Author Topic: $20 LCR ESR Transistor checker project  (Read 5482095 times)
0 Members and 263 Guests are viewing this topic.
Offline madires
  • A qualified hobbyist ;)
« Reply #9900 on: January 19, 2025, 12:15:11 pm »
Looks like a strange design choice.  Why using the 78L05 Vcc as Vref, then comparing the ADC count against a TL431?  Why not using TL431 directly, to generate a 5V ADC Vref?  What am I missing?
IIRC, the external 2.5V reference was added later on and therefore had to be compatible with the original design (and firmware). Also, the tester switches between reference voltages (Vcc and internal bandgap) on demand. A fixed reference voltage at AREF would break that. And with an ATmega328 we don't have unused pins to switch external references, which in turn would make the circuit more complex (we want to keep the basic design simple). Another reason is that this design supports the measurement of a Vcc higher than 5V (the 5V regulator could output 5.07V, for example). Using the TL431 to create a 5V reference voltage for the ADC would limit measurements to that reference voltage.
Offline madires
« Reply #9901 on: January 19, 2025, 12:17:45 pm »
BTW, all this is explained in the OSHW documentation.
Searched for 10 minutes and couldn't figure out which one do you refer to.  In which place are the docs please, or what term to search for?
Please see https://github.com/madires/Transistortester-Warehouse/tree/master/Documentation and start with Karl-Heinz' ttester-1.13k.pdf.
Offline RoGeorge
« Reply #9902 on: January 21, 2025, 04:49:45 pm »
That was a lot of reading.  Took an entire afternoon to read all that.
And together with other things, took me 3 afternoons to clarify which is what.  ;D
But I'm grateful that documentation exists, and the project as well, thank you all, and thanks for support, too.
- first day did the reading
Not yet sure if mine is an RLC-T4 or a T3, but the schematic posted above matches mine, except one resistor, which I guess is a typo.  R12 on the PCB measures 100k, not 10k.  The value printed on the PCB silkscreen is also 100k, so I guess the R12/10k in the picture is a typo.  Funny thing, in some PCB versions (like mine) the programming header is mirrored.
The software docs (English PDF) is probably translated from German, and sometimes not very clear, but the English version of the README text file (the one gziped together with the sources) was crystal clear, and up to date.
- second day had problems with my PICkit 2, and instead of using another programmer, spent the time making the pikit2 programmer to work again.
- then another day spent fooling around with all kind of software options and settings.  I didn't know there are so many hardware and software options for this project.  It can do a lot more than the default.  :-+
A nice surprise was the PC connectivity, which I want to try.  But how come that there is no ADC logger implemented already?  A 3 channel ADC logger (for the 3 probes) would be a nice feature.  Or is it already there but I've missed it?
To summarize for newcomers like me:
- there are repositories for sources and another for documentation
- the project supports many models of MCUs and many types of schematics
- there are two flavors of firmware, 'k' and 'm', 'm' is for MCUs with at least 32k (MCU at least ATmega32)
- unless you are a developer, all you need is to download the last .gz version from https://github.com/kubi48/TransistorTester-source/tree/master/Markus (ComponentTester-1.54m.tgz)
    - unpack and cd into it
    - read the ./README
    - customized the 'Makefile', 'config.h' and 'config_328.h' according to your tester's hardware
    - connect the AVR programmer and type
            make upload
And now, fool around with all the new features for the days to come.  :D
Offline indman
  • Country: by
« Reply #9903 on: January 21, 2025, 05:11:49 pm »
This schematic contains a lot of errors, so I don't recommend using it. I have attached a more correct version below
« Last Edit: January 21, 2025, 05:22:01 pm by indman »
Offline madires
« Reply #9904 on: January 21, 2025, 06:45:34 pm »
No. There are tons of data loggers much better than what an ATmega328 could do.
Offline RoGeorge
« Reply #9905 on: January 22, 2025, 08:02:20 am »
I guess I've spent too much time with the project, because now I'm starting to see all kind of flaws.  ;D
Being open source I'm tempted to change too many details, which might break backwards compatibility with older hardware.  Another thing, I'm tempted to add all kind of upgrades, which will probably sink a lot of time for me (not a programmer), upgrades that will probably not be very useful, or might not fit in the memory without disabling something else.
