Author Topic: Dim OLED Screen replacement for Agilent Keysight U1253A U1253B U1273A U1273AX  (Read 117605 times)
Offline DavidAlfa
Start reading few post back.
The following users thanked this post: onesystem
Offline fbpicsous
Thanks a lot, we just saved 2x U1253B !
I buy "midas" oled:
https://midasdisplays.com/shop/oled/oled-graphic/mcot128064ey-ym/
Works great.
Unfortunately the capacitive measurement does not work anymore with the new firmware U1253B !???
(Both MM affected)
Offline DavidAlfa
Does it work again with unmodified fw?
Maybe the patch area was not empty after all, I could try relocating the code elsewhere.
« Last Edit: May 28, 2024, 07:36:03 pm by DavidAlfa »
Offline gamalot
  • Correct my English
    • Youtube
I'm having trouble upgrading the firmware version of my U1253B (from 2.26 to 3.04). The screen keeps showing "D...." and the PC keeps repeatedly asking me to cycle the power of the multimeter to continue the upgrade process. I gave up after trying this dozens of times. Any suggestions?  |O
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline DavidAlfa
Try official update first?
The following users thanked this post: gamalot
Offline gamalot
    • Youtube
It was the official one.  :(
I actually tried every version I could get my hands on, the official 2.26 and 3.04, as well as the patched 3.04.
« Last Edit: June 01, 2024, 09:57:08 pm by gamalot »
Offline DavidAlfa
Can't tell. Maybe bad cable driver? Depleted batteries?
Offline gamalot
    • Youtube
I've tried the original U1173B and my DIY CH340 cable, but none of them worked.
Regarding the battery, I tried powering it with a bench power supply.
I also used the method you mentioned in post #33, but there was no visible change.
« Last Edit: June 01, 2024, 10:06:42 pm by gamalot »
Offline DavidAlfa
Can't help, sorry.
Offline gamalot
    • Youtube
Can't help, sorry.
Thank you very much for your reply. Now the only hope left is whether it is possible to write the firmware directly through the Flash Utility.
Offline DavidAlfa
Are you sure the U1173B optical cable is working?
Try disabligng any other COM ports in the Device manager.
Also try changing the assigned port to COM2 or COM3, removing the cable and plugging it back afterwards.
Just to make sure, try with a USB 2.0 socket!
This is only to start the mcu into native bootloader mode.
It's totally unrelated to the Keysight bootloader the updater talks to.
Theorically yes, you could. But it's risky!
First, I would try only erasing block 127, then writing a ramdom 1KByte file to it.
If it fails, the bootloader will be still intact and enter update mode automatically.
python flash-util.py -e -b 127 -p COM3
python flash-util.py -f "1kb_file" -b 127 -p COM3
If it was able to erase and write that block, then you can try wiping the chip and writing the whole firmware.
You need to first convert the original file into the native binary with tool_U1253B_U1273A (Available here):
tool.exe firmware.AG firmware.bin
Then flash it:
python flash-util.py -e -p COM3
python flash-util.py -f firmware.bin -p COM3
« Last Edit: June 01, 2024, 11:23:36 pm by DavidAlfa »
Offline gamalot
    • Youtube
Thank you very much for such a detailed reply, I have double checked the cables and as mentioned I have also tried different cables and changed port numbers. I even found an old Thinkpad T410 laptop with only USB 2.0 and installed WIndows 7/8.1/10 operating system, etc., without success. That's why I said my last hope is to use Flash Tools to write the firmware, I'll try it soon and report back.
Offline gamalot
    • Youtube
Pinout of ports on U1253B.
Offline gamalot
    • Youtube
My CH340 based U1173B clone.
Offline DavidAlfa
How does that clone compare to the official cable?
It seems nowhere close to me, looks like the original cable goes inside of the socket while yours is flat.
