Author Topic: Challenge Thread: The fastest breadboard oscillator on the mudball  (Read 112762 times)
Offline 0culus
Re: Challenge Thread: The fastest breadboard oscillator on the mudball
« Reply #200 on: June 20, 2020, 07:21:11 am »
Dude, will you chill out with all the "dangerous rule bending" crap? This is for fun, no one is playing for money here.
Whatever :) Dude cool down yourself. I am stirring the pot, for entertainment purposes. Please don't call it Breadboard Oscillator especially when winning entries do not follow rule #3, part "All electrical connections between individual parts must be made by the breadboard contacts".
Why would I blatantly cheat by using an IC, anyway.  ::)
Usually main part of Comb Generator is just diode. Thou needs powerful signal. Anyway I was kidding. Noticed smiley that looks like: :D? It means: "laugh". Comprehend? :-DD
I'm experimenting with different inductor configurations and I happened upon one that made the second harmonic take over by a few dB.
Good! As I said - would be nice to show fundamental together with harmonic, preferably using two markers, if any.
If you're stirring the pot, it may be coming across as more combative than you are intending it to.  :box: I don't know if it's the language barrier, but since you had to explain it you might want to be more careful.
Anyway, let's see your efforts. Otherwise you're just the peanut gallery.  :-DD
Offline 0culus
« Reply #201 on: June 20, 2020, 07:25:13 am »
I'm going to order some much faster parts from digikey this weekend anyway. I'm not going to bother trying to desolder these.
Offline 0culus
« Reply #202 on: June 20, 2020, 08:14:08 am »
Usually people become hyperventilated about my sentences ending with smileys ;) Who is combative here? :D BTW I did not resort to personal insults like you with your "language barrier", "peanut gallery", not even mentioning personal insults directed at me from contest leader.
Snip
LOL.
> claims to be kidding because emoticons
> wants to have it both ways and be insulted by mine
I’m not the first person to call you out on how you’re acting in this thread. If you can’t handle being called out and having it dished back at you, that’s not my problem and I have little sympathy. No one asked you to be the self appointed breadboard oscillator rules cop. The OP is doing a fine job of arbitration so please leave it to him.
Offline BreakingOhmsLawTopic starter
  • Certified solder fume addict
« Reply #203 on: June 20, 2020, 08:35:39 am »
Keep me out of this, and perhaps you should make an entry yourself for the others to scrutinize.
« Reply #204 on: June 20, 2020, 08:47:04 am »
Question to OP: If I do not show my entry due to lack of MW counter/SA, I can't post here in this thread?
Highly encouraged to post it anyway. This competition is for fun and educational purposes.
And to disprove the false legend that "breadboards can't go over 10MHz".
I don't have access to anything over 1GHz myself, so I will be contributing some related stuff now and then like i did yesterday.
Cheers.
Offline trash
« Reply #205 on: June 20, 2020, 08:51:34 am »
Wow, Bitchin !
I've been away for a week and Joe is up at 16Ghz and the 2GHz version is still sitting on my work bench.
I like the shield, I hadn't thought of doing that.
I've got some new ideas I want to try with a completely different circuit tonight.
I'm back at work again for another week so I only have tonight for some development.
It looks like there is a lot more interest in the competition now and people have realised how easy it is to break the 1GHz barrier even on a breadboard.
Offline trash
« Reply #206 on: June 20, 2020, 09:04:32 am »
I would not stress about not having any gear over 1GHz. It's just as easy to test your oscillators and do it REALLY cheap.
The first thing you probably already have. A USB TV dongle.  Run some SDR software and you have a spectrum analyser that is good up to almost 2GHz.  For only $20 !
The next thing to do is get your hands on some downconverters. Again, you probably already have these things.
The first is a satellite TV receiver. They're good to 2GHz. The IF stages also make good spectrum analysers on their own.
Those old MMDS antennas. The downconverters on them have a local oscillator of 1950MHz. They will give you access up to 3GHz, especially if you remove any front end filtering.
Next is a C Band satellite LNC. They're good for 3GHz to 4.5GHz. Again, if you have an older on you don't mind removing the front end filtering, you can push them out to 5GHz.
Next is 10GHz. If you have an old automatic door motion detector, a radar detector, or a burgular alarm microwave motion detector.
That will give you access to ~9-11GHz.
Ku Band LNC's, they're give you access to 9-13GHz and you can modify them well out to 15GHz. I've got an old Plessey 2.2dB NF LNC that I pushed out past 15GHz. (trying to get to 24GHz).
K Band Radar detector will give you 24GHz and some of the images. 24GHz gunn modules, you can mix them down and run them on your CRO or SDR.
And even then, you can still go dumb as a box of hammers simple diode wavemeter.
Two wires in parallel with a diode on the end connected to your CRO with a slow sweep looking for tiny changes in DC.
Connect the signal source to the diode and short the two wires. Move the short up and down the wires and look for nulls and peaks.
