Author Topic: Another DSO+DMM - Zeeweii DSO3D12, claimed 120MHz/250MSps (june 2023)  (Read 151164 times)
0 Members and 11 Guests are viewing this topic.
Offline RAPo
Re: Another DSO+DMM - Zeeweii DSO3D12, claimed 120MHz/250MSps (june 2023)
« Reply #25 on: August 18, 2023, 08:24:28 am »
Estimated delivery date = 30th august. A little bit of patience is needed. :-DD
I know the device is very fresh. But sometimes the Aliexpress ships really quickly so I was hoping someone (RAPo?) already have one or may get one in coming days. The "marketing pictures" somewhat answer some of my questions (if they can be trusted):
« Last Edit: August 18, 2023, 02:10:00 pm by RAPo »
Online Fungus
« Reply #26 on: August 18, 2023, 10:19:33 am »
Offline wasedadoc
« Reply #27 on: August 18, 2023, 12:28:50 pm »
I just found the manual for this online:
http://www.sigpeak.com/download/zeeweii-DSO3D12_manual_EN.pdf
That same link was in the very first post 8 weeks ago.
Offline RAPo
« Reply #28 on: August 21, 2023, 02:36:04 pm »
The Zeeweii DSO3D12 is in.
Did a little basic testing: all seems to be working.
First complaint: I don't like the output pins for the Gen. Will modify it to banana jacks.
Have a basic question: how do I get the saved images to the PC? Asked Zeeiweii for assistance.
Very nice feature: you can save images with a black background or inverted + you can select the color for the 2nd channel.
Especially for you guys I did open the scope. See the images below.
Hires will follow later.
Yes, you can use scope+ gen+dmm (in a little window) together.
You cannot use the DMM while USB is connected.
Indeed the FFT is the same as on the DSO2512G, only reference no measuring.
« Last Edit: August 21, 2023, 03:17:17 pm by RAPo »
The following users thanked this post: Fungus, shakalnokturn, Markus2801A, tunk, lcp, jebem, Aldo22
Offline RAPo
« Reply #29 on: August 22, 2023, 07:06:22 am »
Got a message from Zeeweii:
DSO3D12 does not support transferring images to PC.
|O
I asked to add this in a firmware update.
The following users thanked this post: Fungus, milan_e
Offline RAPo
« Reply #30 on: August 22, 2023, 07:37:58 am »
Results from DMMCheckplus for the DMM:
The following users thanked this post: Markus2801A, Aldo22
Online Aldo22
« Reply #31 on: August 22, 2023, 08:33:57 am »
Thanks for testing and opening.
Does it actually have a rubber-like housing like the DSO2512G or is it hard?
I find that quite practical with the DSO2512G. It does not slip and does not fall down e.g. somewhere in the engine compartment.
Yes, it also has no AV output afaics.
I still think DSO2512G + AN870 is the better equipment in this price range for my case.
« Last Edit: August 22, 2023, 08:35:37 am by Aldo22 »
Offline RAPo
« Reply #32 on: August 22, 2023, 08:49:09 am »
It's a hard plastic.
Indeed no AV output, but that doesn't bother me.
If I hook it up to an USB port a USB serial  CH340 com port comes in the system, no way to get to the files.
I think you are right regarding the combo.
Online Aldo22
« Reply #33 on: August 22, 2023, 09:19:25 am »
After what I had written here:
What is the bandwidth of the signal generator (sine/other)?
Do you see the jitter?
Zeeweii writes "When the set frequency is greater than 1MHz, the square wave signal may show small horizontal jitter".
Is the voice assistant usable in practice?
Is the screen looking good?
Thanks!
Offline RAPo
« Reply #34 on: August 22, 2023, 10:01:07 am »
sine wave max 5MHz, square wave and others max 2MHz.
Horizontal jitter starts at 1.02MHz (sine), 1.01 MHz square but is not really noticeable.
For a 50% square wave:
   1kHz Vpp=2.53V Duty = 50%
   1MHz Vpp=2.49V Duty = 49.5%
   2MHz Vpp=2.47V Duty = 48.6%-49.6%
Didn't try out the voice assistant yet.
Screen quality is the same as the DSO2512G
« Last Edit: August 22, 2023, 10:07:54 am by RAPo »
Online Aldo22
« Reply #35 on: August 22, 2023, 10:10:40 am »
Thank you!
But it should be bigger and better (According to the advertisement)?
Offline ptluis
  • Country: pt
« Reply #36 on: August 22, 2023, 10:14:10 am »
|O
I don't understand how they manage to launch a new product and remove important features.  Voice activation is interesting but then they fail at unthinkable things.  And to transfer images to the computer, well, we have to use a smartphone
Offline RAPo
« Reply #37 on: August 22, 2023, 10:34:16 am »
Indeed quite incomprehensible.
phone + OTG would be nice, but isn't there.  |O.
Offline RAPo
« Reply #38 on: August 22, 2023, 10:36:02 am »
Yes, it is bigger, no doubt about that, but I find the quality more or less the same.
The following users thanked this post: jebem, Aldo22
Offline ptluis
  • Country: pt
« Reply #39 on: August 22, 2023, 01:39:37 pm »
phone camera  :palm:
Offline RAPo
« Reply #40 on: August 22, 2023, 01:55:11 pm »
I'll know, I'll know  ;D
phone camera  :palm:
Offline siealex
  • Country: ua
« Reply #41 on: August 22, 2023, 04:36:55 pm »
To make them subscription based.
Offline RAPo
« Reply #42 on: August 22, 2023, 05:27:40 pm »
Strange triggering.
I'm applying a 1kHz square wave with a 1% duty cycle (from the Fnirsi DPOX) and zooming out to 10ms.
A block of square waves randomly flops from right to left on the screen.
The following users thanked this post: motoge
Offline ptluis
  • Country: pt
« Reply #43 on: August 22, 2023, 09:24:05 pm »
Strange triggering.
why is the scope in AC coupling?
Offline wasedadoc
« Reply #44 on: August 22, 2023, 10:02:16 pm »
Strange triggering.
Why would that have any influence on the issue that RAPo is querying?
Online Fungus
« Reply #45 on: August 22, 2023, 10:07:36 pm »
Strange triggering.
1% duty is very narrow. The display is probably missing the peaks if they don't line up properly with the decimation filter.
(or they're going in and out of phase with it, which is probably what you're seeing)
What happens if you zoom in? I think they should appear.
Offline ptluis
  • Country: pt
« Reply #46 on: August 22, 2023, 11:36:27 pm »
Strange triggering.
I didn't say it had influence, I asked why it was in AC coupling.
Offline RAPo
« Reply #47 on: August 23, 2023, 07:13:13 am »
no particular reason, I started with DC then retest with AC coupling and no difference then I made the photo.
« Last Edit: August 23, 2023, 08:27:15 am by RAPo »
The following users thanked this post: ptluis, motoge
Offline RAPo
« Reply #48 on: August 23, 2023, 07:15:00 am »
If I zoom in, the signal is triggered.
Will investigate this some more.
Online Aldo22
« Reply #49 on: August 23, 2023, 08:25:32 am »
Maybe that's not such a bad thing.
The Zeeweii tells you this way that the resolution is not enough to display the signal reasonably.
Whatever it shows (all yellow, all transparent, what do you expect it to show?) it's wrong anyway ;-)
Just the screen alone: How many 1% peaks can you adequately display with 360 pixels?
My 2 ¢
« Last Edit: August 23, 2023, 08:30:04 am by Aldo22 »
