Author Topic: Solder paste/flux manual syringe applicator  (Read 222900 times)
0 Members and 36 Guests are viewing this topic.
Offline mike_58
  • LEGO playground
Re: Solder paste/flux manual syringe applicator
« Reply #225 on: December 15, 2015, 05:16:34 pm »
Hello all - here I found interesting approach with lots of reality incorporated in this SmartDispenser - NO AIR !!
http://gentec-benelux.com/airfree/
LDS9000 et SmartDispenser
Sturdy precision machined screw and precision motor assure zero backlash during operation which eliminates any leak in the hydraulic line chance of pressure loss.
The stepper motor is directly engaged with the screw eliminating lags and backlash, and is preventing any chance of pressure loss.
Patented Precision machined Piston Stabilizer holds the piston straight in the reservoir, eliminating any chance of pressure loss.
PosiLok™ Quick Release threaded hub and piston allow zero slippage between the piston and drive rod, eliminating any chance of pressure loss.
NoFlex™ Linear Drive Technology gives you the accurate and repeatable method of positive displacement you want without the headache of pneumatic systems. There is no need to flush chambers or valves. Formulations stay untouched in safe, silicone-free barrel reservoirs with this revolutionary new system. You can change fluids or volumes with ease. Unlike AirPulse™ machines, this intelligent dispensing system knows the barrel size, volume and the dispense rate. The result: you get a process control that is unachievable with AirPulse™ systems. profitability.
SmartDispenser™ uses air-free, linear-drive dispense technology to achieve the highest repeatability when dispensing assembly fluids. This technology allows manufacturers to establish one dispense program globally, with no change to fluid deposits. By standardizing dispense programs per product, manufacturers reduce the cost of product validation. The technology also eliminates fluid waste, rework, rejects, and costly air compressors, thus maximizing
By integrating the Windows 7 platform into its technology, each SmartDispenser™ system can be networked to a desktop, laptop, smartphone, or another SmartDispenser™. This technology gives you the ability to monitor live video feeds and real time production data, and enables.
Offline zapta
« Reply #226 on: December 15, 2015, 05:27:46 pm »
Looks expensive, how much? Would be interesting to buy just the dispenser and build a DIY controller for it.
Offline mike_58
  • LEGO playground
« Reply #227 on: December 15, 2015, 05:44:41 pm »
It is for sure not in price range of my Dispenser, it comes with a magic box -controller...
http://gentec-benelux.com/wp-content/uploads/2015/09/CATALOG-GENTEC.pdf
BUT THE POINT IS STEPPER DRIVEN SOLDER PASTE DISPENSER WILL TAKE LEAD in dispensing - AIR REQUIREMENT IS NIGHTMARE TO ME!!
« Last Edit: December 15, 2015, 05:47:08 pm by mike_58 »
Offline mike_58
  • LEGO playground
« Reply #228 on: December 16, 2015, 10:40:25 am »
Try this one : http://online.flipbuilder.com/rjbj/pjpy/#p=1
Enclosed as well table of Volume Chart  ...
Offline mike_58
  • LEGO playground
« Reply #229 on: December 16, 2015, 10:49:11 am »
Offline mike_58
  • LEGO playground
« Reply #230 on: December 17, 2015, 09:00:38 pm »
Hello Zapta - I asked for data /here reply to my/your price Question:
Fishman has 18 different applications for fluid dispensers,  they range from $9,000 - $12,000.
If you would like to proceed with a quote, we will need more information from you.
*Address
*Industry
*What are you dispensing?
It is Fishman Corporation policy that all our potential new clients be scheduled for a conference call with one of our dispensing technicians. This gives them a better understanding of your dispensing needs.
Offline mike_58
  • LEGO playground
« Reply #231 on: December 19, 2015, 09:28:57 pm »
Here some photos of my today work -looking good to me... Needle Gauge 23-24     (Inside Dia 0.38 -0.41 mm?)
http://wordpress.mencinger.biz/
video here: https://youtu.be/o4PbVOhY2UQ
« Last Edit: December 20, 2015, 08:32:15 am by mike_58 »
steverino
  • Guest
« Reply #232 on: December 20, 2015, 11:09:40 pm »
*Address
*Industry
Just to clarify, as it wasn't immediately apparent to me, the unquoted text starting from "Fishman has..." was the text of the response by Fishman corp.  For a minute, I thought mike was representing Fishman products.
Offline mike_58
  • LEGO playground
« Reply #233 on: December 21, 2015, 07:14:39 pm »
Hello - good point !   Definitely I'm not representing Fishrman Corp.....
Offline xebbmw
« Reply #234 on: December 21, 2015, 09:30:59 pm »
I came across this web page Change unipolar 28BYJ-48 to bipolar stepper motor  http://www.jangeox.be/2013/10/change-unipolar-28byj-48-to-bipolar.html
might be useful to get more power/torque out unipolar stepper ....