Just trace the same pins:
1. pin   50    P14/RxD6
2. pin   51    P13/TxD6
3. pins   18    EVSS,
            60    AVSS
4. pins   16    REGC,
            19    VDD,
            20    EVDD
5. pin   10    RESET (via 1K resistor)
6. pin   13    FLMD0
« Last Edit: June 02, 2024, 11:52:23 am by DavidAlfa »
Offline gamalot
    • Youtube
It works just as well as the original, maybe a little better, since the PL2303 converter that Keysight used in their cables is no longer supported by Windows 11.
One thing I thought of before trying to use the flash tool directly was to wire out the reset signal to a button, as I found that my U1253B didn't always have a reliable power-on reset.
« Last Edit: June 02, 2024, 12:27:30 pm by gamalot »
Offline onesystemTopic starter
When debugging my U1273AX after flashing wrong firmware onto it I did a reset of the chip by simply shorting two wires for a moment and that worked for me.
Offline Tarloth
  • Country: ar
Thanks to everyone, I was able to change the screen, update with the modified firmware and revive a U1253A without any problems (using the Bluetooth adapter). EVERYTHING WAS PERFECT, THANKS TO THOSE WHO MADE THIS POSSIBLE.
Gracias DavidAlpha por tu esfuerzo!
The following users thanked this post: DavidAlfa, onesystem
Offline Per Hansson
This is an off-topic reply but I'm hoping it helps save someone else:
I have been meaning to put NiMh batteries in the U1273Ax I showed on the previous page but have not been to IKEA yet.
I thought for sure it can work fine with some Alkalines for just a few weeks.
They where unused and from the same batch, expiry date December 2027
Looks like the second cell from the left in the attached picture shorted.
It smells burnt and is blackened, however all cells show quite nominal voltages from left to right both with a high and low impedance measurement:
1.497v 1.461v 1.485v 1.524v (I did check the batteries voltage before putting them in the meter and then they where all within a few mV).
So I expected something inside the meter had shorted (like a capacitor) but nothing looked burnt.
So I powered up the meter from a bench PSU and it draws a normal load and works fine.
So this is your call to find all Alkalines batteries in your possession and get rid of them, thank me later :)
In my case the only part that took damage was one of the battery series metal clips, so I got lucky.
I was going to measure something with the meter and it was totally dead: I guess the clip no longer made contact and that stopped the carnage...
Offline DavidAlfa
They look cheap, don't put crappy batteries in expensive equipment, use the good stuff like Energizer, Duracell...
Offline Per Hansson
Thanks but I respectfully disagree: I have Energizer batteries that leaks when unused in the original plastic packaging.
My thinking for putting "cheap brand" (these are marked by a local store chain in Sweden) is that unlike the large names they probably don't spend time eeking out the last bit of battery capacity:
With the hope that there should be more internal spacing for the internal seals, obviously that didn't work in this case but my only advice for everyone in this thread is to not use Alkalines, ever.
The previous owner seem to have had a battery leak in this meter too, one of the battery posts is degraded just like in Daves video #1564.
« Last Edit: August 01, 2024, 07:41:21 am by Per Hansson »
Offline Tarloth
  • Country: ar
Hi, I use the U1253A today to measure capacitors and the meter it's dead, change the scale up to mF and nothing happens. Any idea? Thanks
Offline DavidAlfa
Define "dead".
Or is it only failing to scale to mf?
@onesystem could you test this on yours?
Offline Tarloth
  • Country: ar
Sorry @DavidAlfa!, yes, the capacitor measurement reads nothing, change automatically from nF to uF and then to mF, after few seconds shows the overrange "OL" but never sees the capacitor. Before flash the new firmware I did measured a couple of caps (with inverted screen) and did works ok. I attach an image of the problem.
EDIT:Everything indicates that it will make a normal measurement going through all the scales but as if I never connected the capacitor to the measurement circuit. If I connect the thermocouple (same dial position but using the shift) the measurement is perfect.
« Last Edit: August 10, 2024, 03:45:26 am by Tarloth »
Offline voltsandjolts
@Tarloth
Is the capacitor in circuit, or out of circuit?
What is the expected capacitor value? Is it within the measurement range of your meter (see specs)?