Measure the intervals which will be half wavelength.   That's what we used to do in the days before rectum paralysers became dirt cheap.
Offline trash
« Reply #207 on: June 20, 2020, 10:44:07 am »
Looks like I've reached the end of the line tonight.
Doubling the output of the 2GHz oscillator to give 4GHz should have been a walk in the park. But I was getting nothing.
I couldn't work out what was going on. So I fired up the sig gen and nothing out of the doubler either.  So I thought the doubler was broken and I rebuilt it. And still nothing.  Eventually I went and got a C band signal source and nothing on the spec-an either.
 Ah shit... looks like the >2GHz section in my spectrum analyser has stopped work so I've been stuck at 2GHz not realising that the comb generator I built was probably cranking out harmonics at 10GHz last week. Doh !
So I had to change to take some of my own advice and fire up the X band mixer to see if anything was happening at 10GHz.
Sure enough there was a carrier there. So tonight I thought I'd go back to the simplest circuit and see if I could make it work.
A negative resistance diode (Tunnel diode) set up on a skeleton waveguide and woohoo ... the dirtiest signal I've seen at 10.7GHz.
It's completely useless as any kind of oscillator it's that bad. But it is enough to claw back some of my dignity for now.
So it looks like I'm out for the time being. I'm going to have to now find some time to repair the spec-an.
The following users thanked this post: SilverSolder, joeqsmith, mnementh, ch_scr, 0culus
Online mnementh
« Reply #208 on: June 20, 2020, 11:28:51 am »
Taking the new oscillator for a test drive and blowing the old record out of the water and it's only in first gear idling...      Added a scope shot to make it official.
What an adorable little Faraday cage! Just the right size for a Lego guy and his cellphone!  :-DD   No, seriously... righteous sqwawk, man.  :-+
*tosses peanuts at Oculus and shells at ogden*
Go sine wave! rah, rah, rah!  ;)
*Impairing SNR since nineteen-mumblety-mumble*   >:D
« Last Edit: June 20, 2020, 11:30:41 am by mnementh »
Offline 0culus
« Reply #209 on: June 20, 2020, 03:08:54 pm »
I did? I even posted photos and spec an screen grabs. ogden is right, of course. That stupid pcb the transistor is mounted on is probably causing all sorts of havoc, but I see little point in trying to desolder such a tiny part when I am already planning on ordering some new parts which will come on a tape.  >:D I reached a new personal record, and to be fair since the fundamental and the second harmonic are all but equal, I'm only claiming the fundamental here.  :-+ I was able to get a counter to grab the second harmonic but it wasn't stable so, I'm going to make a judgement call and say that it doesn't count...see what I did there?  :-DD
Rules clarification: if I manage to get the (erstwhile) second harmonic larger than the (erstwhile) fundamental, can I claim success under the clause "distorting and leeching harmonics"? If so, I finally got something out of the 2SC5227. It's rather unstable and the waveform isn't pretty.
As ogden pointed out, the counter will need to count the harmonic. You will probably need more than 3dB suppression of the fundamental for that to happen.
Bear in mind, with 1.5pF breadboard parasitics, you would need single digit resistance for a 10GHz RC high pass filter.
But i am ready to be proven wrong by voodoo engineering any time! :-D
Fair enough. My sleep deprived brain came up with this monstrosity.  :-DD The fundamental and second harmonic are essentially equal, but sadly the second harmonic is already getting pretty far outside the 7104 (and FET probe's) passband so I can't see what it looks like in time domain with my current tools. Basically, it's the same Colpitts oscillator except with the 2SC5227 transistor (which had already been helpfully mounted in a tiny PCB with legs for breadboarding) and this train of inductors that aren't directly in the circuit but are modifying the parasitics.
Offline joeqsmith
« Reply #210 on: June 20, 2020, 03:15:15 pm »
Is it possible to beat against another oscillator nearby and pick the difference signal up with the instruments that have run out of breath?
Yes.  This was also covered in those early videos and some of my posts.  Trash was also confused by it.  Maybe this post will help you:
https://www.eevblog.com/forum/projects/challenge-thread-the-fastest-breadboard-oscillator-on-the-mudball/msg3095837/#msg3095837
As I mentioned in that post, the oscillator is only good to 8GHzish and the mixer had a max IF of 4GHz, so  8+4=12GHz was about it.  The next limit was the DSO which has an analog BW of 5GHz but my Signal Hound is good for 6GHz.   In the following post I show the Signal Hound looking at the previous record holder.   You can see the signal is there but it's suppressed.
https://www.eevblog.com/forum/projects/challenge-thread-the-fastest-breadboard-oscillator-on-the-mudball/msg3097054/#msg3097054
There has been a fair amount of information posted if you care to dig into it.    Better yet, build something!  Be the second member of the 5GHz club!!
