There are some potential uses for this technology but yeah, the marketing wanker bull$#!t is great with this one!
Applications:
1. remote controls (TV, radio, garage door opener, etc):
- intermittent use, it would have enough time to "charge" the supercap in-between
- fairly low power consumption during utilization
- right now can retrofit existing remotes with their AA or AAA batteries
- unlikely to be able to fit into coin-cell format (which many remotes also use)
- maybe in the future will integrate into remote control PCB's
- however, do you really care if your remote battery lasts for 300 years?
2. low-energy bluetooth type devices (keyboards, mouse, sensors, etc)
- the key is the energy charging vs. discharging (through use) curve
- battery can come fully charged, and yes it will slowly discharge with use...
but will the "trickle" charge produced by the piss-ant 100 uW power source
be enough to keep up with the typical usage of the device?
3. smart watches, calculators, memory
- today's smart-watches (except for ultra-high efficiency) need a fair bit of energy
- most fitness watches with heart rate monitors and any sort of connectivity to
your phone use a lot of power
- a simple digital watch or even mechanical without many features may work
(my Casio sports watch features a 10-year lithium battery, will an NDB fit inside?)
- perhaps a supercap to charge in the background to power the light button when
you want to illuminate the watch
- calculators that can operate on uW source can operate on a solar cell, so
unless you want to work in the dark (in which case you still need a light source)
is there any advantage to an NDB or why not just use a solar panel on the calculator?
- memory rention/refresh/backup power source, not so much an issue today with Flash
4. biomedical devices
- advantage to not having to replace batteries or require surgical replacement
- potentially back a device with enough NDB's and supercaps to match the energy
usage of device/monitor/log so that it can stay in longer than the human lifespan
- of course, with medical technology advancing it may not be practical using an old device
5. emergency LED lighting/flashlights/radios
- say a 3.6 V LED with current of 20 milliamperes will use 72 milliwatts of power
- you would need 720 of the 100 uW NDB's just to keep 1 LED on indefinitely
- a simple handcrank could be used intermittently to charge up a supercap
and light up an LED/radio emergency flashlight for minutes
- ...again... no practical purpose for an NDB chip
I still can't think of a practical use for these things. They need to pack 100x more radioactive stuff into those chips and bring us up to maybe 10,000 uW (or 10 mW output) to get somewhere more practical. I read on a forum that a small solar-cell from a solar-cell-powered calculator will show 2 volts at less than 5 milliamps, or 2V * .005A = 0.01 watts (10 milliW)... or 10,000 uW, which is 100x more than this 100 uW than the NDB chip. So if they can increase the power output by 100x to what they have now, *MAYBE* it will have some practical use in a solar-cell-powered calculator and some other devices.
Total marketing bull$#!t, right on. When will they even learn?
Hey what ever happened to the Thorium-powered car?