How do you guys resist to cramming too many features?
- For my hardware version, one thing has to be addressed first is the 2 x 1N4148 diodes in series with the display (which is a 3.3V LCD powered at 4.3V, because the voltage drop of the two series diodes is too small at the quiescent current of the LCD).  When the contrast is set above 9, the LCD contrast is already showing signs of over voltage, and above 15 is unreadable, while the expected contrast range is from 0 to 63.
So either a resistor in parallel with the lcd (to increase the current through the series diodes) or maybe try to replace them with a Zener.
- Another high benefit and easy to do is to replace the 8MHz quartz with a 20MHz one.  Would like it to measure and display faster, but I would expect some loss in precision at higher ADC speed.  Not sure by how much, or if that would be visible at all in the final result.
- Maybe a worth trying HW change would be to increase the current through TL431 (reduce R15/2k2 to 1k or less).  The current now is (5V-2.5V)/2.2k = 1.1mA, out of which some current is needed for the Ref input of the TL431.  1mA is right at the lower edge of the TL431 specs.
TL431 still works at 1mA, but I remember some application notes where the recommended current for peak performance was 10mA.  That would be a lot of current for a 9V primary battery, but I am using a much bigger rechargeable NiMH pack, so I don't care about battery life.
(by the way, the measuring inconsistencies I was seeing before the firmware upgrade are no longer happening with the new firmware - didn't fully tested it, but the values seem rock solid now, with no HW changes yet)
Again, not sure if a higher current for TL431 will have any visible effect.  Are there any known results already (either positive or negative) about increasing the TL431 current?
Offline indman
  • Country: by
« Reply #9906 on: January 22, 2025, 08:21:49 am »
The best option would be to install a separate 3.3V LDO to power the display instead of 2 1N4148 diodes. This is done in more competent clone designs.
The design and circuitry of your clone is simplified and far from optimal, so I do not recommend changing the clock frequency above 16 MHz. Many owners of similar clones note unstable operation at higher frequencies. Better pay attention to those improvements to this clone, which I marked in red on my diagram. This will bring much more benefits than replacing quartz.
As I wrote above, it is better for you to avoid using the TL431 altogether. The best option is to install a high-quality LDO MCP1702-5.0 instead of 78L05
Offline RoGeorge
« Reply #9907 on: January 22, 2025, 10:38:19 am »
I've noticed the changes in red, only that I'm not convinced they are necessary.  Here's what my doubts are about:
- the additional 0.1uF at the input of the 71L05 is not needed, particularly when the power source comes from a battery.  Adding a 0.1uF is a thumb rule, but the existing C1/1uF MLCC already has very low ESR, another 0.1uF won't help.
- 10uF instead of 1uF (the cange of C1/C3) might get the LCO to behave even worst, particularly the C3.  I've looked yesterday in the datasheet of a few 78L05 manufacturers, they recommend smaller C1/C3 values, and they don't use a second 0.1uF neither at input, nor at the output.
The thumb rule of adding 0.1uF decoupling does not apply to voltage regulators, in general.  In fact, for some other regulator models (not 78L05), adding a 0.1uF MLCC might turn them into oscillators, because MLCC capacitors have very low ESR.
- same for the C2/0.1uF at the output (existing in the unmodified version), not needed.  C2 should have been placed near the ATmega Vcc pin on the PCB, and unfortunately it was placed near the 78L05 instead.  I guess things got mixed during the PCB design.  This comment is not about the changes in red, but about the misplacing of the C2 on the PCB design.
- because of the above PCB design pitfall, the C* you added should be beneficial, I'll add those too, just that I didn't mentioned them as critical in my previous post
- the R* of 2k7 seem too big.  I guess the reasoning of adding them was to limit the maximum current into the LCD pins, but the R* combined with the input capacitance of the LCD pin will make a low pass filter (will damage the edges of the digital signals).  For custom builds with a longer ribbon cable to the LCD, the cable capacitance will add to the parasitic C of the LCD inputs, too.  Maybe the 2k7 R* + the C_LCD_input + C_wires might be too much for faster SPI bit-bang at 20MHz sometimes (only a guess, I didn't test it).
