Author Topic: Solder paste/flux manual syringe applicator  (Read 141357 times)
Online PlainName
  • Country: va
Re: Solder paste/flux manual syringe applicator
« Reply #175 on: October 18, 2015, 06:05:03 pm »
It looks right to me. See this datasheet:
http://www.mouser.com/ds/2/185/ed_ZX_20140804-461411.pdf
Note that the part reference is 'RD', which means 'reverser top mount'. The pattern on page 5 of the datasheet is applicable, I think.
Offline zapta
« Reply #176 on: October 18, 2015, 07:43:56 pm »
Where did you pick  up Eagle Cad library file - for this USB connector on your PCB????
I created it myself based on the datasheet of the connector specified in the BOM.
Used the same footprint and connector in previous projects (including data lines) with no problem.
I think the one in the BOM is Hiroshi, not the Molex you looked at.
Offline mike_58
  • LEGO playground
« Reply #177 on: October 18, 2015, 08:31:01 pm »
It is not important Mollex or XY - standard USB cable must work with it and in your case it will  NOT - it will smoke  :-DMM.
see this link and compare your Eagle cad library USB with this one from here :  https://www.sparkfun.com/products/12035 and open Eagle cad file and paste it to your PCB!!
Documents:
Schematic
Eagle Files
GitHub
Mike
Online PlainName
  • Country: va
« Reply #178 on: October 18, 2015, 08:49:39 pm »
Mike, that's a totally different manufacturer. All that matters for the cable is that the pins are the right order for the orientation of the socket. The part that Zapta uses is reversed so that you can mount it on top of the PCB and still have the cable oriented properly (to solve that problem where cables are 'upside down' on some phones, for instance).
Here:
I suggest you  look at the actual datasheet for that actual part from the actual manufacturer, and then you'll see that Zapta's layout is correct. Indeed, his use in other products without the smoke escaping suggets that he knows wtf he is doing with this, doesn't it?
I've attached the relevant diagram from the datasheet (I made a mistake before - it is page 7 rather than 5, but the  footprint is the same anyway). Maybe you could take a look at that before insisting it is something else?
Offline mike_58
  • LEGO playground
« Reply #179 on: October 18, 2015, 09:13:06 pm »
Ok , noted, better I am wrong than PCB !!
Offline zapta
« Reply #180 on: October 18, 2015, 10:02:12 pm »
Mike and anybody else, if the USB connector in the BOM is hard to get or confusing, feel free to change and send me a github pull request (and having a nice manual routing if you feel like).
EDIT:  in this project I am using the micro USB connector Digikey 609-4616-1-ND (different physical footprint) which has the 'other' orientation.
https://github.com/zapta/arm/tree/master/pro-mini/board
In any case, the USB connector should have through hole mounting tab, otherwise the SMD pads peels easily.
« Last Edit: October 19, 2015, 12:47:51 am by zapta »
Offline mike_58
  • LEGO playground
Offline mike_58
  • LEGO playground
« Reply #182 on: October 19, 2015, 11:13:31 am »
and this SMD type of USB here enclosed. (rename ending .txt to .lib)
Offline neslekkim
  • Country: no
« Reply #183 on: October 19, 2015, 12:03:25 pm »
agh, already ordered this board from oshpark, but didn't know that an "special" usb connector was used here, will make sure to order the correct one :)
Offline zapta
« Reply #184 on: October 19, 2015, 03:26:32 pm »
You can download Hirose lib from this link: https://github.com/chiengineer/Eagle-Libraries/blob/11e4a75bc9876ab7e70823fd5aa7b1fb6786185f/Connectors/con-hirose.lbr
and use.
Thanks Mike. I can see a footprint for ZX62R-B-5P but it doesn't have through holes or vias, just SMD peels. From my experience, this will peel easily. My footprint has holes but I still solder it as an SMD part with reflow.
BTW, is there a standard for the orientation of the USB cable connector in relation to the PCB or the outer enclosure of the device? That is, "this side need to be 'up'"?  I had cell phones with both orientation. Personally I prefer the narrow side of the micro usb connector to  be up in the normal orientation of the device.
