Author Topic: Experimenting with waveguides using the LiteVNA  (Read 138746 times)
Offline msat
Re: Experimenting with waveguides using the LiteVNA
« Reply #450 on: August 12, 2023, 03:55:15 am »
Hey guys
I know this is somewhat off-topic but I felt this is the best place other than maybe a new thread to discuss this.
I finally got around to doing a little microwave experimentation. However, since I never jumped on some crappy but cheap-ish ebay WR42 horns for my coax to waveguide adapters when I had the chance, and been somewhat reluctant to 3d print (and paint) some, I instead opted for a couple of ~10GHz gunnplexers. In my recent experimentation, I used one as a transmitter, and then measured the output of the detector diode on the other which is thus used as the receiver.
As you can hopefully see in the attached image, I printed a mount for them that allows me to adjust the angle on the longitudinal axis from 0 to +/-90 degrees in 22.5 degree increments, with the center of rotation being the center of the gunnplexer.
So in my little experiment, I was getting some baseline voltage reading at the detector when both tx and rx were oriented at the same angle (same polarization), and then measuring the decrease in voltage as they're rotated relative to one another. I wanted to compare and contrast this with what polarizer experiments seem to show.
At 22.5 degree relative angle, the received voltage is 75% of baseline. This makes sense from a trigonometry standpoint. At 45 degrees however, it drops to 25%, which is not expected. These results are consistent regardless of distance between tx and rx, and the way I orient them to get the relative angle differences. Right now I'm thinking these unexpected results are due to my hardware. Soon I'll be modifying some satellite LNBs, specifically because they use round waveguides/horns, to perform the experiment with. However, I was also hoping someone here could duplicate the experiment on their hardware and post their results if they could find the time. Any of you guys willing to do that?
Offline joeqsmithTopic starter
« Reply #451 on: August 12, 2023, 04:07:15 pm »
Far more on topic than much of what has been posted.   :-DD   Walter Lewin had a lecture on this.  Lucky for us, MIT/France could not purge the internet of his content.   In the video, he conducts a demonstration starting at about the 1 hour mark.
For off topic, I would have liked to have all the details about that sexual harassment case.   I can't imagine anyone who would self-mutilate rather than simply dropping a course and turning off their PC.  I searched her after the fact and while I don't know enough to form an opinion one way or the other over the case, I am glad that we still have access to the content he created.
https://www.govinfo.gov/content/pkg/USCOURTS-mad-1_16-cv-12394/pdf/USCOURTS-mad-1_16-cv-12394-0.pdf
« Reply #452 on: August 13, 2023, 06:18:07 pm »
During my short visit on the V2Plus group.io, I had noticed someone asking about using theirs to measure waveguides.  The advice given was IMO poor as obviously anyone following this thread would know.  I attempted to post a comment to them but sadly, they once again censored it and it never showed.
IMO, people who actually want to discuss the V2Plus4 should just ditch that group.io reflector and use a different group or forum.
https://nanorfe.com/forum/using-V2-plus-4-Pro-for-waveguide.html
Offline msat
« Reply #453 on: August 14, 2023, 01:07:29 am »
I have watched that lecture by Walter in the past, among other ones of his. However, it doesn't provide the data I'm interested in unless I guesstimate it. I've tried to do this on a few other videos with similar demonstrations, but it's unsatisfactory.
I've been wondering if part of my issue the way I'm interpreting the values from the detector diode. I'm merely hooking up a volt meter to it, while the gunnplexer itself has the diode shunted to ground via a 1k resistor and a zener (it was there when I bought it).
Per https://www.qsl.net/in3otd/electronics/power_detectors/power_detectors.html "As known, the diode detector output is proportional to the square of the input voltage/linear with the input power at low power levels and becomes proportional to the peak voltage/square root of input power at higher levels."
I'm still trying to wrap my head around that, and how relevant it is. Like I said before, the results are the same regardless of the distance between the tx and rx (which does have an effect on the baseline voltage reading).
Tangential to this, I got my couple of "Ku" satellite LNBs in the mail, which I ordered new from amazon for ~$10 each. I was a bit premature in my purchase, neglecting to realize such new and cheap parts were highly unlikely to use dielectric resonators or really much of any discrete circuitry, making electronic mods pretty much a no-go. To top it off, naturally many of the passives are among the smallest SMD sizes available. I then thought that *maybe* I could hook it up to my TinySA Ultra and use that to measure received power, but in the almost non-existent spec sheet for the nearly all-in-one LNB IC, it states that it does some automatic gain nonsense, so there goes that idea too  |O The only usable component may be the waveguide, but then I need to figure out the electronics, and I don't currently have a suitable LO source, mixer or LNA. Maybe I should just go the diode detector route?
« Reply #454 on: August 14, 2023, 01:05:19 pm »
You should start a thread for your project.  I would provide details about the goals you have in mind, your background, work you have done so far.    Others may have a similar interest and chime in.
Problems with using this thread, it long and people don't take the time to read.  It's difficult for readers to locate sub topics.  Then, I started the thread to cover some basics on waveguides.  Anyone reading from the start may loose interest and never discover your project.
To be clear, I don't mind you posting here but rather just offering a suggestion if you are looking for help on how to increase your exposure.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #455 on: August 24, 2023, 01:46:28 am »
We're both proceeding at a snail's pace.  :-DD
« Reply #456 on: August 24, 2023, 01:17:49 pm »
Slow indeed.  With it being used,  I had to test it first to make sure the performance was still good enough.    I've thought about mounting it all into a box to make it a bit more robust and take up less room.    There are some nice extruded aluminum cases but that coupler and cables would need about 10" depth assuming I let the APC7 connector extend outside the box.
