Finally, the circuit does not understand what is called "ground" - so the loop area matters.By "ground", I was referring to the potential at the so-called GND pin on that IC, and at the power supply return, nothing more.
As long as the other end of the capacitor has that same potential, and it does not vary at short timescales, no current flows in or out of the capacitor end at that potential. The capacitor is not part of a current loop — no current flows across the capacitor, only across the end that has a varying potential on it —, so why would the area of some loop dictated by the capacitor be significant? Other than as a source for coupled noise from elsewhere, that is.
But of course current flows through the capacitor.
I fully admit I could have the physics of capacitors wrong, being unable to verify this in practice for myself. Practice always trumps theory.
At the moment I'm looking at an FPGA for a high speed design. In the hardware design manual, the manufacturer is very specific about the decoupling capacitors to use:
This is not by chance or rule-of-thumb. These values have been obtained by analysis of the chip, package and circuit board layout. So if you adhere to the design guidelines and power supply routing examples, you'll very likely end up with a design which is pretty close to optimal given the design constraints.FPGAs are one of the most well documented parts for this purpose, because designing with these parts depends a lot on the chip floorplan and switching activity. Some customers will need to be able to verify their own custom design.
If you want to get any accurate power figures of a modern FPGA, you basically need to have your core design finished, with switching activity stimulus supplied, and only with this information a proprietary tool will spit out the most accurate figures of power supply requirements. Indeed, there is no rule of thumb, but there is also no omniscient appnote that will do this work for you.
The datasheet for this PolarFire FPGA specifically says:QuoteDecoupling capacitors other than those listed in the previous tables can be used if the physical sizes of capacitors meet or exceed the performance of the network given in this example. Substitution would require analyzing the resulting power distribution system's impedance versus frequency to ensure that no resonant impedance spikes the result. See Figure 1-1 for power supply design.Or in other words: exceed these specs, verify substitutions. The 2nd table from your list is described as "Recommended Decoupling Capacitors For PolarFire Devices". There are still some values missing, which means that all designs require some amount of substitution or eyeballing, still.
Other chips may not be so well off. There are also plenty of appnotes out there for MCUs, MPUs, etc. that use the "100nF on every VDD" whilst supplying no information about the on-chip decoupling measures, the ripple specifications, layout, etc. Yet still the processor is switching at the best part of a GHz and comes in a LQFP-64 package I could even shove into a breadboard when I solder it to an universal breakout board (bad idea).
Most if not all modern (high speed) microcontrollers have internal regulators. So the sensitive power integrity is handled inside the package entirely. The I/O section is about the only functional group powered by the external supply. This makes the decoupling requirements not so strict which is good as many microcontrollers end up on 2 layer or even single layer boards.
I fully admit I could have the physics of capacitors wrong, being unable to verify this in practice for myself. Practice always trumps theory.A capacitor is a two terminal device, current must flow through it for it to have any effect at all. As Siwastaja says, if there is no current interacting with the capacitor it can be removed with no effect.
Recommendation of 0.1 μF (100 nF), in parallel with a 1000 pF (1
nF), 10-20V. These capacitors should be low-ESR and have a resonance frequency in the range of
20 MHz and higher. Ceramic capacitors are recommended.
If the board is experiencing high-frequency noise above tens of
MHz, add an additional ceramic-type capacitor in parallel to the decoupling capacitors. The value
can be in the range of 0.01 μF to 0.001 μF. Place this capacitor next to the primary decoupling
capacitors. In high-speed circuit designs, consider implementing a set of capacitances as close to
the power and ground pins as possible. For example, 0.1 μF in parallel with 0.01 μF and 0.001 μF.
No, do NOT ignore the manufacturer's recommendation. They very likely have done extensive simulations and testing to optimise power integrity as part of the chip design
I fully admit I could have the physics of capacitors wrong, being unable to verify this in practice for myself. Practice always trumps theory.A capacitor is a two terminal device, current must flow through it for it to have any effect at all. As Siwastaja says, if there is no current interacting with the capacitor it can be removed with no effect.Ah, this is one of these tricky matters. Dave actually talked about it in a now old video:
For the practical purpose of designing electronic circuits, the subtlety usually doesn't matter too much, but it's still an interesting point.
In a related vein, you can also have a look at this long thread: https://www.eevblog.com/forum/chat/veritasium-(yt)-the-big-misconception-about-electricity/
In case anyone wonders about it, I was applying the electrostatic model — as in, what happens when you have two isolated charged conductors and bring them to contact — to decoupling capacitors. The no-current part is based on perfect dielectric model. It is not at all what happens when a capacitor is part of an electrical circuit (and indeed the links SiliconWizard included discuss the correct model).
Current cannot enter and exit a single terminal without an equal and opposite current appearing elsewhere.
Your use of the term current is fundamentally wrong.
I used the wrong model and approach, the electrostatic one, instead of electric circuit models. Yes, that was stupid of me, and a fundamental error, but one of applying the wrong model to the problem at hand, not a "clever word game" or "reframing".
Edit: Someone with the test equipment needed could test this in practice, by using two current-sense resistors before and after a capacitor, and a single-ended signal generator connected to one end, the other end to the common "0V" or "GND" reference potential, and some (much larger) load resistor in parallel with the resistor-capacitor-resistor assembly. You should see the signal only on the sense resistor directly connected to the signal generator, with the voltage on the sense resistor on the other side of the capacitor being basically the "0V" reference potential. I fully admit I could have the physics of capacitors wrong, being unable to verify this in practice for myself. Practice always trumps theory.
relating to stationary electric charges or fields as opposed to electric currents
We have righty pointed out this is incorrect by using clear arguments falsifying your claims.
We have righty pointed out this is incorrect by using clear arguments falsifying your claims.You obviously missed me pointing out I was wrong in #52. Perhaps the concept of someone admitting they were wrong before anyone else noticed or commented on it is utterly alien to you?
But you’re still arguing something something something wall of text ? ? ?
ESD and lightning discharges do have a closed loop of current.
And I still haven't gotten a single reply on whether it suffices to minimize the VCC-to-bypass capacitor distance, or whether one should consider the bypass-to-ground distance also, in practice.
But of course current flows through the capacitor.No. A capacitor stores charge; the movement of charges is the current; and the cause for the movement of charges is a change in the potential.
They very likely have done extensive simulations and testing to optimise power integrity as part of the chip design and that resulted in the recommended values.
So, when the vendor says:QuoteRecommendation of 0.1 μF (100 nF), in parallel with a 1000 pF (1
You wish
Some may have. In reality, example circuits are usually just "good enough". Heck, it is completely normal that application examples are not even working properly.
This whole capacitor thing is typical example of cargo cult.
You wish
No, do NOT ignore the manufacturer's recommendation. They very likely have done extensive simulations and testing to optimise power integrity as part of the chip designThe obvious errors found in datasheets indicates "very likely have done" is quite optimistic. It may be so in some specific manufacturers' specific product lines, but I'm much less convinced it is true in general. For many cheaper microcontrollers, decoupling capacitor recommendations seem to be based on some random engineer saying "I tried 100nF and it seems to work, so let's recommend that in the datasheet".
