.
The driver supplied is for a STK1150, so windows 7 would not install this one. I installed a driver for STK1160. Both cameras work with the viewer tool included in the driver, but not with the PnP software.
In the software I can only see a red cross on black background
thank you
Offline ManuFerHi
« Reply #843 on: July 20, 2018, 10:07:21 am »
Hi ubbut.
In the setting/camera menu you have a tab that you can choose the serial number cameras, unfold the menu and choose the correct serial.
Offline ubbut
« Reply #844 on: July 20, 2018, 10:32:29 am »
Hi ubbut.
Thanks. I am unable to find this setting somehow? Where is it?
Offline ManuFerHi
« Reply #845 on: July 20, 2018, 12:05:15 pm »
Sysconfig / Camera
Offline ubbut
« Reply #846 on: July 20, 2018, 12:44:53 pm »
Looks different in my version of the program :(
Offline qihe_kim
« Reply #847 on: July 21, 2018, 02:31:49 am »
Hi ubbut,
There is no serial number cameras in the V3.09 software,you just need to install the camera driver correctly,and then the camera will work.
Please check the e-mail I replied to you.
And the sound is normal.It cames from positive pump,and it is on 220V.
Offline [email protected]
« Reply #848 on: July 29, 2018, 02:31:44 am »
My TVM802B is constantly generating "X-Axis Into Positive Limit" alarms. The unit is now almost unusable.
Does anyone have a service manual or schematics so I can troubleshoot the problem?
What is the part number of the photo interrupter? I suspect the problem is related to noise, but it will be helpful to know which part is used.
If it is a noise problem, I'd like to desensitize the detection circuit so it will be more immune to noise spikes.
Thanks,
Mike
« Reply #849 on: July 29, 2018, 02:33:28 am »
Is there a bug in the new v2.39 software? After using the "Prick MoveTo" function a few times the prick stops functioning and the unit needs to be power cycled to fix it.
Anyone else seen this problem? BTW, the new software is great. It adds a lot of new features.
Thanks,
Mike
