Author Topic: What's this please? (Component Advice)  (Read 1240837 times)
Offline Terabyte2007
  • It is purpose that created us... That defines us..
« Reply #575 on: August 03, 2014, 11:42:04 am »
Great info! Thanks much! A little embarrassed though that I did not even think to check for a diode. Trying to cram too much into my day and not taking the time!  :palm:
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Offline Electronics
« Reply #576 on: August 18, 2014, 07:41:10 pm »
I happened to get this board when I bought a HV powersupply for radar. I can identify all the pieces other than these black components. They're all mounted on a central metal bar which has connections at either end. The resistance between the two connections on the side is almost nothing (<0.5 Ohms). Anyone got any ideas?
Offline Richard Crowley
  • KJ7YLK
« Reply #577 on: August 18, 2014, 07:53:42 pm »
I strongly suspect those are mechanical (magnetostrictive) delay lines.  Was this by any chance a phased-array radar?
EDIT: On second thought, with only two terminals, it seems more likely they are inductors.  Although I wonder about the use of that common bolt through the center of all the devices. It seems like that would constitute a "secondary turn" that couples them all together. Or maybe not, if it is not a complete turn/loop.
You see warnings with modern torrodial power transformers to NOT create an unintentional "shorted turn" by using a metallic bolt with both ends in contact with the  chassis, etc.
« Last Edit: August 19, 2014, 06:31:31 am by Richard Crowley »
Offline sunnyhighway
« Reply #578 on: August 18, 2014, 08:42:11 pm »
The number on top looks like a NATO stock number, which can be broken down.
5950-99-523-4132
http://en.wikipedia.org/wiki/List_of_NATO_Supply_Classification_Groups
http://en.wikipedia.org/wiki/NATO_Stock_Number
59xx: Electrical and Electronic Equipment Components
99: United Kingdom
The first three segments can be found here:
http://www.abtus.com/assets/downloads/2008/12/Abtus_Nato_List.pdf
523: Some sort of transformer?
Offline Alexei.Polkhanov
« Reply #579 on: August 19, 2014, 03:34:25 am »
Wow that looks like some old equipment! What year is that radar from?
« Reply #580 on: August 19, 2014, 03:36:50 am »
I would be curious to know what material those spacers (disks) made from?
Offline IO390
« Reply #581 on: August 19, 2014, 05:56:19 pm »
Image credit goes to Robrenz. It's from the PSU thread but I can't find many pictures of these things...
Those number selector things, where do you get them and what is the proper name? I've also seen one where it has a sort of notched wheel sticking out and you can turn that, as opposed to buttons.
Offline PA0PBZ
« Reply #582 on: August 19, 2014, 06:10:02 pm »
  • KJ7YLK
« Reply #583 on: August 19, 2014, 06:12:05 pm »
Those are pushbutton-actuated "thumbwheel switches".
In the example above, it is quite probable the switches and the "fine control" pot at the right are logically connected together as a simple potentiometer in an analog circuit.
They commonly used 1-2-4-8 stepped resistors wired to the BCD-encoded switch segments.
« Reply #584 on: August 22, 2014, 01:52:34 am »
I am still puzzled by those black components from radar's power supply. Hate mysteries :-) If Richard's theory that these are inductors is right then I wonder why they market pins as "S" and "F"? For inductor it should not matter right? Also I don't understand how exactly such delay line would work? Metal bar in the center is connected which means it is not just for mounting.
Offline Rufus
« Reply #585 on: August 22, 2014, 02:50:02 am »
The electrical connections to the rod going through the middle suggests the rod is a single turn primary of a toroidal transformer with the blocks being multiple secondary windings. S and F is likely Start and Finish of the winding, the phase being important.
The devices on the aluminum brackets look like they could be dual diodes in TO220 packages. It could be 6 separate supplies but it looks more like some kind of multiplier stack producing a single high voltage output. I would not be surprised if it is a pulse supply with a capacitor being discharged into the primary periodically.
Having searched the web a bit dumping a capacitor into the primary of a pulse transformer the secondary of which powers a magnetron seems to be a common way of generating short radar pulses.
  • KJ7YLK
« Reply #586 on: August 22, 2014, 04:13:39 am »
Start and Finish (the two ends of the winding).
Theoretically. But if there were some intended interaction along that magnetic shish-kabob, then they would probably want the physical windings "in-phase".
Maybe it is just grounded. Especially if it is subject to some high-level RF fields, etc.  Hard to believe it is intended to be a "winding" of the composite inductor. It would be extraordinarily low impedance. Unless they were running some high-current signal through it, but I would expect heavier wiring.   :-//
« Reply #587 on: August 22, 2014, 05:06:45 am »
Then pulse will be for a pulse TWT tube or Klystron like on photo but smaller. I am not sure if those things can be called "magnetron". It must have been pretty small radar then. :-\ Sources I found on internet like this http://www.aps.anl.gov/Accelerator_Systems_Division/Radio_Frequency/Presentations_and_Lectures/Cross_Training/Documents/Cours_Presentation%203-7-08.pdf show that inductors used to make the pulse shaped more uniformly square, not to generate delay.
« Last Edit: August 22, 2014, 05:09:40 am by Alexei.Polkhanov »
« Reply #588 on: August 22, 2014, 07:07:10 am »
I think I found complete description of that entire assembly!