Online PA0PBZ
« Reply #211 on: June 20, 2020, 03:20:13 pm »
@joeqsmith, can you post a picture of your setup that shows all the details (like I did)? I've seen the video's (too far away or too fast panning) and I've seen the pictures of some details but I think I've not seen the whole picture? Correct me if I'm wrong and then point me to what I missed please.
Offline SilverSolder
« Reply #212 on: June 20, 2020, 03:49:56 pm »
I watched the video and I am beginning to see what you are doing.
I'm still trying to understand the limitations at DC and 400Hz so 5GHz is a bit down the road!  :D
Offline joeqsmith
« Reply #213 on: June 20, 2020, 04:07:54 pm »
That's too bad.  I thought you may have been the second one to reach 5GHz.
Offline joeqsmith
« Reply #214 on: June 20, 2020, 04:11:09 pm »
There have been a few.  This is the one that I was referring to where I show a software simulation of LeCroy's DBI.  It seems like we may have had a visit from one of LeCroy's VPs.
« Reply #215 on: June 20, 2020, 04:13:31 pm »
That's the one I watched.  I liked the software sim idea.   Did you do that in LabView?
« Reply #216 on: June 20, 2020, 04:41:30 pm »
That was not directed at you mate, but ogden.
Offline joeqsmith
« Reply #217 on: June 20, 2020, 04:55:47 pm »
Yes, that's in LabView.   With it being YouTube, I wanted some sort of visual demonstration and wasn't able to find anything LeCroy had put out.   As Roger points out, it's a simplistic view of it.   Still, with the two counters and siggen, you should get a sense of how the down conversion works.
Basically every part I used on that first down converter would need to be replaced in order to look at this new oscillator.  There is a limit to the parts Mini-Circuits offers.    Shown is the new mixer, filter, amp and some coax sections for it.
The original goal was to exceed what the counter could display and I wrongly guessed it would overflow at 18GHz but it seems like the tests with the comb generator show it closer to 21.5GHz.   It's over what the mixer is good for but we should be able to get something up on the Signal Hound and my old LeCroy.
https://www.minicircuits.com/WebStore/dashboard.html?model=ZX05-24MH-S%2B
Offline 0culus
« Reply #218 on: June 20, 2020, 05:03:24 pm »
Sorry, I couldn’t tell since you didn’t quote him. Anyway, I said my piece and won’t say any more on the subject. :)
Online PA0PBZ
« Reply #219 on: June 20, 2020, 05:09:41 pm »
No problem.  There's 6 pages of history now.  I'm guessing its becoming too much to follow.  These are what I consider my key posts from the earliest to the most current.
None of these show the complete circuit at a size we can see what's going on. I'm asking for something like this:
Or this:
The following users thanked this post: ogden, mnementh
Offline joeqsmith
« Reply #220 on: June 20, 2020, 05:18:25 pm »
We (again) are approaching dangerous rule bending territory.
Does that mean you have something technical to contribute?   I would allow you to bend every rule you like with your 555 timer IC.  Just that fact that you actually did something with electronics after all these years would be impressive!!   :-DD
... I am stirring the pot, for entertainment purposes. ...
Of course you are.  It's the whole point of trolling.
Offline ogden
  • Country: lv
« Reply #221 on: June 20, 2020, 07:44:47 pm »
No. I just pointed at few issues of the contest. Your retaliation with insults, 555 timer sarcasm - that's trolling.
Offline joeqsmith
« Reply #222 on: June 20, 2020, 09:21:45 pm »
I'm sorry that you took those 555 comments as sarcastic.   I just assumed this was your skill level or at least something you could actually tackle.   I bet you could find some beginners videos showing how to hook one up.   Maybe add a your own twist to it, like a flashing LED.  You like LEDs don't you??   :-DD :-DD :-DD
Now that I understand that the 555 would be a pretty big first step for you,  to help you get started, I did a Google search for a simple oscillator and came up with the following link:
http://jlnlabs.online.fr/cnr/negosc.htm
I know it seems very complex and while the physics behind it are, building it is not too bad.   Picture showing the scope attached to the base.  179 is looking at the base, 180 is at the emitter.    Transistor is a 2N2222A.   Try it.  You may find it more fun than spending your time trolling the forum.
Sorry, I forgot to add an LED.   Kids like flashing things right??
Pic2 shows the setup.  Note the resistor in parallel with the LED.  Scope again attached to the base in 175.   You could adjust the Rs, C and voltage to get the effect you like.
« Last Edit: June 21, 2020, 03:00:30 am by joeqsmith »
Offline ogden
  • Country: lv
« Reply #223 on: June 21, 2020, 05:51:44 am »
WTF is wrong with you.
[edit] Why instead of building hate device, taking pictures of it, you didn't answer this post:
« Last Edit: June 21, 2020, 07:39:57 am by ogden »
« Reply #224 on: June 21, 2020, 11:02:50 am »
A competition on how fast a 555 can be made to run, would be a good one for a different thread! :D
