Here's my drift diagram for my only build, the ADR #3.
I'm not interested anymore in the overall stability / drift of the ADR, as I have completely finished my studies about stability of buried zener references, have proven the nature of the LTZ 1000 as a Deterministic / Absolute Reference, and now I only would like to improve the characteristics and specification of longscale DMMs, like my 3458A.
The ADR would offer the opportunity to realize a usable 9-digit DMM, i.e. rms noise in the 0.001ppm range, INL 0.02ppm, and drift lower than -0.6ppm/yr., By implementation of the Deterministic Reference by adding a secured real time clock, idle power supply and battery backup, these design changes would yield an Absolute Voltmeter. Its 10V range uncertainty specification would simply be:
0.01.. 0.001ppm over Lifetime
+/-0.02pmm of Range
I have modified my ADR #3 by as well adding a proper 2nd electrical shield around the inner GUARD magnetic shield (with Andreas EMC capacitors), and doubled the zener current for achieving lower noise. T.C. is not yet aligned to zero.
This initiated a new, but faster inrush drift.
As said, the ADR #3 with its given bad die attach is not usable at all for DMMs, only with the described power back up. AD should make a Design Change on that.
I've heard nothing from Illya, or MiDi, concerning their tests to bring down the noise level of the 3458A (together with the necessary modification with EMC capacitors for the A9 board), by changing the +/- 12V and 5V reference OpAmps and using a 4fold ADR reference.
Has anybody heard about that activity?
Frank
