Some people have been saying the nickel sheets cause current sharing issues because they are simply pressed together with plastic. This could cause the CID to trip
That's a very strong hypothesis. Paralleling cells is good practice and safe, but it requires top-notch, similar-resistance connectivity between the cells if currents are going to be high. The "press together" design is horrific; intermittent connections that come and go are worst even at low currents because cells can drift to different state-of-charge and when they reconnect, nearly unlimited current flows, and what's worse, that's charging current from the perspective of lower-voltage cell. Instant self-destruction.
In a paralleled design where N is just ~dozen max, design must rely on any CIDs or PTCs never triggering because that causes a cascade failure. Now arguably if you put, say, 60 cells in parallel like Tesla did in their first generation pack designs (before their cell customizations), then one or two cells getting disabled by CID is not going to cascade because current seen by other cells rise only marginally.
Absolutely. And I wonder how well these cells are matched before they are put into these parallel packs. Yeah, the press together is horrid. Their other pack does not even have mechanical connection between their cells packs and there are many failures with that design. I had one vent in my backyard, and I know an individual in hawaii with two failed packs in a single day.
I have noticed that the internal resistance is all over the place after you stop charging or discharging. I think this is because the current is still moving between the cells because there is a current sharing issue. With prismatic packs with only 4 cells instead of 120 cells, the ir is very consistent when you stop charging or discharging. Yes exactly! And there is neoprene pushing the packs together. As with all plastics, it will lose its rebound effect over time. Add in some high ambient temps and that pressure on the electrical connection is reduced. Game changer battery is the worst in this regard. They use the actual case to hold the electrical connections together. This is probably why I found arcing in a pack after only 1.5 years of use.
Oh good point about drift at soc extremes.
Yes very true about the tesla packs. And those were matched with high quality cells. The cells they use are UL listed but that does not mean much these days. I cannot find any high performance cells in the size cell they sell. And going by the labels in packs I open, they have multiple suppliers.
Great point and I was super confused by this as well until I looked at the data and then reproduced this exact same event in another battery. So what we are seeing here is a cascade effect. The more cells that are lost, the more current going through the remaining cells. One by one they disconnect with the CID in the top of the cell.
Here is my graph of before and after in a second battery to reproduce this: https://diysolarforum.com/threads/12x-battleborn-batteries-w-9-years-of-service.127226/post-1870621
I post whatever I find and then we argue about it on the forum. I have the graphs for both tests, for both batteries.
Ah okay, I guess that could explain why you reported capacities >26% in one video, then saw <15% in the next. Some more cells probably went open circuit in between due to your testing.
One thing I screwed up is saying IR was 0. I should have said OL or something else. I did mess that up.
btw what instrument do you use to measure ESR of large cells/batteries? Looks like some Finisri box, but with only two leads. I would assume a decent ESR reading would require a four-lead measurement.
And what was wrong with the solder test? That has been mentioned a lot. And of course it is low resistance. Did you see my other crimping videos where I measured voltage drop across something like 40 different cables I made? what was wrong with the tests? I am here to learn
I don't think anything was wrong with the resistance test itself. But why did you do it if you were just going to handwave it away at the end of the video?
Lawsuit update
Here's my 2c advice: There's obviously a ton of issues you could go after Dragonfly for, but I recommend just focusing on the ones directly relevant to Dragonfly's complaint (not sure what those are, since you say the amended it). Dumping too much info on a judge/jury might just confuse or frustrate them, which isn't good for you.
Yes Finisri but it is a four lead probe, even the clamp one. I have tested both of their probes and they are consistent results and I have two meters. I do not know of a battery ir meter that has two wire probe. They are all four wire probes.
What do you mean by handwave it away at the end of the video? I do not know what to expect when I make my videos. Oh! You mean the low resistance. Yeah it was impressive! That was a cool result. But solder cannot be relied on for large cables. Just because it is a low resistance connection does not mean it is strong or can handle heat. Crimp is going to win and why it is industry standard for 40 cable.
Ok understood. I am just trying to figure out the disconnecting cell part. The other stuff in the lawsuit, dragonfly energy is being sued for currently. The president of the PVICC who helped created multiple UL standards is suing them. The thermal failsafe thing is so easy to disprove. I just want to find out why these things have meltdowns and cascade failure/loss of capacity. It is quite literally in 100% of batteries I have tested, and every single cell pack I have found. The cell venting is terrifying. Actually the cell venting video is in the lawsuit. I still do not know what to do with that battery. Really nasty stuff.
If anyone has any idea why these cells disconnect I am all ears. I love this forum and have learned a lot from in years back. Lots of smart people here. I just do tests in my shop and share what I find.