Look at this document on page 70 where they talk about "output stalk": http://www.lle.rochester.edu/media/publications/lle_review/documents/v133/133_07_Solid.pdf. Center rod is output. So it is a HV pulse transformer and that thing is called "pulser stack". Design described in the paper is pretty cool - they used METGLAS cores and 90 $80 RF  MOSFETs.  :D
(http://canada.newark.com/ixys-rf/ixzr08n120a/mosfet-n-rf-isoplus247/dp/42M1935?ost=IXZR08)
So those black components are definitely inductors and they most likely have high-permeability core inside.
Edit: I think it is essentially non-destructive version of flux compression generator (http://en.wikipedia.org/wiki/Explosively_pumped_flux_compression_generator). I sooo want to build one now >:D.
« Last Edit: August 22, 2014, 07:14:12 am by Alexei.Polkhanov »
Offline Electronics
« Reply #589 on: August 22, 2014, 01:14:06 pm »
The TO220 packages are BT151's - SCRs
« Reply #590 on: August 22, 2014, 05:31:53 pm »
Looking at the schematics from the document I linked see it is almost exactly same except SCRs are used instead of MOSFET and also I don't see any charge storage capacitors and clamping diodes. Those big blue components on the left look like HV capacitors but they are not connected to inductors directly?
Offline TheBorg
  • Hoping to start an EE degree soon...
« Reply #591 on: August 23, 2014, 03:33:56 am »
Any idea what these connectors are? I commonly see them on laptops (mostly Apple devices). Looks like I need to repair a few and can't seem to find anywhere to buy them...
Edit: been searching some more and it might be the Pico-EZ mate connector series. Though if anyone thinks otherwise, please feel free to tell me!
http://www.digikey.com/product-detail/en/0781710002/WM4459CT-ND/2424928
« Last Edit: August 23, 2014, 04:30:11 am by TheBorg »
Youtube Channel - Assimilated Circuits
We are Borg. You will be assimilated. Resistance is futile.
Offline ablacon64
  • Country: br
« Reply #592 on: August 24, 2014, 01:44:25 am »
I believe those are Apple proprietary connectors since I only see them on Apple's laptops. Once I had one like those broken, it was for the cooler fan, since I couldn't find a replacement just desoldered it and soldered the cooler fan wires directly to the motherboard pads.
Edit: See this: http://www.digikey.com/product-detail/en/0781710004/WM4460CT-ND/2424929
« Last Edit: August 24, 2014, 02:51:30 am by ablacon64 »
Offline d-chord
« Reply #593 on: August 24, 2014, 05:06:28 am »
I'm not sure that this is the appropriate thread for this, but here goes.
I've got an LG OS-5020 oscilloscope that I recently purchased (my first scope).  It apparently had a blown channel 2.  I did a little poking around and decided to swap what I'm pretty sure is a JFET between channels 1 and 2.  After swapping this component (labeled "304 E7G" - photo attached), channel 1 worked and channel 2 didn't.  The channel that doesn't work doesn't have a trace at all.  I don't have a schematic, but there is one available for a similar scope, the OS-9020G.  This schematic lists a part "2SK304E" and is the only FET in the parts list.
It doesn't seem like this part is available anymore, so I bought an ON Semi "MFP4393" which seemed to be fairly similar.  The pinouts are different, so I had to do some creative bending of the legs to make sure the S/G/D pins are in the right holes (marked on the circuit board even, which is nice).  There's no change with this part in place; the failed channel still doesn't display.  And yes, I checked and the legs weren't shorted against each other.  I even tried a MOSFET (Fairchild BS170) to no avail.  I guess there's no standard pinout for FETs because the BS170 actually does have the same pinout as the supposed original.
One other piece of information is that I measured the resistance between legs of each of the two components.  Assuming I have the pinouts correct, the bad one measures:  S-D: 204 Ohms, S-G and D-G are both about 10K.   The good one measures: S-D: about 60K and S-G and D-G are open.
I was hoping that someone might be able to confirm that this part is in fact a JFET.
If anyone has any other advice on what might be a good replacement, it would be appreciated.
-David
  • KJ7YLK
« Reply #594 on: August 24, 2014, 05:48:04 am »
Google says that "Buy-Transistors" has 7 of them for sale at £1.44 each.
http://www.buy-transistors.com/transistors/2sk304e.html
Offline amyk
« Reply #595 on: August 24, 2014, 11:53:25 am »
You might want to check the schematic... at least I know that J6500 on an M51 board is a Foxconn HS8804F-B. Not surprising as Foxconn make much of Apple's boards.
Offline d-chord
« Reply #596 on: August 24, 2014, 12:58:46 pm »
Thanks Richard!  I've got two of those JFETs on the way (one spare just in case).
-David
Offline TheBorg
« Reply #597 on: August 26, 2014, 02:24:29 am »
Yikes, thats a very close part! I can't find a schematic for it dang it. However I think it is the EZ mate, the text in the corner as well as height matches on a similar board. I would check the pin to pin distance but I don't trust my calipers down at 0.05mm difference.
Offline IO390
« Reply #598 on: September 03, 2014, 01:36:03 pm »
I've found some old panel meters and the manufacturer's name is in some sort of italics so I can't read it. Does anyone recognise it?
Cheers
Offline ElektroQuark
    • ElektroQuark
« Reply #599 on: September 03, 2014, 01:40:53 pm »
Ernest Turner instruments