Found it, https://www.displayfuture.com/Display/datasheet/controller/ST7565.pdf the LCD pin capacity for mine is 8pF (page 59 of 72).  Corner frequency will be about 7MHz, but to pass nice square edges through it, the bit-bang will gave to be about 10 times slower.  I would expect problems if the equivalent bit-bang SPI clock goes higher than 500kHz.
Anyway, even without any series resistor, the current from an ATmega DO at 5V to a 3.3V+0.6V LCD input clamp diode probably won't be more than a mA or so but I didn't measure.  A few mA will be safe to handle by any input clamp diodes the LCD might have on its inputs.  My guess is, the real reason for no voltage level adapter is because the LCD inputs are in fact 5V tolerant (but at a first glance can't see 5V tolerant inputs mention in the datasheet, so it might not be).
- about the second C*/0.1uF at the AVCC (by the way, it's a good idea to always number or name any components on a schematic, so to easily refer to them later).  As opposed to the 0.1uF near Vcc (where it is added to keep the fast current edges inside the MCU), the 0.1uF is to keep out any incoming spikes, so it will be more effective with a series ferrite bead, or a shunt L, or even a small resistor between the Vcc and the 0.1uF+AVCC, to form a low pass filter.
On the VCC pin, the MCU don't care much about outside noises, so the 0.1uF role is to minimize the escape of the internal RF produced spikes into outside, into the rest of the PCB.  It keeps the inside MCU noises inside the MCU.
On the AVCC pin, the role of the 0.1uF is to keep the outside noises outside of the MCU, so to not influence the ADC and the other blocks sensitive to analog noise.  In fact, the datasheet recommends a low pass filter, not just a decoupling 0.1uF.  A ferrite bead, or a small R in series between the 5V and the 0.1uF at the AVCC should help even more.
Of course, these are generic comments, and I didn't try them in practice.  They might not apply much when the manufacturer sources its BOM based on lowest price alone.  So, if you observe better performance with the changes in red, definitely keep them.
« Last Edit: January 22, 2025, 10:51:08 am by RoGeorge »
Offline indman
  • Country: by
« Reply #9908 on: January 22, 2025, 10:59:39 am »
You have a lot of unnecessary text and theoretical assumptions that you haven't tested. And I have many years of experience in using these devices and I have not just highlighted in red color changes that really correct some of the shortcomings of the circuitry. And they are naturally proven in practice by many people. Whether or not to apply them is up to you. ;)
Offline mentholflash
« Reply #9909 on: February 03, 2025, 06:20:44 am »
Hi all
Just wandering if this could be used to create a ttester?
it was $9
which is the reason for the question
Thanks
Offline hapless
« Reply #9910 on: February 04, 2025, 01:55:10 am »
What do you mean by"conclusions"? Broken out I/O points?
Hi all
it was $9
Thanks
Looks like a simple enough breakout board for the chip. Without a schematic for that thing, I think that removing R2 is going to make it work as the heart of the tester. But there may be something else on the board that needs to be modified, especially if there are more components on the reverse..
Offline snapper
« Reply #9911 on: February 04, 2025, 03:57:17 am »
« Last Edit: February 04, 2025, 07:36:33 am by snapper »
Offline hapless
« Reply #9912 on: February 04, 2025, 04:44:32 am »
Thanks for that. Guess it also needs AREF (pin 20?) to be decoupled from VCC and have a cap on it. Someone more eagle-eyed than I may find something else, but I don't see anything...
Offline masterpogo
« Reply #9913 on: February 10, 2025, 01:08:13 am »
Does anyone have the firmware from the post:
Reply #7879 on: September 22, 2022 and could share it? I don't have 10 posts yet to ask the user in PM and there is only such an option. This is New modification English k-firmware for GM328A(AY-AT) based on the current 899th revision 1.13K.Quartz 8 or 16 MHz.Font 8x15.
THX.
Offline CaptainBucko
« Reply #9914 on: February 11, 2025, 12:41:17 am »
You may be better off installing the required software to compile it yourself.