@Zapta: would be interesting to test your dispenser by using the same motor but with a higher torque. I guess you would need to change the driver to a bipolar driver for the motor.
« Last Edit: December 22, 2015, 02:28:17 pm by xebbmw »
Offline mike_58
  • LEGO playground
« Reply #235 on: December 21, 2015, 09:59:25 pm »
The   28ybj-48     stepper motor would need to me slightly modified to be used as bipolar stepper motor - in addition there is integrated tention clutch in that motor - see video -
Offline mike_58
  • LEGO playground
« Reply #236 on: December 27, 2015, 08:51:55 am »
Online 0xdeadbeef
« Reply #237 on: December 27, 2015, 10:31:38 am »
My understanding is that you don't even need to modify the stepper to use it as bipolar stepper. Just leave the red wire unconnected. Doesn't hurt to cut the trace though if you don't intend to use it as unipolar stepper.
https://learn.adafruit.com/adafruit-arduino-lesson-16-stepper-motors/overview
Offline mike_58
  • LEGO playground
« Reply #238 on: December 27, 2015, 11:29:50 am »
Correct, but you need to change from ULN2003 to L239D driver!
Online 0xdeadbeef
« Reply #239 on: December 27, 2015, 11:44:16 am »
Sure. That's also clearly described in both of the links (with and without cutting the trace).
Offline mike_58
  • LEGO playground
« Reply #240 on: December 27, 2015, 04:50:57 pm »
Why don't you try some other gear & bi-polar stepper motor if Trying is the first step towards failure ?
Canada: http://www.ebay.ca/itm/R119573-BAS-Bioanalytical-Systems-Beehive-MD-1001-uL-Min-1ml-Syringe-Pump-/391306678916?hash=item5b1bb21284
Tip: http://www.ebay.com/itm/271938887974?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
« Last Edit: December 27, 2015, 06:16:15 pm by mike_58 »
Offline zapta
« Reply #241 on: December 27, 2015, 04:58:33 pm »
I think you also need to increase the voltage, otherwise you get half the current and double the number of turns so no chance. Unless if you manage to have the two halves in parallel in the right polarity.
Offline mike_58
  • LEGO playground
« Reply #242 on: December 27, 2015, 05:19:23 pm »
Works fine to me on 4 wire 5V -
Offline mike_58
  • LEGO playground
« Reply #243 on: December 27, 2015, 05:48:06 pm »
Motor Code MICRO MO Electronics Inc AM1524-2R-V-12-150-07  next line 15/5S262:1  Seam like 262 :1 gear ratio.
Offline zapta
« Reply #244 on: December 27, 2015, 11:50:33 pm »
Yes, but does it really give significantly more torque since it uses now roughly half the current?
Offline mike_58
  • LEGO playground
« Reply #245 on: December 28, 2015, 08:11:28 am »
Quote from: zapta
[/quote
You can find your answer here:
"Finally, most importantly, my torque test resulted in :
800gcm !!
which is at least twice as much as full stepping unipolar (380gcm) and almost 3x more powerful than my half stepping unipolar test (300gcm)
Basically, if I cut one wire in the motor, it gains almost 3 times its original strength."
Offline zapta
« Reply #246 on: December 28, 2015, 08:24:50 am »
But that 800gcm is not with 5v :)
The torque gain comes from going from 4v (the ULN Darlington has 1v drop) to 9v.
Offline mike_58
  • LEGO playground
« Reply #247 on: December 28, 2015, 02:24:32 pm »
There are several versions of this motors 5V and 12V.......  - see https://grahamwideman.wikispaces.com/Motors-+28BYJ-48+Stepper+motor+notes
Torque results
See All torques in gram-force * cm.
Most notably:
Note 1: My test for pull-out get to about 200g x 10cm, and at that point broke teeth in the gear train. See images below.
Note 2: Neither Adafruit nor RioRand [as of current writing] list a pull-in spec, a spec which is crucial for actually moving a load.
Note 3: Adafruit's spec for pull-out torque is low by a factor of six! That is, the motor is six times more powerful (in holding) than Adafruit says it is.
Note 4: Perhaps unsurprisingly, the RioRand 5V motor's pull-in torque was about 4x that of the Adafruit 5V motor, corresponding to the 4x greater step-down gearing.
Broken teeth while testing pull-out torque......
Offline moya034
  • Former Welder, IT guy, and Ham Radio Junkie
« Reply #248 on: December 28, 2015, 06:32:41 pm »
I see the thread here has taken a turn from the original question, but figured I'd share this dispenser, (Loctite brand for $35USD), I Just ordered it last week, should get it anyday:
https://www.all-spec.com/products/98815.html
Allspec also sells the Loctite needles in a variety of gauges.
Offline mike_58
  • LEGO playground
« Reply #249 on: December 28, 2015, 07:27:07 pm »
Juup - moving with the flow!
