Author Topic: Dymo 550 Thermal Printer DRM Hacking  (Read 163818 times)
0 Members and 16 Guests are viewing this topic.
Offline js_12345678_55AA
  • Country: ht
Re: Dymo 550 Thermal Printer DRM Hacking
« Reply #200 on: December 16, 2024, 04:24:27 pm »
Meanwhile I created a new release (v1.1.1 on Github) which should fix the pass through problem introduced with v1.1.0.
=> https://github.com/free-dmo/free-dmo-stm32/releases/tag/v1.1.1
Next few days I should have some more time to check everything with my 550 Rev. K.
JS
Easy PDK programmer and more: https://free-pdk.github.io
The following users thanked this post: Axis-3790, kko
Offline Axis-3790
« Reply #201 on: December 18, 2024, 11:05:37 pm »
Rev I
550 Turbo QF4
I have tested v1.1.1 and it is showing improvement compared to the previous version. It will now detect official dymo branded labels w/ the bluepill. No flashing lights. It did not take the default 30336 label when I tried testing an after market roll.
Offline Bastelwastl
« Reply #202 on: December 23, 2024, 06:35:23 pm »
@JS, thanks for the early x-mas present, works fine :-+
@Axis-3790, did you try to flash another precompiled .bin from the v1.1.1 ZIP File?
Offline Axis-3790
« Reply #203 on: December 23, 2024, 11:16:33 pm »
I did not use a precompiled. I have been compiling my own firmware via WSL everytime. I can use a precompiled firmware if that is the recommended method.
Offline lemonotype
« Reply #204 on: December 30, 2024, 05:11:14 pm »
Hello everyone!
I signed up to:
1. Thank everyone involved for doing god's work and letting me use a machine I paid for as I see fit.
2. Report my experience / findings as I didn't see them outlined here exactly.
Here's how it went:
1. I bought the machine (5XL) mid-December off Amazon, flashed 1.1.1 on Bluepill and it immediately worked fine.
2. A day or two (and less than 10 labels) later it started showing up as empty on Dymo software.
3. The only way to get it to print was to send labels to print, get the empy error, then turn it off and on, it would print all labels then start flashing again.
4. Today I decided to dig up a solution, found this thread, opened it up again and looked for the two pins to short... but the chip wasn't there.
5. I found it hiding on the bottom of the board, joined the pins, and the printer has correctly been reporting 219 labels and online for a few hours now... fixed?
PCB says RevD
Adding a couple photos, maybe it's useful to someone, thanks again and... see you next time it stops working  ;D
EDIT: Welp the issue came back again, guess I'll lurk around and wait for a fix lol.
EDIT2: Actually uhh it seems to be working fine now, so maybe the write protect did the trick after all.
« Last Edit: January 01, 2025, 08:53:06 pm by lemonotype »
Offline Cali250402864
« Reply #205 on: December 31, 2024, 06:44:35 pm »
Forgive me for the stupid questions...  I recently fell into the Dymo 550 trap. From what I understand from this thread, the hack requires modification to the hardware in order to modify the code/program?
Is it possible to clone the NFC code onto blank tags? Has anyone tried yet?
Offline Axis-3790
« Reply #206 on: December 31, 2024, 10:40:00 pm »
This thread is related to a bypass of reading the chip on the 550's. It is through the method of installing an STM32 board between the NFC reader and the main board. You do not necessarily "modify" the hardware but add to it. The STM32 is emulating the chipped labels and just modifying the label count on the NFC. I believe we cannot clone the NFC onto a blank one due to the label count being stored in the dymo itself. I highly recommend reading through the 9 pages of this thread if you are wanting anymore info. I am just another user who is thankful for the bypass as the cost of labels is a literal 10x price difference.
Github w/ instructions on what to do: https://github.com/free-dmo/free-dmo-stm32
Offline Fara
« Reply #207 on: January 12, 2025, 06:20:17 pm »
Received a new Dymo 5XL.
PCB rev: I
Date: 20221017
Different EEPROM (BL24C128A), located on the front.
As I understand, legs 7 and 8 should be connected for WP mode, right?
Offline voltsandjolts
« Reply #208 on: January 12, 2025, 06:34:08 pm »
Correct.