Offline mike_58
  • LEGO playground
« Reply #185 on: October 20, 2015, 05:38:43 pm »
Hello - SEE WIKI - https://en.wikipedia.org/wiki/USB
See numbering of pins ;
See Eagle which shows this pins ( if enabled in settings of Eagle !!)
Offline mike_58
  • LEGO playground
« Reply #186 on: October 20, 2015, 06:03:22 pm »
And this table of WIKI standard - Green!
Offline zapta
« Reply #187 on: October 20, 2015, 06:29:01 pm »
What's the conclusion Mike, that it doesn't work out that it works but doesn't comply with some part of the USB standard?
Offline mike_58
  • LEGO playground
« Reply #188 on: October 20, 2015, 07:14:59 pm »
Test it - you have the cable and the connector - take some other cable and measure + / - on connector pins.. to make sure it woks with different standard cables..
USB or Universal Serial Bus standard was designed in the mid 1990 to replace old standards like serial or parallel ports.  In our days the USB connector can be found in keyboards, printers, digital cameras, flash drives, external hard drives and almost all peripheral digital equipment.
Until now three USB standards were released:
–          USB 1 released in 1996 with speeds of 1.5 Mbps for Low-Bandwidth and 12 Mbps for High-Bandwidth;
–          USB 2.0 release in 2000 is the most used usb port at the moment at supports a maximum speed of 480 Mbps;
–          USB 3.0 released in 2008 in the latest standard who can support speed up to 5Gbps.
There are 7 USB connector types: type A, type B, Mini-A, Mini-B, Micro-A,Micro-B and Micro-AB. Type A and B has 4 pins, Mini and Micro A and B has 5 pin usb pinout.
Offline mike_58
  • LEGO playground
« Reply #189 on: October 20, 2015, 07:17:42 pm »
Printout -look here
Offline mike_58
  • LEGO playground
« Reply #190 on: October 20, 2015, 07:41:08 pm »
Zapta see this - good view : https://www.pololu.com/product/2592
Offline mike_58
  • LEGO playground
« Reply #191 on: October 20, 2015, 07:42:36 pm »
DIGI - shows your connector like this:
Online PlainName
  • Country: va
« Reply #192 on: October 20, 2015, 08:09:44 pm »
Mike, what are you showing? I am somewhat confused since we know Zapta's original connector has the right footprint, is wired correctly and conforms to all USB standards. Are you  showing a different connector that he should switch to or what?
Offline mike_58
  • LEGO playground
« Reply #193 on: October 20, 2015, 08:25:59 pm »
The question from Zapta was ;
BTW, is there a standard for the orientation of the USB cable connector in relation to the PCB or the outer enclosure of the device? That is, "this side need to be 'up'"?...,
Online PlainName
  • Country: va
« Reply #194 on: October 20, 2015, 08:39:13 pm »
Yes. It is as shown in the photo I posted before:
The USB logo on the connector should be 'up'. You put the standard or reverse connector on the PCB to do that (so the curved part of the connector profile is 'up'). As I noted, particularly on phones and tablets, where the component side of the PCB may be screen side or non-screen side, you often find the connector upside down in relation to the body. The designer should have used the reverse connectors.
An example of the 'wrong' connector being used is the Hudl. In the photo below, the bottom item is the Hudl tablet and the top one is an LG 40 phone.
Offline mike_58
  • LEGO playground
« Reply #195 on: October 21, 2015, 09:31:09 pm »
Zapta - here more lib - Hirose : http://www.diymodules.org/eagle-search?text=Hirose+usb&type=dev%2Cpkg%2Csym&lib=usr%2Cstd&desc=1
And this is the one you are using in part list with trugh holes in pcb ?
http://www.diymodules.org/eagle-show-library?type=usr&id=1012211140.  ?
Offline mike_58
  • LEGO playground
« Reply #196 on: October 28, 2015, 01:53:29 pm »
Offline zapta
« Reply #197 on: October 31, 2015, 05:33:43 am »
Offline zapta
« Reply #198 on: November 09, 2015, 05:10:30 pm »
I just posted the Arduino Motorized SMT Solder Paste Dispenser here:
http://www.thingiverse.com/thing:1119914
Online PlainName
  • Country: va
« Reply #199 on: November 09, 2015, 06:46:39 pm »
Nice. And thanks  :-+