Install WSL here with Ubuntu 22.04: https://learn.microsoft.com/en-us/windows/wsl/install
Install avr-gcc and downgrade: https://github.com/carl1961/Transistor-Tester-AVR-Compiled-files-On-Windows
Then you have total flexibility for all your needs.
« Reply #9915 on: February 17, 2025, 06:11:28 am »
Hi all
it was $9
Thanks
Thanks for the replies
i stole the atmel from it to put on a 2013 booster model
nxt question does anyone have a BOM file for Transistor_Tester_PCB_Rev_A0_02C_m1284_Mega_4GSL?
the one that is in the file doesn't work for any supply companies
Thanks in advance
cheers
Offline grossd
  • Country: cz
« Reply #9916 on: February 18, 2025, 05:33:11 pm »
Hi, I would like to clarify the situation regarding the discussed 2.5V reference. I have my AY-AT equipped with a 5V MCP1702-5002 regulator and a 2.5V reference LM4040AIZ-2.5. If I disable the use of the 2.5V reference in the config.h file (//#define HW_REF25), is it also necessary to remove the 2.5V reference from the tester?  Will the tester work properly if the LM4040AIZ-2.5 remains physically connected in the tester?
« Last Edit: February 18, 2025, 05:41:17 pm by grossd »
Offline madires
« Reply #9917 on: February 18, 2025, 05:43:25 pm »
You can leave the LM4040AIZ-2.5 in place. Disabling HW_REF25 simply removes all related code, i.e. the external reference will be ignored. When running the k-firmware you would have to remove the external reference, IIRC.
« Reply #9918 on: February 19, 2025, 02:04:13 am »
The tester turns off, "you (are) cut off", the display goes off during the measurement of capacitors, mostly of large capacity. When measuring through the menu, there is usually no such effect.
This problem is typical for software from Karl-Heinz k-firmware (1.12-1.13k).The software from Markus Reschke (m-firmware) also has this effect.
What do you mean it turns off? That is, for some reason the MK resets or the control program fails. The most likely reasons:
1. The power supply voltage of the MK and/or display disappears for a short time;
2. Power supply of the tester (MK) from a pulsed source with large ripples, interference and noise;
3. Triggering of WDT (watchdog timer) - enable/disable is set by the appropriate fuse before compilation or in the software;
4. BOD activation (supply voltage level monitoring system) - enable/disable, the threshold is set by the corresponding fuses before compilation.
5. MK defective (quite possible, given the strong rise in price of original chips and the slag that the Chinese industry is now trying to “sniff”).
I've recently been on my own journey with the known problem of shutdown during >100uF and <1000uF capacitor measurement. My issue has been on the AY-AT GM-328 clone with genuine Atmel MCU328 (DIP28). I narrowed it down to:
   - Capacitors => 100uF and <= 1000uF. Oddly, >1000uF are fine.
   - Measured using ZIF pins (1-3) or (2-3). Oddly, I could never cause the issue to occur using ZIF pins 1-2.
   - External power supply 12v DC. Varying DC supply voltage made no difference.
   - Using Siglent DSO, I could see no significant voltage drop on Vcc during the measurement.
The MCU that came with this kit (MCU #1) had 1.12k. Upgrading this MCU to 1.53m made no difference. Problem occurred in both firmware's.
Upgrading the supplied 7550 +5v regulator for a MCP1702-5002E, checking and replacing decoupling capacitors and add 10uF Tantalum direct on AVR supply pins also made no difference.
I purchased a 2nd Atmel MEGA328 MCU from Digikey (MCU #2) and it worked flawlessly on the same GM-328 board. BOD = 4.3v
I purchased a 2nd AY-AT GM328 kit, took the Atmel MEGA328 MCU from it (MCU #3) it worked flawlessly on the same GM-328 board. BOD=4.3v
I checked MCU#1 ADC 0,1,2 (ZIF 1,2,3) inputs against MCUs #2 and #3 (in the same PCB) - Diode drops to GND and VCC (A-K and K-A) and resistance to GND and cross compared all MCUs, they were all about the same.
