I had the good fortune of finding 3 SZA chips on ebay (they are from hifi-szjxic, so I am hoping they are not fakes).
Last night I read through Lyzmex's excellent thread over on 38hot:
http://bbs.38hot.net/thread-177-1-1.htmlHowever, I noticed that all of the circuits in that thread, and all of the circuits in this thread (with the possible exception of the fluke 8520 circuit?) are true "refamp" circuits, in that they utilize the amplification (beta) of the transistor.
However most of these circuits suffer from having an "attenuation" of only 3 for the most sensitive resistor pair.
One of the big advantages of the classic bootstrapped zener circuit is that the resistors have very good attenuation (if the zener has good dynamic impedance). For example, the LM399 has an impedance of about 1, so a 1k zener resistor will attenuate op amp voltage output errors by 1000.
I'm interested in seeing if we can gain the advantage of the bootstrap circuit, and get good resistor attenuation, by discarding the "amp" functionality from the "refamp".
Starting from the bootstrap circuit, the simplest thing to do is simply insert the Vbe junction into the circuit, ignoring the collector pin (see attached 1).
I think this would as expected if you simply threw a 2N3904 and a 5.6V zener onto a breadboard, but I suspect that this won't work with the SZA, as I suspect the transistor cannot handle the full zener current through its base. Can anyone confirm that? Is there a way I could find out how much current the transistor can handle, without sacrificing an SZA to find out?
Assuming the transistor can't handle the full zener current, we need to have independent resistors for the base and zener currents (another way of stating this is that we need to add an extra resistor to inject additional current into the zener). This is circuit 2 (attached).
However, this isn't ideal, as my understanding is that the collector current is what gives you the ability to tweak the zero-tempco point. So we can also add a third resistor to have independent control of the collector current. (see circuit 3).
This is still the classic bootstrap circuit, and the base pin (the most stable point of the circuit) is what controls the op amp loop, so this should be as stable as we can get.
Does this approach work? I plan on trying it out when my chips arrive.
I think the biggest disadvantages of this approach are that you only get a 7V output, and it is a high impedance output. However, for me, that's ok.
Any feedback / thoughts are very appreciated!
