Author Topic: What's this please? (Component Advice)  (Read 1560632 times)
Offline fluxcapacitor
Re: What's this please? (Component Advice)
« Reply #375 on: September 16, 2013, 10:12:47 pm »
I am thinking it's a regulator, part that says GGRTW which I can't find on google.
What is the pcb from ? + model name/number on pcb etc .
Offline Alexei.Polkhanov
« Reply #376 on: September 16, 2013, 11:49:49 pm »
Wow, lovely sensors they have - MS5805 includes 24 DAC with 15 cm altitude resolution. :-)
Offline mikec
« Reply #377 on: September 22, 2013, 09:59:01 pm »
Ok so this component is a capacitor I am pretty sure of that, however I have no idea what type of capacitor. Doesn't look like any electrolytic or ceramic capacitor I have ever seen.
« Reply #378 on: September 22, 2013, 11:43:41 pm »
what is the pcb from ? make/model might help if theres a schematic.
Offline Rufus
« Reply #379 on: September 23, 2013, 01:07:42 am »
It is a polyester film capacitor mostly (if not exclusively) made by EPCOS.
« Reply #380 on: September 23, 2013, 03:25:55 am »
Yes very much like it. I wonder who painted the sides with blue paint?
« Reply #381 on: September 23, 2013, 08:33:46 am »
Theres some datasheets here:
http://www.epcos.com/web/generator/Web/Sections/ProductCatalog/Capacitors/FilmCapacitors/MetallizedPolyester/Page,locale=en.html
The caps are ,radial Boxed,radial uncoated ,radial coated etc and a note in one the datasheets about mounting -
Notes on mounting
When mounting these capacitors, take into account creepage distances and clearances to
adjacent live parts. The insulating strength of the cut surfaces to other live parts of the circuit is
1.5 times the capacitors rated DC voltage, but is always at least 300 V DC.
That could be why theyve been "painted"  ?
« Reply #382 on: September 23, 2013, 06:12:17 pm »
The painting is just the "extra protected" version. Those generally are nice capacitors, and are made on a large wheel and then cut to size before final lead attachment.
Offline chicken
  • Rusty Coder
« Reply #383 on: September 25, 2013, 03:59:58 pm »
What are the components in the metallic packages? I never noticed them before.
The packages look like oscillators. But the components are used in power supply related context (big inductors and caps), which I think eliminates that possibility. What else? Fancy caps? Tiny transformers?
Source: 27" iMac teardown on iFixit
http://www.ifixit.com/Teardown/iMac+Intel+27-Inch+EMC+2639+Teardown/17828/1
Offline chicken
  • Rusty Coder
« Reply #384 on: September 25, 2013, 06:48:31 pm »
Ok, I think I figured it out: International Rectifier DirectFET MOSFETs
http://www.irf.com/product-info/directfet/
Offline N TYPE
« Reply #385 on: September 27, 2013, 02:20:39 pm »
Hi can anybody tell me what these parts are soldered to the legs of this to92?
Have no idea what they might be called
Offline Codemonkey
« Reply #386 on: September 27, 2013, 02:27:25 pm »
They look like PCB Turrets to me
Offline notsob
« Reply #387 on: September 27, 2013, 11:40:34 pm »
Offline IZ3IJG
« Reply #388 on: October 07, 2013, 11:18:51 am »
Guess what is this
Offline c4757p
  • adieu
Offline JoeO
  • I admit to being deplorable
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline IZ3IJG
« Last Edit: November 05, 2013, 10:52:57 am by IZ3IJG »
Offline PA0PBZ
« Reply #392 on: October 09, 2013, 06:41:20 pm »
Oh! Oh! May I?
The hand drawn part is the rough copy of the silk screen that was under the component. Basically a zigzag in a rectangle. Probably some power component, but I have never seen the symbol, so no idea.
EDIT: added a picture with a ruler. It's about 10mm wide.
What happened to your photos?
My guess: after 2.5 years most bits are recycled and used somewhere else on the 'net?
Offline Fryguy
« Reply #393 on: October 17, 2013, 09:29:36 am »
To me it looks like they are crimped to the to92's legs so i'd say they are contacts for a twist socket like the ones on a fluorescent lamp starter .
I guess the to92 part is a temperature sensor .
« Last Edit: October 17, 2013, 09:33:40 am by Fryguy »
Born error amplifier  >.<
Offline Isaac
  • Country: br
« Reply #394 on: October 30, 2013, 11:21:33 pm »
It's a inductorless SR IC. Its powered from the mains (110/240 V ac). Ok, I know what it is, but i can not identify the part number on the IC. I wonder if someone can identify the IC based on the traces on the pcb. I don't have a better picture of it. It's from the "Moteino"  website.
Thanks.
« Reply #395 on: October 31, 2013, 12:45:19 am »
the picture isnt clear enough.
http://lowpowerlab.com/contact/
Offline Isaac
  • Country: br
« Reply #396 on: October 31, 2013, 02:05:27 pm »
According to the guy, it's a Supertex SR-086 Inductorless Switching Regulator.
Offline edwardcurrentclamps
« Reply #397 on: November 02, 2013, 03:26:42 am »
Hi!
Can someone confirm whether this is a quad positioning sensor or something else?
Appreciate all input!
Thanks
« Reply #398 on: November 02, 2013, 05:38:13 pm »
Uncased 4 quadrant large area photodiode definitely.
« Reply #399 on: November 03, 2013, 12:16:14 am »
Thanks,
any idea where I get something like that? I also wondered, how are you so sure. In what kind of application have you seen something like that before?
Thanks
