Author Topic: Airsoft - paintball chrono  (Read 55058 times)
Offline UA
Re: Airsoft - paintball chrono
« Reply #50 on: May 17, 2014, 12:38:52 am »
Maybe the whole thing in the wrong processor programming ATMEGA8A-PU?
Offline vzooleTopic starter
  • Country: hu
« Reply #51 on: May 17, 2014, 12:44:21 am »
Remowe the controller and make a short between PIN 7 and PIN 15.
Same time make a short on one transistor side legs (E -C).
Does the display show something?
Offline UA
« Reply #52 on: May 17, 2014, 01:18:11 am »
All done. But nothing. The indicator has not responded (photo). And yet, when I took ATMEGA8-PU, still lit LEDs.
Offline UA
« Reply #53 on: May 17, 2014, 10:51:36 pm »
Try again perepronramirovat ATMEGA8A-PU, can help. If not, I will look for where it can be a mistake. If there are hints that it may be, I will be grateful.
Offline dannyf
« Reply #54 on: May 18, 2014, 12:37:57 am »
At this point, I would retrace the board and make sure that it is consistent with the schematic.
Offline UA
« Reply #55 on: May 18, 2014, 07:03:04 pm »
Dear may already tired of my questions, but I still do not understand, will not rest. Publish photos chronograph from all sides. Checking the installation, all in accordance with the scheme. Details respectively indicated. Closures and without defects. I think that may be the problem of the correctness of programming ATMEGA8A-PU. I do not know how and what to check.
  • Country: hu
« Reply #56 on: May 18, 2014, 07:26:02 pm »
Next time remove the controller (as I asked) before you make short on their connections or you may damage it.
What's the value of R1? Can you measure it?
Offline UA
« Reply #57 on: May 18, 2014, 08:05:36 pm »
Value R1 - 180 ohms. At a voltage value of 180 ohms.
Value R11 - 91 Ohms. When feeding is 0 ohms. When I connect the voltage value of R11 - 91 Ohm disappears. Multimeter shows nothing.
Offline UA
« Reply #58 on: May 18, 2014, 08:07:19 pm »
Learned controller. Made a short circuit between PIN 7 and PIN 15. Same time made ??a short one transistor lateral branches (EC). But the indicator did not show (photo).
Offline UA
« Reply #59 on: May 18, 2014, 08:14:14 pm »
Apply voltage: R11 - 2,6 volts. But in this case, R1-7 - 0 volts, R8-10 and - 1.4 volts.
« Last Edit: May 18, 2014, 08:17:09 pm by UA »
  • Country: hu
« Reply #60 on: May 18, 2014, 08:42:00 pm »
Something wrong around 7 segment display. It get direct voltage in this test so must be light.
Offline UA
« Reply #61 on: May 18, 2014, 09:08:07 pm »
Question. What is it and whether these contacts zamykatsya?
  • Country: hu
« Reply #62 on: May 18, 2014, 09:10:14 pm »
Offline UA
« Reply #63 on: May 18, 2014, 09:22:30 pm »
What voltage should be on these contacts (on the legs of the display)?
Offline UA
« Reply #64 on: May 20, 2014, 10:24:55 am »
Hello everyone. Hooray, I reached performance chronograph. The problem was in the indicator. He had a common anode and common cathode required:-DMM. Bought new, replaced and succeeded. Works. I am very glad :).
"Vzoole" Thank you for the product.
« Last Edit: May 20, 2014, 11:23:02 am by UA »
Offline UA
« Reply #65 on: June 12, 2014, 02:41:55 pm »
Hey. Tell me, what maximum speed chronograph can measure (meter per second). Want to experience a firearm.
Offline littlej
« Reply #66 on: July 07, 2014, 07:48:32 pm »
Hy, could you please share the source code, i'm trying to build one almost like your's but i'm beginner intro codding and i would like to take a peak at the code. thanks pls feel free to email me.
Offline dannyf
« Reply #67 on: July 07, 2014, 09:38:38 pm »
For a newbie, writing your own would be a much better learning experience.
Offline littlej
« Reply #68 on: July 08, 2014, 12:45:37 pm »
Hi, well i have an idea how to write my own code, but i have no idea how to get it more accurate, i mean i know i have to use timer1 (since it's 16bit) to count the time between the trigger on the first sensor and the second but i don't know how to do it exactly and i would like to see an example doing just that. Thanks
Offline dannyf
« Reply #69 on: July 08, 2014, 02:09:02 pm »
The only way to solve that is by doing it.
You sound like to have a foundation but without opportunities to practice. This would be a good opportunity to do so.
Offline hodza
« Reply #70 on: May 05, 2015, 08:16:24 pm »
IR LEDs have their polarity reversed. The cathode should be connected towards the ground or negative side of the driving voltage source, and the anode toward the positive side.
  • Country: hu
« Reply #71 on: May 05, 2015, 08:23:33 pm »
You are right! I have made mistake. I'll correct it as soon as I can.
Thanks for report.
Offline hodza
« Reply #72 on: May 07, 2015, 08:01:57 am »
Nice project. Thanks!
Offline Di11on
« Reply #73 on: June 14, 2015, 08:37:48 am »
What a nice project - thank you so much for sharing.
I wonder if you could help me with a problem.
At the moment, I just have two blinking zeroes (voltage at pin 27 is 0).
I have programmed the chip fine, but when I set the fuses as per your image, I lose contact with the chip. Is it something to do with the external crystal clock not working for some reason? I have used a 10MHz crystal with 22p capacitors as per the information you uploaded. The crystal I am using has a capacitance of 30p.
Have you any idea what the problem may be?
Many thanks in advance
Offline hodza
« Reply #74 on: June 14, 2015, 12:05:31 pm »
http://mdiy.pl/atmega-fusebit-doctor-hvpp/?lang=en
