The major issue with the 399 and 1399 designs (good ones or bad ones) when targeting the 10V output are the two 7->10V resistors availability/quality.
Frankly, the easiest solution is the ADR1001. It combines "similar" performance of the 1399 and adds up the on-chip ovenized/trimmed resistors as well (all in ceramic). It has got some minor quirks and it might require a proven history of a metrology grade measurements, sure, but for generating 2.5/5/7/10V output there is hardly a "cheaper*" and a simpler solution available..
*ADR1001 is pretty pricey, tbh, but..
With a "traditional" 399/1399 designs the "best" solutions would be those with 2/4/N refs in parallel, with the zener's cathode resistor biased off the 10V output (and buffered by an npn/jfet transistor), with those 2 critical 7->10V resistors having "ratio TC" better than the TC of those 399/1399s used (resistors difficult to get, people use "single chip statistical resistor arrays" sometimes). Another option is to ovenize the entire stuff to mitigate the resistor's bad ratio TC somehow. Have a look into this thread there are several such designs elaborated again and again..
..there are definitely better designs here than the IMSAI's one..
Hello
Could be interesting to create a post with the ( one ) best solution circuit ? or even link the Gerber files or PCB design tips as ground plane , thermal control ....
Regards
OS
PS: below a typical design I would consider "good". Sure, there are nuances we may discuss, as usual..
Notes:
1) All caps in the "signal path" -> foil.
2) Input voltage >19V, ie. 5*18650.
3) 7815 off the Vref pcb (7815 changes its temperature with the input voltage variations).
4) Most critical for the TC and the long term stability is the resistor's array and the trimming resistor (with a trimmer adjusting you would need a special wiring).
5) PCB design - star config(s) with grounds (low current and high current tracks and grounds, the schematics does not show the nuances), special handling of the area around the 399 pins (thermal gradients removal), cutouts (mechanical stress avoidance),
etc. etc..
6) Resistor array - that one in the example has "ratio TC" <=1ppm/C, the trimming resistor (say 10ppm/C) makes it even worse. That is 2-5x more than the TC of the 399/1399. The vintage OP07 (or use a newer one there) may have less influence on the TC than those 7->10V upscaling resistors.. Another point is the noise of the resistors (there are better arrays people say).
