Author Topic: Airsoft - paintball chrono  (Read 54659 times)
Offline vzooleTopic starter
  • Country: hu
« on: January 13, 2013, 05:45:33 pm »
I would like to share an airsoft - paintball chrono that I made.
"Underspeed Chrono Light"
Version: 1.0
Last modification: 08.01.2016
Some tecnical info:
Set AVR clock to external crystal.
LED:
Any IR (infra red) LED.
Best under 60 degrees
7 segment LED display:
common cathode, common sticks.
For example:
KINGBRIGHT ELECTRONIC BC56-12SRWA
http://www.tme.eu/hu/details/bc56-12srwa/harmas-led-kijelzok/kingbright-electronic/#
Phototransistor:
Many type working well.
I tested BPW17 and SFH309FA phototransistors.
PCB size:
81mm x 85mm
!!! LED1, LED2 polarity is WRONG on the schematic !!!
« Last Edit: January 08, 2016, 06:44:57 pm by vzoole »
The following users thanked this post: Tarien
Offline TorqueRanger
Re: Airsoft - paintball chrono
« Reply #1 on: January 14, 2013, 11:54:58 am »
I like it .... :-+
I wish I still used my paintball guns again but might build your setup for my brother though..
Offline Noobiq
  • Country: sk
« Reply #2 on: January 22, 2013, 04:09:46 pm »
hello
so i build it, but its not working, and i would like to know why.
when i turn it on, the display start blink (at frequency like 25hz), and show just three zeroes.
i used 1n4007 instead of 1n4004, and ATMEGA8A-PU instead of ATMEGA8-PU (i couldnt find this, and "google say" they are the almost same,)
could anything of that make problem?
  • Country: hu
« Reply #3 on: January 22, 2013, 04:39:08 pm »
I think the problem could be the avr clock setup.
You have to set clock source to external crystal (high fequency) and disable CKOPT.
Check the first post, I attached display of clock setup.
Offline Noobiq
  • Country: sk
« Reply #4 on: February 07, 2013, 04:28:01 pm »
i am finally reprogrammed processor, display works fine now, but dont measure.. only show 3 zeroes.
i used R1-R7 = 150 ohm (but this shouldnt matter, it can be 150-220)
btw, R11 = 91 ohm? (just to be sure)
i don´t know exactly what IR LED i used, it looks like this one
http://www.sos.sk/?str=371&artnum=11936&name=kingbright-l-53sf4bt
i mean, can dark color of the LED be a problem?
everything else (except what i alredy wrote in previous post) is same as your
edit: i tried IR led from old mouse, but still no output on display..
« Last Edit: February 08, 2013, 02:41:41 pm by Noobiq »
  • Country: hu
« Reply #5 on: February 10, 2013, 03:42:04 pm »
Hi!
Yes, R11 is 91 Ohm, but best if you measure IR LED current, and you choose correct resistor value.
IR LED with filter is good. You can check the lighting, with a camera or phone.
And check the PD2 and PD3 leg with multimeter. Measure voltage there, after cross the light and measure again. Share the values.
Offline Noobiq
  • Country: sk
« Reply #6 on: February 14, 2013, 03:21:37 pm »
i changed R11 to 47 ohm (added 100 ohm parallel).
i measured PD2/3 before and it was 5V/3V, now it is 5V/2V and the chrono works correctly.
i thought cameras have IR filter therefore little ir light is see. Becouse of that i didnt realized LEDs shine too weak
Thanks for your help!
Offline Sh4DoVV
« Reply #7 on: February 21, 2013, 09:33:36 am »
Hi
so i build it, but its not working , the 7segement not show any thing ! |O
please help me
Offline Psi
« Reply #8 on: February 21, 2013, 12:41:53 pm »
How are you timing the delay?
Are both light sensors on hardware interrupts where you start the timer on one and read the value on the other?
  • Country: hu
« Reply #9 on: February 23, 2013, 10:44:41 pm »
I think program isn't run. Please search an AVR topic or tutorial to find the problem.
You think well, just a little different. Timer is always run. I reset at 1st interrupt, and read at 2nd interrupt.
Offline Sh4DoVV
« Reply #10 on: February 24, 2013, 11:29:42 am »
Hi dear vzoole
may you tell me how to program your ATMega8 ?
I have STK500 Programmer , but i don`t know how to program my ATMega8
thanks
  • Country: hu
« Reply #11 on: February 24, 2013, 11:35:49 am »
I use AVR Studio 4.
Offline Sh4DoVV
« Reply #12 on: March 06, 2013, 08:52:03 am »
hi friend
I built it again butdn't work
I program atmega with stk500 by avr studio 4 ,but 7segement don't show anything
Please help me
  • Country: hu
« Reply #13 on: March 06, 2013, 11:30:22 pm »
Check clock and display outputs on AVR with scope.
Offline andreiu21
    • My web page
« Reply #14 on: March 11, 2013, 05:34:06 pm »
nice little project.
Thanks for sharing! D
Offline tim1986
« Reply #15 on: March 12, 2013, 03:12:42 am »
Nice project! What is is actually displaying? MPH, km/h, inches per second, just the time between?
Thanks!
-Tim
  • Country: hu
« Reply #16 on: March 12, 2013, 06:11:55 pm »
Thanks!
Actually show FPS in video.
Offline adam164
« Reply #17 on: December 03, 2013, 02:17:01 pm »
I made your chrono but it not work correctly. Slow speed show (under 20 fps) but higher speed no....I use phototransistor SFH309 and I programmed in Pony prog becouse I have only LPT programer and in AVR studio not work. Do you tested it with airgun cal. .177?
  • Country: hu
« Reply #18 on: January 10, 2014, 10:59:33 pm »
Hi!
Maybe you doesn't switch off CKOPT option that is dividing the clock by 8.
So if you measure 20FPS that could be around 160FPS in real ( 20*8 ).
So please check the FUSE bits.
« Last Edit: January 26, 2014, 09:29:38 pm by vzoole »
Offline UA
« Reply #19 on: March 25, 2014, 07:30:21 am »
Install the software on a chip (Chrono_light_01_mPs.hex), but does not work. What should be the current work? What could be the reason?
How much should be volts?
  • Country: hu
« Reply #20 on: March 26, 2014, 10:00:10 pm »
Minimum input voltage is 7.5V
Current without controller (only IR LEDs): ~30mA
With MCU and working 7 segment display: ~110mA
If you have no current flow you have supply problem.
Offline s3k0
« Reply #21 on: March 27, 2014, 07:29:59 am »
very nice project  :)
i want to make one but im complety dummy for project
can you tell me what exactly i need parts for this porject;
example;
2x diode
1xatmelxxxxx
 i readed first post but missing somethings like ressitors
2xphototransistors
2x ir led
1x atmega8pu
1xusbbasp for programming
....others ? :-// i can see in picture but i dont know names  :o
Offline UA
« Reply #22 on: March 27, 2014, 07:59:25 am »
there is no voltage on the LED (red circle on the picture)
  • Country: hu
« Reply #23 on: March 27, 2014, 08:21:22 am »
You can find parts in schematic in zip file at first post.
Check the input voltage on regulator input.
Offline UA
« Reply #24 on: April 29, 2014, 02:26:25 pm »
Hi friend. Which firmware to measure in meters? Chrono_light_01_FPS.hex or Chrono_light_01_mPs.hex
