Author Topic: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B  (Read 235103 times)
0 Members and 21 Guests are viewing this topic.
Offline Testtech
Re: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B
« Reply #675 on: July 15, 2026, 04:43:40 pm »
Hi PA0PBZ
If you would please keys for:
E4407B
S/N SG45100508
Host ID 7240A7BD
IDS
226
Thank you!
Bob
Offline PA0PBZ
« Reply #676 on: July 16, 2026, 02:20:08 pm »
Host ID 7240A7BD
IDS
226
Bob,
I think you want 1DS, not IDS so I generated 1DS for you. If I'm wrong let me know.
1DS 778535D0E112
226 8FF7271E05B2
The following users thanked this post: Testtech
Offline Testtech
« Reply #677 on: July 16, 2026, 10:35:17 pm »
You are correct, thank you!
Offline Testtech
« Reply #678 on: July 17, 2026, 03:10:08 pm »
Would you also please generate code for option 229.
Thanks again!
Offline PA0PBZ
« Reply #679 on: July 17, 2026, 03:12:44 pm »
7CF93A31E3C3
Offline Testtech
« Reply #680 on: July 17, 2026, 03:46:10 pm »
Thanks!
Offline XavierL
« Reply #681 on: July 22, 2026, 03:49:39 pm »
Hello PA0PBZ,
I managed to put my hands on a Agilent PSA E4445A.
Much better than the E4407B to do phase noise measurements.
Would you be able to generate a license key for personality 215 (external source control), 219 (noise figure) and 241 (flex digital demod)?
The serial is MY46181289
The host ID is D4279BF8
Thanks,
Xavier
Offline Cmayer66
« Reply #682 on: July 23, 2026, 01:04:02 pm »
Good day PA0PBZ,
Not sure you are interested in helping someone out who just registered today for this forum as you of course don't know me and owe me nothing, but I was looking to have some keys generated for an E4407B. Our CPU died and had to be replaced, that's done but I need options 219 and 226 added back.
Any chance you'd hook a stranger up? If so, I'll send whatever info you need. Let me know - THANKS!
-Carl
Offline PA0PBZ
« Reply #683 on: July 26, 2026, 03:26:15 pm »
215 7D8327A84A62
219 917B13946256
241 3DCA14B15957
Offline PA0PBZ
« Reply #684 on: July 26, 2026, 03:27:20 pm »
I can do that but I need the HOSTID of the instrument.
Offline XavierL
« Reply #685 on: July 28, 2026, 07:40:02 am »
Hello PA0PBZ,
Thanks a lot, the keys are good.
Best regards,
Xavier
Offline XavierL
« Reply #686 on: August 06, 2026, 09:27:18 pm »
Hello all,
Has anyone tried to activate AYZ on a PSA E44405A?
The required hardware is available in the E4445A.
I would just need to get the LO out and the IF in. No biggies...
Will the firmware accept the AYZ license codes while Agilent stated that it is for 26.5 GHz and above models?
PA0PBZ, could you generate the license key for AYZ?
I am curious to try.
Best regards,
Xavier
Offline PA0PBZ
« Reply #687 on: August 09, 2026, 09:29:14 am »
Hi Xavier,
I see you deleted your msg about thee missing A13, so let us know if it works.
AYZ: 8BEA9B1C38AC
Offline XavierL
« Reply #688 on: August 10, 2026, 09:37:57 am »
Thanks PA0PBZ,
I read conflicting info about AYZ support on the E4445A and E4443A.
One of them was that the A13 board was not fully populated on these models and IF IN may not be switched properly.
However, there is no indication in the Agilent service manuals that there is a different reference of the A13 board for these machines.
I doubt that Agilent would have two different A13 assemblies with the same part number.
That's why I deleted my post.
I have entered the license key and it was accepted.
The IN/OUT menu now gives me access to the external mixing options.
That does not mean yet that it works...
I have to open the analyzer to connect a mixer on the LO OUT and IF IN (this is where the problem could be).
That will take me a bit more time to do that.
I'll keep the forum posted about my findings.
Best regards,
Xavier
Offline PA0PBZ
« Reply #689 on: August 10, 2026, 09:53:08 am »
I just got a question from Greg, user VoidLoopGreg, but since he has zero posts on the forum I can't answer him in a PM. Looks like the forum has the rules mixed up again: zeroposters are not supposed to be able to send PM's but answering them should not be a problem.
So I hope Greg is reading this thread: Please post your question here and I will happily see what I can do. Hint: I need the HOSTID of the instruments to be able to create a license key.
Offline zhang011101
  • Country: cn
« Reply #690 on: August 13, 2026, 10:44:30 am »
hi PA0PBZ,
I am currently trying to test some DPD functions with this old piece of equipmnet and need the following option: 226 229 1D5
could you generate the license? many thanks!
HOST ID :  B88781A8
SERIAL NUMBER : US41062599
best regards,
zjy
Offline PA0PBZ
« Reply #691 on: August 13, 2026, 01:21:44 pm »
HOST ID :  B88781A8
Assuming it is an ESA this should work:
226 224C3E3430FA
229 530A0D030E0B
1D5 BBF02A9C1098
Offline StanfordEE
« Reply #692 on: August 13, 2026, 03:40:53 pm »
Thanks for reaching out to my friend. VoidLoopGreg got banned - apparently merely mentioning a non-free educational product is sufficient. Good thing I didn't post more about all of the free stuff... :)
Anyway, this is my academic account and should work.
Would be extremely grateful for help with the options!
Thanks,
Greg
Offline PA0PBZ
« Reply #693 on: August 13, 2026, 03:44:58 pm »
I'd be happy to help but I still need the HOSTID  ;)
Offline StanfordEE
« Reply #694 on: August 13, 2026, 04:14:59 pm »
Sorry - just went down to the lab and got them.
E4407B
S/N SG44210552
HID 25C3C313
E7705E (in case this could work with the EMC analyzer)
S/N MY45116056
HID 7D83BAF3
Many thanks!
Greg
Offline PA0PBZ
« Reply #695 on: August 13, 2026, 07:20:49 pm »
I have no idea what that even is ;) Does it have any options installed so I can try to reproduce the key?
Offline PA0PBZ
« Reply #696 on: August 14, 2026, 10:42:55 am »
Greg, option 226 for the instruments:
E4407B: 5F68C1CFC095
E7705E: D90D792A84F1
No idea if the last one will work!
Offline StanfordEE
« Reply #697 on: August 14, 2026, 03:50:10 pm »
The second one is an EMC analyzer with these options (EsA hardware):
1DR - narrow resolution BW
1DS - RF preamp
060 - low emission
1D6 - Time-gated SA
UKB - low-frequency extension
B72 - expansion memory
A4H - GPIB and parallal
AYX - fast sweep and ports
AYQ - detectors and FM Demod
1DN - 3.0GHz TG, 50Ω
1D5 - High-stability frequency reference
Offline PA0PBZ
« Reply #698 on: August 14, 2026, 07:06:01 pm »
It looks like some options require/are additional hardware like 1D5 or A4H. Did you check if the instrument has any active options so I can have a look at the key?
Offline StanfordEE
« Reply #699 on: August 19, 2026, 01:16:24 am »
I'm super sorry. Typo. It is an E7405A. The info is here:
https://www.keysight.com/us/en/assets/9018-19220/technical-specifications/9018-19220.pdf
Again, sorry. It is at a site I have to drive to, so I was unable (this week) to power it up and look.
Thanks,
Greg
