I told earlier that i'm going to log my ioniq 5 (2023) 12v battery. I have data for ~13 days now, with voltage and current in 1 minute intervals. No averages etc, just a sample every minute.
I had the opportunity to let the car stay ~untouched for 4 days because of the holidays and saw a strange thing happen 68 hours after parking it. Theres ~2 watt blips about every 40 minutes (probably something else that just wont register with the 1 sample per minute log, but anyway) that just ended at 68 hours. Base load is about 0,2 W. Which seems pretty low, when someone mentioned 300 watt idle loads for some evs, which just can't be true, as that would mean that the 12V 60Ah battery would die in under 3 hours.. Did someone miss the milli-part of the idle watts or something?
I tought I had the logging setup last time using the negative battery lead as a shunt, but it was the positive one that was way easier to connect to. I tried to calibrate the shunt voltages against clamp meter with as high stable current consumption I could and I think I got pretty close with several values between 5 and 9 amps. Highest charging was 39 amps and highest consumption 26 amps. Battery voltage was 11,94 - 14,90 volts. Last time (summer 24) I saw pretty regular threshold for charging at 12,7 volts, but this time it seems more random. Probably better for the battery? Median voltage was 12,81v.
Charging the actual drive battery does not really affect the 12v charging cycles, if something, the still somewhat random charging isn't so brutal and I saw it peak at just ~10 amps while connected to grid. >20 amps happens often when the car is just parked unplugged. I would have thought that the 12v charging would be forced or at least the threshold to be bumped higher when theres external power available, but Koreans had thought otherwise.
When parked, there's about 2-50 watt consumption after leaving the car for ~10 minutes, where the higher values are for things just shutting down and me using the power trunk lid etc. 10-60 minutes stays at 0,5 watts + some 2 watt blibs. Hours 1-68 it stays at just 0,2 watts with those 2 watt blips every 40 minutes and after that the blips disappear.
Earlier logs (summer 24) with different sw/fw on the car it woke up for 4 hours pretty much every time when it saw the keys even near it. Then there were steps for 20-50 watts for 2-3 minutes, 2-5W for 3 minutes, and couple steps through the 4 hours to finally drop to about 0,4 watts. Things have clearly improved since that.
