Ignoring the whole juice DRM, and the fact that hardware relying on external servers is garbage, they buy a high voltage DC motor from a drill motor company and instead of getting them to throw a planetary gearbox that's 1/2 the size of the motor? or using a worm drive for a steep reduction, they put together a fancy custom machined gearbox? Custom power supply for 330v that's inaccessible to the user instead of rectified (and doubled in 120v land) mains? Jeeze these guys sure knew how to stuff, but sure didn't know when or why to do stuff.
In fact, it would have been *easier* to design in the CC3100, since you could just talk to the STM32 via SPI right out of the box. The CC3200 would need to be programmed with some custom firmware to allow it to send data back and forth between the STM32.
Given their locking down of things I'd say that's intentional, that way they can use a non-standard communication scheme to make reverse-engineering more difficult.
Anyway the whole thing is so overvblown it really sounds like it's based on a marketing whiz crunching up some numbers and predicting they'd basically be drowning under so many millions of monthly profits from their bag sales in no time, backed by people who believed it and invested way more than you'd expect into such a thing, driving everybody into "we don't need to care a single bit about costs becasue we'll make soooo much anyway" mode.
I actually just read that Juicero has put forward the ability to block packs from being used if there was a recall on a batch of product.
That forces the remote authentication scenario.
Just cut it and squeeze by hand
The typical customer won't even think/remember they can do that
Juicero says you can mail your $700 juicers back for a refund if you were outraged to learn you can squeeze its juice packs by hand
Juicero, the maker of a high-tech juicing machine, is offering full refunds to customers who are upset to learn that its juice packs can be squeezed by hand.
In a lengthy blog post on Medium on Thursday to address the hand-squeezing controversy, Juicero CEO Jeff Dunn promised to take back machines from any customer who "feels that we aren’t making it easier, more enjoyable and delicious to form a healthy habit."
"If you send us your Press, we’ll refund the money you paid for it. Period," he wrote.
When it was launched a year ago, the $700 Juicero machine touted its ability to create the perfect glass of juice, harnessing the tons of force generated by the machine to squeeze out every last drop of juice from the bags of fresh fruits and vegetables.
But on Wednesday, Bloomberg broke the news that the high-end juicer backed by Silicon Valley's elite venture capitalists wasn't even needed to squeeze out the juice. It turned out that hand-squeezing the packets yielded nearly the same amount of juice and in a slightly shorter time, according to Bloomberg's tests.
http://www.businessinsider.com/juicero-offers-refund-for-squeezing-juice-packets-2017-4
But ...
Expiration date
Now, Juicero is on the defensive and is arguing that its juicer (whose price was already cut to $400) is needed because "the value of Juicero is more than a glass of cold-pressed juice. Much more," says its CEO Jeff Dunn.
To Juicero, the value of the company is its connected juice press that can tell you when the juice is about to expire and saves you the two minutes of packet squeezing.
Like the juice packets, Juicero's refund offer also has an expiration date: Customers need to return the machines in the next 30 days. And don't expect Juicero to take care of the shipping. Dunn's blog post noted that "if you send us your Press" the company will issue a refund.
Whether a $400 juicer is worth saving two minutes of hand-squeezing is a question you'll have to decide, but here's what it was like to use the Juicero machine when Business Insider first visited last April.
I got a better idea, seeing as how you can just squeeze it by hand, just do an Addam's family design. Have two hands come out of a machine and do the squeezing!
But ...
Expiration date
Yeah, my mind must constantly be in he gutter because I can think of a much more profitable
job for a mechanical
hand and it ain't squeezing juice!
I don't think anyone has suggested that the machine is actually bad at juicing
Given the amount of juice you can get out by hand I think the pulp is mostly for show. I think it either only has enough power to squeeze the already liquid juice from the bag, or they found that putting large chunks of fruit&veg in the bags ran the risk of bags failing.
I was thinking the same thing. Anyone that has ever tried to extract juice from a fruit or vegetable knows it requires far more pieces of fruits/vegetables than what you end up getting as juice. If those pouches hold 8 oz of fruit/veggies, then there should only be about 1 - 2 oz of juice, if that. They MUST already be full of juice.
One of the most overengineered piece of bad engineering.
The door is completely unnecessary, ever seen a press with a hingeable load structure? Probably not, because it weakens the structure and is completely unnecessary. Just flip the good old portal press by 90° and load the bags from the top.
That acme screw thingy is ridiculous, such a 18th century design, except they knew on how to build acme screw presses back then and used massive screws. That screw will always get all the loading on a few mm's of it's length. That's where the screw will start fretting and galling before getting stuck forever. From what I can see, they were even stupid enough to fabricate the nut from the same material as the screw (hardened? steel) instead of bronze or brass, which will make the issue even worse.
Sure, understand the interest of looking at all aspects.
Yeah, right.
And the government wants to take away your privacy to fight terrorism.
Same scenario.
"It can't be that bad if it can save your life."
There's this, which is basically the Juicero without the IoT DRM: http://www.juisir.com/
(It does use semi-special bags, but I bet those would be easy to make yourself.)
At least you can cut up your own veggies and make up the bags yourself. I bet that really pisses off Juicero -
Juisir launched a Kickstarter earlier this year, with pre-orders still underway. The company claims that its product will provide 8 tons of force to press juice from fruits and vegetables that a Juisir owner chops themselves and places in either a single-use or a re-usable bag that the plant matter gets pressed in.
https://arstechnica.com/tech-policy/2017/04/juice-wars-juicero-has-sued-another-juicer-maker-for-patent-infringement/
Man these juice names are confusing me - Juicero - Juisir - I keep looking at the source page to spell them correctly.
Could go with Juiceroo but then Batteroo would have to sue.
Guess who's got his dirty mitts on one?
Don't usually watch much youtube, but that stuff is hilarious
Hahaha - oh man gotta watch that tonight!
Work with me here - wouldn't it be possible to just go to the local grocery store and buy the fruit directly, take it home, and then squeeze it yourself?
The reason such things have some success is precisely because they change the boring usual way of doing it.
I feel like people are just getting bored in this day and age, and more and more new things nowadays are thus just about finding a different way to do stuff simply to try and keep people entertained, regardless of how useless or inefficient it is. And it will be since most of daily life's actions have reached "maturity" and their most efficient implementation decades ago, and any change thus has to become worse... but that's good, becasue in 10 years we'll be able to introduce a change again by bringing back the good old way that people will have forgotten in the meantime.
I see such a cycle in many fields. The lack of real progress calls for going backwards because regular change is needed. The linear progress doesn't work anymore so it's turned into a slow oscillation around the plateau.
I think you're onto something. Explains the whole mechanical watch thing, although that world has its own overpiced junk, there are some products that are true craftsmanship and mechanical engineering.
This is even better than the John Deere tractor manufacturer in trying to rinse IP rights for the corporate overlords
And yet another awesome teardown by AvE, that was hilarious
It's not really a 330V motor, that was a mistaken (and foolish) guess based on the motor label.
As was said in the video - should have made the plastic case clear, to show off the expensive machined parts inside.
