Author Topic: The Siglent SDG2042X Thread  (Read 567588 times)
hfleming and 8 Guests are viewing this topic.
Offline tautech
« Reply #775 on: July 15, 2017, 08:47:35 pm »
@ Plasmateur
Sorry haven't got a 2042X ATM but this SDG1032X UI should be the same.
Enter Utility/Interface (Page 2)/LAN State = On (toggle if needed)
LAN Setup/DHCP...........toggle to ON and wait for the IP, SN and Gateway to get auto populated.
Utility = Exit and save
Does yours not do this ?
Online exe
  • self-educated hobbyist
« Reply #776 on: July 20, 2017, 08:09:31 pm »
Hi guys! Is it possible make SDG2042X to remember settings across reboots (except for enabled channels)?
Offline tautech
« Reply #777 on: July 20, 2017, 08:54:42 pm »
Yes of course.
You can find the settings for Power On as Last (used) or Default in the Utilities menu.
The following users thanked this post: exe
Offline pigrew
« Reply #778 on: July 25, 2017, 05:25:41 pm »
Is there a way for the generator to force an external reference (and never change to the internal reference)?
Currently, the frequency reference is switched to internal (with no indication on the GUI) when the frequency reference is turned off. It's too easy to continue using it thinking that the frequency is still locked (and yielding bad data).
Also, I'm worried that when it defaults to internal reference, it is outputting 10 MHz on it's reference output which is directly connected to another instrument's 10 MHz out. Having two instruments outputting 10 MHz into eachother can't be a good thing. I don't know if the hardware supports it, but it'd be nice to tell it to disable the 10MHz output while using the internal reference.
There are a few parameters (like reference mode, screensaver, language, number format, and beeper) that I'd really like to always have saved (irrespective of the "power-on setting"). Maybe as a work-around, there could be an option to load a particular saved configuration on startup(so the choices would be factory default, particular configuration, or last configuration)?
Offline flash2b
« Reply #779 on: July 26, 2017, 09:52:02 am »
I asked for the same thing, but no one reacted.
I am wondering why you cannot see on the screen if the Siglent SDG external clock is switched on or off on the main screen. Siglent did implement the "Phase Lock" lock-icon so they could add another lock-icon next to this for the exernal clock indication. On comparison, the Rigol DG series shows "Ext" on the screen when external clock is switched on.
May be Siglent should add this to the backlog for future firmware, that would be great.
Offline Dwaine
« Reply #780 on: August 10, 2017, 02:10:02 pm »
Wondering if graphing and histogram functionality in the counter function is an option the firmware team can do?
Maybe grab the same code from the DMM firmware.  I was using my SDG2000x last night and wished I had a graph displaying some values.
I think a lot of people would like those two options.
Offline eurofox
    • Music
« Reply #781 on: August 10, 2017, 02:20:31 pm »
I just order one  :-+
Seems it is one of the best generator for the money + 120Mhz hack  :-DD
eurofox
Offline bson
« Reply #782 on: August 10, 2017, 10:27:29 pm »
Even worse, it will start driving the reference port as an output, and when you plug in your frequency standard again it will short.  The direction shouldn't be automatic...  If set to input the instrument can auto detect a signal; if set to output they could auto detect a load (if possible), but the direction itself needs to be a purely manual setting.
Ideally, when set to use an external reference an indicator should be used to show the state of the input.  No pop-ups or dialogs - those are too easy to miss and just annoy.  A simple indicator and possibly a beep the first time it locks.
« Last Edit: August 10, 2017, 10:31:15 pm by bson »
Offline Gary1942
« Reply #783 on: August 12, 2017, 10:17:26 pm »
This is page 32 of this thread. Apologies for not having read all the posts. Also, I could not find a place to ask a service question on siglent.com.
I bought my SDG 2042 from Amazon in February 2016.
I saw some comments on the net about firmware updates. I have never connected my SDG 2042x to the network, so, today I plugged in a network cable and turned it on (it has not been on for at least a month). It reaches the boot logo page and hung there. I left it on for a few hours thinking that it was downloading an update, but half a day later, still the same. I turned it off and back on, still hangs on the Siglent logo with the network plugged in or not.
Any advice?
Offline Dwaine
« Reply #784 on: August 13, 2017, 01:02:50 am »
The firmware update is only by USB.   The hanging when connected by network cable to a router, maybe try and disconnect the Ethernet cable and power cycle the unit. Hopefully it will finally boot successfully.
Offline pigrew
« Reply #785 on: August 13, 2017, 01:28:51 am »
Any advice?
Email the Siglent folks, at the email address listed on this page.
Connecting to a LAN shouldn't cause it not to boot. Firmware updates are only performed when you ask it to load firmware update files from USB flash storage. This sounds like there's a bad component in the unit, or its flash storage has corrupt data.
Offline spidola
  • Country: ua
« Reply #786 on: August 13, 2017, 02:38:53 pm »
My unit came with the 2.01.01.23R5 firmware. This version is not yet available at the official site.
Offline mspec
« Reply #787 on: August 13, 2017, 11:39:38 pm »
I recently purchased the SDG1032X version and was going to give it a go to see if I could try the hack to turn it into the 60 MHz version however telnet is requesting a username and pass. Anybody know what the default for this might be ??
Offline CustomEngineerer
« Reply #788 on: August 14, 2017, 02:54:55 am »
As far as I know no one has figured out the telnet username/password. And since the 1000X came out after Siglent added the username/password to the firmware, I don't know of a way to liberate the 1000X. Good luck though, do let us know if you manage to figure it out.
Offline Dwaine
« Reply #789 on: August 14, 2017, 04:10:53 am »
I wonder what changes are in the new firmware?
Offline tautech
« Reply #790 on: August 14, 2017, 05:26:10 am »
Chasing this ^ up.
Coming back with an edit when I find out.
Offline Qw3rtzuiop
« Reply #791 on: August 14, 2017, 05:46:53 am »
23R5 isnt new. The update can be found at siglent.com. There is also a changelog.
Offline tautech
« Reply #792 on: August 14, 2017, 07:36:18 am »
Link please.
Offline Dwaine
« Reply #793 on: August 14, 2017, 07:46:48 am »
Only 2.01.01.23R3 is listed on the WEB Site?
Offline tautech
« Reply #794 on: August 14, 2017, 07:49:41 am »
Yup.
Haven't got any new SDG2kX's to check either.  :(
Then I wonder if spidola mistyped 5 for 3 ?  :-//
Offline spidola
  • Country: ua
« Reply #795 on: August 14, 2017, 08:42:04 am »
Yup.
No mistake here. The latest firmware is 2.01.01.23R5 and it is not yet available at the support site. Let's see who can find it first  ;)
Offline Qw3rtzuiop
« Reply #796 on: August 14, 2017, 09:01:13 am »
Sorry i made a mistake. I just found 23R3 on the website.
Offline Dwaine
« Reply #797 on: August 16, 2017, 02:13:11 am »
Yup.
I guess we will have to wait until Siglent posts the newer firmware..  Thanks for the screenshot..
Offline spidola
  • Country: ua
« Reply #798 on: August 16, 2017, 03:46:36 pm »
It appears, the next released firmware is going to be 23R6, they skip posting 23R5 ???
Offline eurofox
    • Music
« Reply #799 on: August 16, 2017, 07:08:18 pm »
I got mine today and hack it from 40Mhz to 120Mhz in 5 minutes  :-DD :-+
Very nice generator  :-+
eurofox