« Reply #457 on: September 06, 2023, 01:28:29 am »
Roughly $50USD from China.  The faces are a bit thin and I think I would machine a new face for the front with 1/4" plate aluminum.   Something to ponder over the winter.   It's a lot of junk to cram in that small box and I would want some decent bulkhead connectors.
« Last Edit: September 16, 2023, 07:39:03 pm by joeqsmith »
The following users thanked this post: all_repair
« Reply #458 on: September 16, 2023, 07:59:49 pm »
My plan is to make it a clam shell so the two boards fold up.  A while back I had posted my attempts to repair a damaged semi-ridged cable.  Thread shows the bulkhead connectors I plan to use.
https://www.eevblog.com/forum/rf-microwave/is-is-possible-to-repair-a-hairline-crack-in-semi-rigid-coax/
Decided against running the the APC7 through the case.    All the RF connectors will be routed to the front,  P1 to the bottom left,  P1extended to the top left.   Single toggle switch will also be mounted on the front to select between S11&S21 maybe in the center, along with the 10MHz reference clock input.    Power connector may be off the rear.
Offline xrunner
« Reply #459 on: September 17, 2023, 01:12:29 am »
Looks very professional so far. Almost like ... you might even know what your doing.  :popcorn:
« Reply #460 on: September 18, 2023, 12:54:07 am »
Mounted the parts on the lower board and made up cables for it.   Stacking the two boards, there's a good 10mm to spare.    Still debating to route out the APC7 or not.   I'm not liking the idea of stacking all those connectors.  Unlike the ham in the photo who placed several connectors in series,  at 12GHz it may present more of a problem.
Offline xrunner
« Reply #461 on: September 18, 2023, 12:11:19 pm »
LOL I dispelled that myth myself a few years ago. The HAMs would say "Don't use an adapter in-line because it'll cause a few dB of loss!"
I connected seven misc adapters together and ran some tests. Tests? Tests? How dare you actually try to see what's really happening!
 :-DD
Turns out it's all BS advice. At HF seven adapters causes less than 0.1 dB loss, and at 144 MHz around 0.3 dB loss.
They don't say that anymore.  :P
« Reply #462 on: September 18, 2023, 01:24:03 pm »
Looks like that video is 3 years old.  Skimming his video, looks like he may have tested to 30MHz and saw a 0.12dB loss.
I may put everything together and compare it against the data I already collected.
« Reply #463 on: September 18, 2023, 01:37:01 pm »
Looking over his videos, it appears someone wrote him about it.
Offline xrunner
« Reply #464 on: September 18, 2023, 02:34:01 pm »
Well, let's put it like this. I used adapters that were in good condition (what other kind would I have?  :) )
If you connected a few adapters used in the field, like up in the air for 10 years, with no waterproofing, with no care in the world, yea you might get a higher loss. But that's not the fault of the adapter, it's on the HAM's maintenance habits.   :box:
« Reply #465 on: September 18, 2023, 04:08:58 pm »
I was imagining someone using RG174 and SMA connectors.  They check the loss with their VNA or other and measure some small loss.    Then they connect it to their 2kW amp...  Should be fine...  :-DD   I'll just crank up the power to compensate for the losses... :-DD
Remember that gold plated PL-259 to N adapter I used as part of my homemade Watt meter testing.   I was seeing a pretty good temperature rise with it even at 300W CW (or what ever I was running).  Wonder when it goes into thermal runaway.  :-DD
Anyway, my point was while we are dealing with small signals (<10dBm), the frequencies are in the 8-12GHz, not <30MHz.
« Last Edit: September 18, 2023, 04:29:01 pm by joeqsmith »
Offline xrunner
« Reply #466 on: September 18, 2023, 10:45:40 pm »
Joe are you using in your project semi-rigid coax? It all looks like hardline. I think I want to try my hand at making up some semi-rigid lines with SMA connectors. So I wanted to know if you had used that type before. What do you use to cut the ends with? I plan on looking at some tutorials in the next few days.
« Reply #467 on: September 19, 2023, 01:46:28 am »
Offline xrunner
« Reply #468 on: September 19, 2023, 05:18:57 pm »
RG-402 + SMA connectors ordered.  8)
« Reply #469 on: September 20, 2023, 12:19:54 am »
Don't waste it on that DC stuff...
Ended up just drilling out the end that came with the case.  Seems sturdy enough.
Offline xrunner
« Reply #470 on: September 20, 2023, 12:35:04 am »
Oh no, I'm going to use it for the FWD and REV RF out of the coupler. I think the short coax cables that I'm using are OK, but I want to try my hand at something new.  :)
« Reply #471 on: September 20, 2023, 01:14:11 am »
I was thinking < 500MHz was DC and you need a new project.  Maybe some 3D printed waveguides.
Offline xrunner
« Reply #472 on: September 20, 2023, 01:25:07 am »
Oh shucks! I had a project that went up to 450 MHz and I'll be damned if you went ahead and defined everything under 500 MHz as DC! I see how you play now. Well, now I'm thinking about laser communications next so we'll see where DC is defined then ...  :-DD
« Reply #473 on: September 20, 2023, 02:17:58 am »
Sure, but I don't see how that new coax fits into the picture.
« Reply #474 on: September 20, 2023, 07:33:24 pm »
Thought about adding something like a 9-pin D shell for power and future expansion (maybe allow my software to control the switch).  But ended up with a simple phono jack for power.   Stuck it on the front so all of the connections are on one side.   Needs hardware to mount the SMA to the plate along with new labels.