Eventually (and thanks to much information posted in this thread), I realized I set the Extended Fuse to = 0xFC (4.3volts) in MCU #1. Looking at my notes, the kits were delivered with the extended fuse = 0xF9 with the kit (which is invalid but BOD is probably disabled in this state?) and later changed it to 0xFC upon erasing MCU #1 moving from 1.12k to 1.53m.
So now, I can get MCU #1 to work if the BOD (Extended Fuse) BOD is set to FD (2.7 volts).
Cal values for MCU #1, 2 and 3 are attached. MCU #1 definitely looks different - the negative Acomp is a concern. Is MCU #1 is a dud?
The 28-pin MCU IC socket is at risk of loose morals so I will stop here and leave MCU #2 installed for now.
Does it appear MCU #1 is damaged or just
EDIT: Photos of MCU ID for each MCU attached
« Last Edit: February 19, 2025, 08:01:38 am by CaptainBucko »
Offline Cosmic_Starlight
  • Country: co
« Reply #9919 on: February 19, 2025, 03:51:07 am »
to add to this issue
i also have well more had the same issue if not pretty similar on another AY-AT unit mine being a factory 16Mhz unit running 1.13K on its supplied MCU
i have this 2200uf electrolytic capacitor that upon trying to meassure it the unit will shut down 100% of the time no matter if its ZIF 1-3, 1-2, 2-3, (ran the test 60 times 20 on each pin combination discharching the cap fully in-between measurements) other lower capacitor values were fine
i tried a higher psu voltage and behaviour was the exact same, 7.0v 9.0v, 12.3v nothing worked
swapping that mcu to another unit the fault followed it with the exact same behaviour no change at all
i also suspect the Brownout detection, however i cant change the EX fuses due to the lockbits preventing any sort of change
replacing it for a new mcu fixed the issue, its currently running 1.54m without a problem using the supplied parts HT7550 and the others and no hardware modification whatsoever and i can test that same 2200uf cap without any problem
Offline indman
  • Country: by
« Reply #9920 on: February 19, 2025, 06:41:02 am »
Note the resistance readings of the Ri- Ri+ I/O ports!!!
It differs significantly from the readings of MCU2 and MCU3. I and many other users have experienced this problem many times.
Your MCU1 is a newer generation controller, it does not mean that it is faulty, but the zone of stable operation of such controllers without failures and BOD reset is much narrower than that of older generation controllers. Therefore, it is highly desirable to set BOD=2.7V.
Perhaps madires will explain this effect in more detail.
« Last Edit: February 19, 2025, 06:44:16 am by indman »
Offline madires
« Reply #9921 on: February 19, 2025, 11:25:07 am »
There isn't much I could add. The first things to try are checking if the LDO is able to provide sufficient current and to add an additional buffer cap (electrolytic) to the 5V rail. If the power supply is fine then try a lower BOD voltage level. Some ATmegas are a bit finicky, i.e. you need to set a lower BOD level or shouldn't clock them beyond 16 MHz. I had fun with that too.
Offline genix
  • Country: ua
« Reply #9922 on: February 20, 2025, 05:24:32 pm »
I have GM328A kit with such MCU + bought separately 2 spare MCUs as well.
I found that it crashes in DischargeProbes() because this newer MCUs (all 3 of mine) has lower internal resistance so current "optimistic" 800mV pull-to-ground threshold is simply too high and causes overcurrent protection / shutdown, it is also more likely to reproduce with hi-value low-esr capacitors, this threshold must be lowered to 400mV or less - then it works fine without any changes in BOD fuses etc.
It has nothing with VR/power delivery.
All my samples works flawlessy at 20MHz as well
The following users thanked this post: indman, CaptainBucko
Offline madires
« Reply #9923 on: February 20, 2025, 06:39:39 pm »
That's interesting! What are the values of RiL and RiH for your ATmegas?
Offline indman
  • Country: by
« Reply #9924 on: February 20, 2025, 07:05:50 pm »
Thank you, this information will be very useful for many new generation MCU owners. I correctly understood that you changed the value of 800 to 400 in the Probes.c file?
else if (U_c < 800)                 /* extra pull-down */
« Last Edit: February 20, 2025, 07:18:19 pm by indman »