So, just to be clear, solder blob where the red dot is on attached image.
Offline Axis-3790
« Reply #209 on: January 14, 2025, 10:48:02 pm »
Let me know if this works for you. I have a Rev I and I attempted to solder 2 legs together with no success.
Offline Pardini
« Reply #210 on: January 23, 2025, 06:16:32 am »
4 more readouts from me...
Offline Fara
« Reply #211 on: January 29, 2025, 02:33:02 am »
I can confirm that the hack works on the Rev. I board.
It does not want to simulate the tags/rolls. So it only works with real tags but resets the number of labels left after power down. So more than enough for me.
Offline Pardini
« Reply #212 on: January 30, 2025, 03:16:14 am »
@Fara have you write-protected the EEPROM on the motherboard with the solder blob method on pin 7/8? Or does it work without modification to the mainboard?
Offline Fara
« Reply #213 on: February 05, 2025, 02:22:05 am »
Yes, it works only with the write protection.
Offline AKRUA
    • GitHub
« Reply #214 on: February 05, 2025, 05:15:15 pm »
Howdy yall, im new to STM32 stuff, and hardware mods, my work has a couple dmo 550 turbos, im trying to setup the bluepill for it. when i flash the firmware to it, it seems to be successful, but when i plug it into the printer, the light on the printer just flashes. Sometimes, the light on the printer will be solid for a couple minutes, but as soon as you try to print or do anything, it will just start flashing. I am not using the original RFID board pass through, and am just trying to emulate labels. I have also added the solder blob on the main board of the printer to add the write protection. Any suggestions or guidance wopuld be greatly appreciated. Thank you.
Offline Axis-3790
« Reply #215 on: February 06, 2025, 06:09:23 pm »
What board revision do you have?
Offline AKRUA
    • GitHub
« Reply #216 on: February 06, 2025, 06:33:06 pm »
I know the last digit of the serial number in the printer is a C, but im not sure how to find the board revision. How would i find that?
Offline Axis-3790
« Reply #217 on: February 07, 2025, 02:55:53 pm »
It is on the board itself. You can see an example on some of the pictures on this thread. Some users have posted pictures of their boards. You will see a section that looks like it has a QR code and below that you will see a revision abreviated to Rev. (letter).
For example, I have Rev. I
If you follow the thread, you will see users have posted a handful of revisions that are working for them.
Offline AKRUA
    • GitHub
« Reply #218 on: February 07, 2025, 03:09:16 pm »
It is a rev I
Offline Axis-3790
« Reply #219 on: February 07, 2025, 07:08:16 pm »
It is a rev I
Supposedly you can use the blob of solder on the pins to reset the label count on official labels but I have yet to get emulation to work on Rev I boards. I have 2 dymos that are Rev I. I am awaiting an update to see if we can get emulation to work on Rev I.
Offline AKRUA
    • GitHub
« Reply #220 on: February 07, 2025, 07:10:09 pm »
It is a rev I
Does it need to pass thorught the STm32 or can i just use the original hardware with the solder blob?
Offline AKRUA
    • GitHub
« Reply #221 on: February 12, 2025, 07:27:23 pm »
Ok, so i have the printer set up with the pass through, and the solder blob write protection, i have a precompiled bin flashed to the stm32, my board is a REV I so i have a dymo rfid tag on the reader.
I no longer am getting the "out of labels" error, but am now getting a "unknown label type detected"
Do i need to re flash the stm32? Do i need to compile my own binary? Im kinda lost here.
Offline Axis-3790
« Reply #222 on: February 13, 2025, 04:28:24 pm »
I have been waiting over a month for another update on this. I believe Rev I is the problem board now. The only idea I have now is to get a different Dymo for a different version board. Maybe go on eBay to find someone who is angry with their older 550 turbo. Otherwise you might be here stalking the forum every few days like me  ;D
Offline AKRUA
    • GitHub
« Reply #223 on: February 13, 2025, 05:07:43 pm »
 |O
Offline AKRUA
    • GitHub
« Reply #224 on: February 13, 2025, 05:09:21 pm »
Have you got the pass through to work? I have a few dmo label rolls that I can use for the rfid if I can just find a way for pass through to work
